Unable to hear during voice calls on one plus 7 pro via OnePlus 7 Pro
  1. #1
  2. J4t1np4r3kh
    OnePlus Accessory Tester Jul 27, 2021
    J4t1np4r3kh , Jul 27, 2021 :
    Are you getting good network in your area?
    Can you try restart your phone?
    When this issue comes up again, can you turn on airplane mode and turn it back off again?
    Try put your sim in the other sim slot, and see whether it resolves the issue
  3. Z1612187578731
    Gingerbread Jul 27, 2021
  4. nerdkabir
    Jelly Bean Jul 27, 2021
  5. BugsBugsEverywhere
    Cupcake Jul 27, 2021
    BugsBugsEverywhere , Jul 27, 2021 :
    Are you using WiFi calling? Try turning off WiFi calling (if you can.) I have this problem on certain networks. I can receive and dial calls, and the party on the other end can hear me, but I can't hear them. It's such a common occurance that I know what's up, and tell them "Call me right back, I need to turn off WiFi." After that the calls using the cellular network work fine.
  6. Pushpdeep_gupta , via OnePlus 7 Pro , Jul 27, 2021 :
    Yes there is no problem of network at all in my area and this problem is with both sim that I am not able to hear the other person's voice clearly on voice network call.
  7. Pushpdeep_gupta , via OnePlus 7 Pro , Jul 27, 2021 :
    No I am not using wifi calling just a normal voice network call.
    BugsBugsEverywhere likes this.
