Unbrick help! Please!
  1. Peterrrrr
    Gingerbread Mar 10, 2020
    Peterrrrr , Mar 10, 2020 :
    I wiped everything in trwp when I was going to install Lineage, I did the misstake to restart the recovery and now Im stuck in the bootlaoder.
    I need to install the stoc firmware via fastboot/bootlaoder but can't find any img file, only zip file of the Stock firmware.
    Is is possible to install a zip file via fastboot?
    Fastboot recognize the phone when typing the commando fastboot devices, so I see the serial nr.
    If I try to install twrp img both on boot and flash recovery commando I get this:
    PS C:\Android> fastboot boot twrp-3.2.1-0-enchilada.img
    downloading 'boot.img'...
    OKAY [ 0.577s]
    booting...
    FAILED (remote: Failed to load/authenticate boot image: Load Error)
    finished. total time: 0.598s
    PS C:\Android> fastboot flash recovery twrp-3.2.1-0-enchilada.img
    target reported max download size of 536870912 bytes
    sending 'recovery' (26748 KB)...
    OKAY [ 0.574s]
    writing 'recovery'...
    FAILED (remote: (recovery_b) No such partition)
    finished. total time: 0.579s
    I have tried the MsmDownloadTool V4.0, but the deviced manager in windows doesn't find the Qualcom....
  2. pablofg1978
    Head Moderator Head Moderator Mar 10, 2020
    pablofg1978 , Mar 10, 2020 :
    What device do you have?
    Caoimhín and Artemus like this.
  3. Jimbo the Great
    Ice Cream Sandwich Mar 10, 2020
    Jimbo the Great , Mar 10, 2020 :
    Flash a stock Rom over using fastboot.
    Should work if your bootloader is unlocked.
    Search XDA. I think the user is mauronofrio
    Has stock rom recovery from Fastboot.
    hope this helps
    good luck.
  4. Caomhin
    9 Series Expert, Participator of the Year Community Expert Mar 10, 2020
    Caomhin , via OnePlus 6T , Mar 10, 2020 :
    For OP6 Only
    [e]26a0[/e]️[e]26a0[/e]️[e]26a0[/e]️ Do This is at your own RISK[e]26a0[/e]️[e]26a0[/e]️[e]26a0[/e]️
    This link at XDA will point you in the direction to unbrick your OP6 phone.
    Please follow their instructions to the letter. Read the posts by other users on XDA for more info
    https://forum.xda-developers.com/oneplus-6/how-to/op6-collection-unbrick-tools-t3914109/amp/
    If you are not comfortable doing that, please contact OnePlus directly at the link below for more information. Or bring the phone to an approved OnePlus service center.
    Scroll down the page for contact details.
    For OP6T ONLY
    This link at XDA will point you in the direction to unbrick your OP6T phone.
    https://forum.xda-developers.com/oneplus-6t/how-to/op6t-collection-unbrick-tools-t3914746/amp/
  5. Peterrrrr
    I used Tool All In One to get back to stock.
    So I installed TWRP and wiped everything, but when Im going to copy the zip files to the internal storage nothing happens when Im extracting the files to the storage.
    Installing via sideload doesn't work either....
    How should I do in order to make the internal storage work?
  6. Artemus
    Junior Moderator, Community Hero 2020 Junior Moderator Mar 10, 2020
    Artemus , Mar 10, 2020 :
    What device are you using?
    Caoimhín likes this.
  7. Caomhin
    You need to follow the instructions within the links I sent, you may need to read the posts to find out how to utilise the files sent.
    Also like I said if you are not comfortable with that use the other link to OnePlus support to contact them to find out more info.
    Artemus likes this.
  8. Artemus
    You screwed up the quote. ;)
  9. Caomhin
    Artemus likes this.
  10. Peterrrrr
    I don't find anything in the links for how to make the internal storage work.
    I tried once again, after installing twrp I can wipe everything except Internal Storage.
    The thing is, in order to install Linaege Os 17 via TWRP I need to Internal Storage....
  11. Caomhin
    The links I have given are to get you to a working OnePlus phone, with OOS nothing to do with TWRP or lineageos. If you want to go that route then consult XDA, Lineageos or whoever else can fix a Modded phone.
    Artemus likes this.
  12. Jimbo the Great
    Ice Cream Sandwich Mar 11, 2020
    Jimbo the Great , Mar 11, 2020 :
    When you used the All in One tool... did you get all the way back to a functioning stock Oxygen install?
    Maybe there is an issue with the TWRP version with the flashed stock Rom and bootloader version.
    Verify your stock rom version when reflashed.
    Use the right TWRP version...( I know that with 10+ TWRP uses a different version than 9. )
    Artemus likes this.
  13. B_Wrath
    Junior Moderator Junior Moderator Mar 11, 2020
    B_Wrath , Mar 11, 2020 :
    Use the stock recovery and not twrp.
  14. E1588652385010
    Cupcake Aug 6, 2020
