6
UI drop frames, animation stutters.
  1. Dunnow
    The Lab - OnePlus 6 Reviewer Jul 12, 2020
    Dunnow , Jul 12, 2020 :
    Nah, it happens all around the UI.
    Scrolling stutters.
    Pulldown shade stutters.
    It's an issue since Android 10 update
    A1577275579996 likes this.
  2. Dunnow
    The Lab - OnePlus 6 Reviewer Jul 13, 2020
    Dunnow , Jul 13, 2020 :
    10*
    Since the last version update basically.
    And at this point 3 or 4 small updates after, I'm starting to believe those 120hz look so nice in comparison for a reason
  3. mischa1981
    Ice Cream Sandwich Jul 13, 2020
    mischa1981 , via OnePlus 6T , Jul 13, 2020 :
    There was a launcher update recently. You could try to update the launcher and see if the problem still exists.
    My launcher now has version 4.5.7.
    Lags have been reduced significantly.
    A factory reset should always be the last option. Some people even install Windows new every time they update their graphics driver...
    Caoimhín likes this.
  4. Sharry7
    Sharry7 , Jul 13, 2020 :
    Done everything....factory reset, update launcher. But no luck. This issue is getting bad:mad::confused:
    mischa1981 likes this.
  5. mischa1981
    Right now it started again on my phone, too. It's a real pain in the butt, but it's only started since Android 10. Under Android 9 I never faced that issue.
    A1577275579996 and Roman941907 like this.
  6. A1577275579996
    Froyo Jul 21, 2020
    A1577275579996 , Jul 21, 2020 :
    Same issue, animations stutter, there are alot of frame drops while scrolling in apps like Twitter, reddit, etc and apps take a while to open since the last update, UI also feels laggy, it wasn't like this before the last update, hopefully this gets fixed.
  7. Caomhin
    OnePlus 9 Series Expert Community Expert Jul 21, 2020
    Caomhin , via OnePlus 6T , Jul 21, 2020 :
    With that many issues Backup your phone and do a factory Erase All Data reset.
    See if that helps.
  8. A1577275579996
    Froyo Jul 21, 2020
    Caomhin, I've already done exactly that 3 times already but it's still the same.
  9. Caomhin
    If so, then I would suggest contacting OnePlus support directly.
    Report the issue directly to OnePlus Developers as a Bug report.
    And also contact OnePlus support directly to see if they have more information on your issue. Scroll down the page for contact and online chat details.
  10. dareknowak
    Froyo Dec 1, 2020
    dareknowak , Dec 1, 2020 :
    Had the same issue on my 5T, replaced a year ago with 6T. These phones are doomed. Will switch to some other brand. Another gen of phones and they still trace the issue. Did search this forum and tried to apply some changes in settings, wiped etc. etc. , nothin works. It just comes back after a week/two.
  11. dareknowak
    Froyo Dec 1, 2020
    Thing is this is a small company, they are pushed to show new phone every year. It can't be done properly with that kind of attitud. I've reported that issue even for my 5T I had previously. My Jaw dropped when I bought 6T and see same thing on new device. That's why I'm switching to pixel, it's over my budge, I'll try though.
  12. #32
