Unable to connect usb for data transfer via OnePlus 7T
  1. S1554636941812
    Cupcake Aug 13, 2020
  2. Cervantes
    Moderator Moderator Aug 13, 2020
    Cervantes , Aug 13, 2020 :
    Hi
    in settings, phone information: touch 7 times compilation number, go back
    in settings, system, developer options, activate: usb debugging
    connect the phone
    in windows file manager, look for the disk with the Op logo, install the driver
    down notifications screen, change usn settings to: file transfer
  3. S1554636941812
  4. VB1
    Gingerbread Aug 13, 2020
    VB1 , via OnePlus 7T , Aug 13, 2020 :
    Go to Default USB configuration under developer options and select file transfer. You should be able to transfer files to your laptop/PC.
  5. S1554636941812
  6. Sheppards
    Jelly Bean Aug 14, 2020
    Sheppards , Aug 14, 2020 :
    1. Install drivers from the Virtual CD drive that appears when you connect. Drive should be something like "Oneplus Drivers" with a Oneplus logo next to it.
    2. Actually, by default, you have to unlock the phone, pull down the notification shade, and click on Other notifications - USB Preferences or options, and select file transfer.
    You can do this from the settings\USB preferences as well
    VB1 likes this.
  7. VB1
    Gingerbread Aug 14, 2020
    VB1 , via OnePlus 7T , Aug 14, 2020 :
    Just attach a screenshot of the Notification panel which you get when you connect the phone to the laptop. Follow the instructions mentioned by @Sheppards
    Sheppards likes this.
  8. OnePlus_8t
    Jelly Bean Aug 15, 2020
  9. Edgar Medina
    Cupcake Mar 30, 2021
    Edgar Medina , Mar 30, 2021 :
    I guess that you have trouble with the driver in your PC , I have the same problem (MTP driver)
