unable to re-install OOS 5.1.4 or 5.1.3
  1. B1514900966419
    Gingerbread Aug 2, 2018
    B1514900966419 , Aug 2, 2018 :
    I had upgraded to OOS 5.1.4 in my 5t using Oxygen updater, and when try to reinstall the OOS 5.1.4 which I had download ed from OnePlus support, the system is saying, I'm to downgrade my phone and so all user data needs to be erased. I even tried reinstalling OOS 5.1.3 but i'm getting same error.
    please let me know if there is a solution.
    Thanks
  2. Omkar_Bhavsar
  3. B1514900966419
  4. Omkar_Bhavsar
  5. B1514900966419
    not sure not what is the difference from the one I installed using Oxygen updater vs. the one in one plus support website. So I want to reinstall the one from one plus support website.
  6. Omkar_Bhavsar
    Omkar_Bhavsar , Aug 2, 2018 :
    The one that you got OTA from Oneplus should be the same as the one on their website. They wouldn't send you a different one OTA.
  7. Liehjan
    The Lab Reviewer - OnePlus Buds Pro Community Expert Aug 2, 2018
    Liehjan , Aug 2, 2018 :
    there is none, it's exactly the same!
  8. B1514900966419
    then why is it asking me to do a user data wipe
  9. Omkar_Bhavsar
  10. Liehjan
    That I don't know, maybe something to do when you try a local update.. do it from recovery instead.
  11. B1514900966419
    when I reinstall the version that I had downloaded from one plus site and installed in my phone, it did ask me to do user data wipe for reinstallation
    Whereas when try installi the version that I downloaded using Oxygen updater, it didn't ask me user data wipe and the reinstallation was smooth
  12. B1514900966419
  13. B1514900966419
  14. CristianD
    Donut Aug 2, 2018
    CristianD , Aug 2, 2018 :
    I made it, and all my data were deleted. But I choose to install beta 14 with upgrade to 15 because it looks better.
  15. B1514900966419
    so without the data getting deleted it isn't possible, and so the indian version is a downgraded version then.
  16. CristianD
    Donut Aug 2, 2018
    Yes. Keep beta version.
  17. B1514900966419
  18. CristianD
    Donut Aug 2, 2018
  19. B1514900966419
    and just for information, it's happening with the stable version as well, not just with beta version
  20. G_T_Bennett
    Jelly Bean Aug 2, 2018
    G_T_Bennett , Aug 2, 2018 :
    Why is beta being discussed? The version of the from Oxygen Updater and the OnePlus website is the exact same. There's no need to reinstall unless you are having issues.
    Open Beta firmwares are completely different.
