type c headphones is not connecting via OnePlus 5
  1. Gautham.2001
    Gingerbread Mar 7, 2020
  2. Waveform Modifier
    Marshmallow Mar 7, 2020
    Waveform Modifier , Mar 7, 2020 :
    You need to explain a lot more than that.
    Y1541333278792 likes this.
  3. Vandit_S.S
    Gingerbread Mar 8, 2020
    Vandit_S.S , via OnePlus 5T , Mar 8, 2020 :
    Oh I have a better suggestion. Use search engine first please.
    Try to enable OTG in settings and try it again. This phone does not support type C earphones because it has 3.5mm jack .
    I saw that after enabling OTG, it works fine. Try it
  4. Y1565085061374
    Cupcake Apr 8, 2021
    Y1565085061374 , via OnePlus 7 , Apr 8, 2021 :
    Since a couple of monthes I only have audio in my cable in-ears in the right channel. Replaced already the usb type-c to 3.5 mm jack, but still not working. Headphones work perfectly on my tablet via the 3.5 mm audio jack.
    Charging via the type- c connector has no problem.
    I read that there are other people with a similar problem. Any idea what I can do oi fix this issue?
    It concerns my OnePlus7
    GM1903
    Oxygen OS 10.0.11.GM57BA
    Thank you
    Ome Kees
    Netherlands
  5. Waveform Modifier
    Marshmallow Apr 9, 2021
    Waveform Modifier , Apr 9, 2021 :
    Wrong forum
  6. Y1565085061374
    Cupcake Apr 9, 2021
  7. Waveform Modifier
    Marshmallow Apr 10, 2021
    Waveform Modifier , Apr 10, 2021 :
    Not a moderator. Just go ask in the forum your device is on.
