2
[Submitted] Unable To Answer Incoming Calls
  1. gurudrew
    Eclair Feb 6, 2021
    gurudrew , Feb 6, 2021 :
    Hello,
    I'm a 7T user that's testing the open beta of Android 11. Both versions of the open beta (1 & 2) have a bug in which the user is unable to answer an incoming phone call. This was tested on multiple phone apps from the Play Store and all had the same result. The issue was confirmed with a 7T Pro user who also has reported this issue prior to rolling back to the stable build of Android 10. I'll continue to stick with the open beta to see if this bug gets addressed within the third update.
    Thank you.
    brandontict and Ltrademark like this.
  2. brandontict
    Cupcake Mar 7, 2021
    brandontict , Mar 7, 2021 :
    I was able to fix my issue by the disabling Google Fi.
  3. #3
