Two Grey dot are visible in direct sunlight
  1. Prem 24
    Froyo Jun 29, 2019
    Prem 24 , Jun 29, 2019 :
    As Circled in photo two Grey dots are visible in direct sunlight
    . I checked in others phone they are also facing this issue what is this ?
  2. moneytoo
    Cupcake Jun 29, 2019
    moneytoo , Jun 29, 2019 :
    I also see them under direct sunlight. I guess they are brightness/proximity sensors. Similar but larger gray circle is visible for the fingerprint reader (but also under direct sunlight).
    Paulo Viana likes this.
  3. Prem 24
    Froyo Jun 29, 2019
    I think so it's something else because that sensor are left side of front camera
    And I have OnePlus 6T also this dot are not visible in it in direct sunlight
  4. Paulo Viana
    Froyo Oct 13, 2019
  5. Paulo Viana
    Froyo Oct 13, 2019
    Paulo Viana , Oct 13, 2019 :
    [QUOTE = "moneytoo, post: 20488830, membro: 849223"] Também os vejo sob luz solar direta. Eu acho que eles são sensores de brilho / proximidade. Um círculo cinza semelhante, porém maior, é visível para o leitor de impressões digitais (mas também sob a luz solar direta). [/ CITAÇÕES]
    Então this.nai Então isso não é um defeito?
    [QUOTE = "moneytoo, post: 20488830, membro: 849223"] Também os vejo sob luz solar direta. Eu acho que eles são sensores de brilho / proximidade. Um círculo cinza semelhante, porém maior, é visível para o leitor de impressões digitais (mas também sob luz solar direta). [/ CITAÇÕES]
    Então, isso não é um defeito?
  6. Paulo Viana
    Froyo Oct 13, 2019
  7. Girish Bapat
    Cupcake Oct 15, 2019
    Girish Bapat , Oct 15, 2019 :
    Any idea what are these spots?
    Got them on my op7 too.
  8. Liehjan
    Lollipop Oct 15, 2019
    Liehjan , Oct 15, 2019 :
    Ambient and proximity sensor
  9. Liehjan
    That's the under display fingerprint reader... Nothing wrong with your device
  10. #10
  11. Liehjan
    The same sensors are there on the 7pro... don't know if it's ambient/proximity but there are holes by design!
    A1569745141844 likes this.
  12. Last edited: Oct 15, 2019
  13. Liehjan
    To answer why you can see them is because it's basically a hole in the screen so that the sensor can shine through. You will find a third hole if you look closely at the fingerprint reader... This is a screenshot from jerryrigeverything teardown video, look when he shines light through the display from the front.
  14. Liehjan
    Read my reply's above :D
  15. Girish Bapat , via OnePlus 7 Mirror Blue , Oct 15, 2019 :
    don't need to see another spot!! but really glad its not faulty piece. anyways thanks for the info.
    Paulo Viana and Liehjan like this.
  16. Liehjan
    Happy to help, enjoy your device :)
  17. andcos
    Cupcake Oct 23, 2019
    andcos , Oct 23, 2019 :
    Hi guys, some situation here. Under the sunlight is very annoying, because I can see these 2 grey dots as you can see in this picture. I opened the RMA, Oneplus accepted it, I had to send my phone in Poland and CTDI told me that "No fault found - no malfunction has beed detected".
    So what I have to think? It's all normal (wow, 600 euros for this screen), all the devices are faulty or the repair service is useless? Oneplus contacted me and asked me to open another RMA... lol
    Such a waste of money and time.
  18. MKaderco
    MKaderco , via OnePlus 7 , Oct 23, 2019 :
    andcos
    bro.
    I have notice that two holes in first day from buying one plus 7
    I send it back . ask them to send me new one .
    so I got new one with two big and small holes
    I contacted them and told what is the problem with this . screen
    but I got No answer .
    my experience is Service in Poland is useless . and there support also .
