36
Battery/Charging [UNIFIED] Battery and heating feedback thread OnePlus 7t pro
  1. milind kowli
    Donut Oct 21, 2019
    milind kowli , Oct 21, 2019 :
    Moderator edit:
    Please use this thread for any questions, SOT, tips, issues and all things related to battery and heating of the OnePlus 7T pro.
    Please note that the way you use the phone (daily usage scenarios and habits) will make a huge difference to the battery/heating performance. In a scenario where there is a heavy performance workload, such as photo shooting/video shooting/mobile gaming/video consumption, the power consumption and heating of the phone will increase accordingly, which is a normal phenomenon.
    You are more than welcome to share any battery tips and tricks in the comment section and ask a forum moderator to pin your post on the first page of this thread.
    Battery optimization never ends. To help OnePlus better resolve battery/heating-related issues, please submit a bug report via the Feedback Tool in the Community app. Thank you in advance.
    ---------- Original thread ----------
    Since i update my one plus 7t pro to the latest update i.e 10.0.3
    I'm Facing the battery Draining issue on my device.
  2. Undeathly_Shadow
    Cupcake Oct 24, 2019
    Undeathly_Shadow , Oct 24, 2019 :
    could you share some more info?
    how long is it holding what is it what makes you belive its a drain effect
    how do you charge it?
  3. Kishan143
    Cupcake Oct 26, 2019
    Kishan143 , Oct 26, 2019 :
    I play Indian Train simulator game in OnePlus 7pro very heat pls all tye game play very heat mobile
    G_JAYA_SEELAN_87 likes this.
  4. Santhosh2791
    Eclair Oct 27, 2019
    Santhosh2791 , Oct 27, 2019 :
    I am using OnePlus 7T pro for last couple of days. I have noticed that battery draining from 100% to 30% in 4 to 5hrs and in battery saver mode it lasting for more then 5hrs with most of the functions disable. So do we have to disable most of the functions to keep the battery in normal mode.
    Need some suggestions and recommendations.
    thanks on advance
  5. X1519571958371
    Cupcake Oct 28, 2019
    X1519571958371 , Oct 28, 2019 :
    I am a very old user of oneplus and I know no one plus batteries are really good but I am not satisfied with the oneplus 7t pro i.e my new phone.
  6. Santhosh2791
    Eclair Oct 29, 2019
    Santhosh2791 , Oct 29, 2019 :
    Hi,
    In my case, I haven't did any of the actions what you have mentioned. Just browsing and taking few photos and watching YouTube videos in my WiFi network. that's it.
    obuj12118085bris likes this.
  7. Santhosh2791
    Eclair Oct 30, 2019
  8. NemesisOne
    Donut Oct 30, 2019
    NemesisOne , Oct 30, 2019 :
    Hi all,
    i'm an happy OP 7T pro owner. It's my first time on Oneplus and I wanna ask which are the average cpu temperature (more or less) of the phone during gaming and normal use.
    CPU TEMP:
    I use CPU Monitor to check it and usually during gaming it sets between 38c and 55c. Just a couple of time it reached 60c. During normal use of the phone (chrome, Instagram etc) it works at 30c-40c reaching sometimes 45c-47c.
    BATTERY TEMP:
    28c-32c During Normal use
    35c-36c During Gaming.
    The body becomes warm but not hot.
    I never had OP so I don't have term of comparison about the Cpu temp. Someone could tell me if they are ok?
    I used Cpu Monitor or Cpu Z to measure
    Thanx
  9. E1572241530465
    Cupcake Oct 31, 2019
    E1572241530465 , via OnePlus 6 , Oct 31, 2019 :
    hi, I have purchased OnePlus 7T pro on 28th Oct and since next day facing issue of handset heating, random beep sound and battery drainage. that too my mobile usage is very less.
    have contacted service center and they have taken the mobile for problem diagnosis.
    I have used other models of OnePlus but never faced the problem.
    I am highly disappointed with OnePlus 7t pro.
    need either a replacement or refund.
    kindly suggest.
    kevalogin and Harmony7 like this.
  10. Santhosh2791
    Eclair Oct 31, 2019
    Santhosh2791 , Oct 31, 2019 :
    Hi, What is the result of the problem diagnosis? What did they said
    I got only battery draining issue... for now...
    burhanpgr and P1572590577800 like this.
  11. milind kowli
    Donut Oct 31, 2019
    milind kowli , Oct 31, 2019 :
    In my opinion i found out that,
    Whenever a person using 7t pro with QHD and 90hz refresh rate battery backup will be less as compared to FHD setting.
    And screen usage time will be less.
    Jotha.dx likes this.
  12. milind kowli
    Donut Oct 31, 2019
    Comparing my phone to the Note 10 plus battery backup is less.
  13. milind kowli
    Donut Oct 31, 2019
    Due to quad hd display the battery backup and screen time usage is less.
  14. Santhosh2791
    Eclair Nov 3, 2019
    Santhosh2791 , Nov 3, 2019 :
    We understand that, so what is the solution for this now? OnePlus should be knowing this before the release or during the testing phase correct. They can't wait till the end customer reports.
  15. NemesisOne
    Donut Nov 3, 2019
    NemesisOne , Nov 3, 2019 :
    No problem with the battery. it lasts really long on 90hz and 2k resolution. 8 hours of screen with a couple of games and social apps.
  16. Rediwed
    Gingerbread Nov 4, 2019
    Rediwed , Nov 4, 2019 :
    My 7T Pro's SOT is just about 2-3 hrs SOT (24hrs since charge) on a full charge. I can't get close to 5-6 hrs SOT without charing it at least twice throughout the day. The phone is usually above 50 degrees Celcius. My usage is pretty light; web browsing, music, social media, youtube, some photography.
    It currently lasts 24 hours with light usage, and at least about a full day with moderate usage. Heavy will drain in it half a day.
    mi2sh and Harmony7 like this.
  17. chuck_stones
    Gingerbread Nov 5, 2019
    chuck_stones , Nov 5, 2019 :
    I've just switched to the 7t Pro and I'm sorely disappointed to see how terrible the battery life is. What is happening here? I can't see anything specific that is draining the battery, but I'm down to ~50% with 1 hour screen time.
    fdorr, 03406356532 and Santhosh2791 like this.
  18. GeorgiKostadinov
    Cupcake Nov 6, 2019
    GeorgiKostadinov , Nov 6, 2019 :
    Last night i went to bed with 60% battery life.
    Today morning the phone is dead.
    After staying on the charger for 30 minutes and Volume up+Power button i managed to turn it on and it was on 9% battery.
    I will update if this happends again.
    Santhosh2791 likes this.
  19. Santhosh2791
    Eclair Nov 7, 2019
    Santhosh2791 , Nov 7, 2019 :
    Guys, With the disable of below options I have noticed battery is not draining too much... Screen usage since full charge is around 3hrs from 100% to 55%. with average usage of social networking apps.
  20. vsinha717
    Gingerbread Nov 7, 2019
