unable to enable sound in oneplus7 pro
  1. swatikalia
    Cupcake May 19, 2019
    swatikalia , May 19, 2019 :
    Hello guys,
    I received the new one plus 7 pro few days back but I am unable to enable the sound. It says phone is on mute and sound bar is also not moving
    I did the phone update as one update was available but no luck
    Please suggest shall I go for replacement
  2. Allstar12345
    Honeycomb May 19, 2019
  3. manuel19
    KitKat May 19, 2019
    manuel19 , May 19, 2019 :
    on the side of the phone, above the power button, you find the alert slider. Use it to switch between different sound profiles
    swatikalia likes this.
  4. swatikalia
    I compelety forgot that
    .. Much thanks it worked
    spdsk8race1 likes this.
  5. V1558553751271
    Cupcake May 22, 2019
    V1558553751271 , May 22, 2019 :
  6. V1558553751271
    Hi
    I have almost the same problem, only vibrations when someone calls no sound, I can't find the option to enable sound, this is my 7th android and all the others had an icon at the top one coulld tap, when going to meetings, cinema and so on
    HOW TO ??
  7. spdsk8race1
    Honeycomb May 22, 2019
    spdsk8race1 , May 22, 2019 :
    read the comments above.. slider on the right, push down for ring, middle is vibrate, up is silent.
  8. V1558553751271
    Cupcake May 23, 2019
  9. Spelt
    Ice Cream Sandwich May 24, 2019
    Spelt , May 24, 2019 :
    Sounds like the alert slider is in silent mode.
