7
[Unified] Always On Display Feature Removed post SW Update
  1. vwite
    Honeycomb May 25, 2018
    vwite , May 25, 2018 :
    oh really? do you mean colors or brightness? I read brightness was only about 400 which is barely enough to use under the sun while note is 600 manually but peaks at around 1200 nits with automatic brightness under the sun
    what about the speaker? When I had the note 8 the speaker was crap but I'm gonna miss the stereo speaker's of the S9+, do you think the speaker on OP6 is about the same than note 8 in loudness?
  2. BA_Baracus
    Eclair May 25, 2018
    BA_Baracus , May 25, 2018 :
    My suggestion is when charging a clock will be on screen is a nice option .
  3. Nezumi_
    KitKat May 25, 2018
    Nezumi_ , May 25, 2018 :
    you can use the screensaver for that though.
    MentalDraco likes this.
  4. Ashura6666
    Eclair May 25, 2018
    Ashura6666 , May 25, 2018 :
    Well I am using it on my S9+ and it just adds a little bit more to the experience. And yeah if you don't want it you could always toggle it off.
  5. G_Ciprian_Mihai_CfCD
    Gingerbread May 25, 2018
    G_Ciprian_Mihai_CfCD , May 25, 2018 :
    As I mentioned, the screen is better but not in a way to make you keep the Note 8 if you consider all the aspects. The speaker is about the same. Average
  6. Mohit makhija1234
    Froyo May 25, 2018
    Mohit makhija1234 , May 25, 2018 :
    it was there on original firmware...after update that's gone...but I think they might bring it back in future updates
  7. X1527220994666
    Cupcake May 25, 2018
    Ashura6666 likes this.
  8. vwite
    Oh sorry I read it wrong I think you meant it was better on OP6, I'm getting mine next week I really hope the display, camera and speaker are good enough
  9. G_Ciprian_Mihai_CfCD
    Screen, camera sound are good but not great. But packed together with the other features of the OP6, software, fast updates in the background, super fast charging good battery life ( by my usage I get almost double compared to Note 8) navigation gestures, very nice immersive screen with almost no bezels, all of this make you have a better experience
    vwite likes this.
  10. Lakshya00
    Eclair May 25, 2018
    Lakshya00 , May 25, 2018 :
    OnePlus should bring out ambient display, if you move the device without lifting it up, it would show you the time and notifications.
  11. Nezumi_
    KitKat May 25, 2018
    ambient display is already there.
  12. Lakshya00
    Eclair May 25, 2018
    Where? I can only find lift up display in ambient display settings.
  13. Nezumi_
    KitKat May 25, 2018
  14. Vansh_c
  15. Lakshya00
    Eclair May 25, 2018
  16. MentalDraco
    Marshmallow May 25, 2018
    MentalDraco , May 25, 2018 :
    It's already there
    Nezumi_ likes this.
  17. Vansh_c
  18. Lakshya00
    Eclair May 25, 2018
    it works only if i lift up the phone. If i move the phone on a say table without lifting it up, it won't show notifications.
  19. Satyendrasingh3339
    Satyendrasingh3339 , May 25, 2018 :
    enable daydreaming in display settings.
  20. MentalDraco
    Yea that's how it's supposed to work. Else every small movement would trigger it, keep your screen awake and drain battery.
    Nezumi_ likes this.
