21
Battery/Charging [UNIFIED] Battery and heating feedback thread OnePlus 7t pro
  1. Y.Singh
    Froyo Feb 15, 2020
    Y.Singh , Feb 15, 2020 :
    it's not their intention to send faulty devices but sometimes it just happens, I'm not sure what you can do try email them for steps and you will probably be charged as it's not in your country.
  2. AlizainAkber , via OnePlus 7T Pro Haze Blue , Feb 16, 2020 :
    please tell me that your device doesnt get that hot while playing pubg or warms up after restart or downloading anything?
  3. AlizainAkber , via OnePlus 7T Pro Haze Blue , Feb 16, 2020 :
    please reply please tell me that your device doesnt get that hot while playing pubg or warms up after restart or downloading anything?
  4. Y.Singh
    Froyo Feb 16, 2020
    Y.Singh , Feb 16, 2020 :
    AlizainAkber
    please reply please tell me that your device doesnt get that hot while playing pubg or warms up after restart or downloading anything?​
    no my device is perfectly fine, it's never gotten hot stays cool most of the time might get warm but that's it.
  5. AlizainAkber , via OnePlus 7T Pro Haze Blue , Feb 16, 2020 :
    while playing pubg?
  6. AlizainAkber , via OnePlus 7T Pro Haze Blue , Feb 16, 2020 :
    its normal use or while playing pubg?
  7. Y.Singh
    Froyo Feb 16, 2020
    I don't play pubg but when playing heavy games it is pretty cool. your device isn't right man you need to check it out.
  8. AlizainAkber , via OnePlus 7T Pro Haze Blue , Feb 16, 2020 :
    my normal usage is fine like browsing or YouTube or netflix but some apps warm it up. is it ok or not
  9. Y.Singh
    Froyo Feb 16, 2020
    I cannot tell you mine has never heated up like that.
  10. Y.Singh
    Froyo Feb 16, 2020
    mine stays cool all of the time but I do live in a decently cool place
  11. AlizainAkber , via OnePlus 7T Pro Haze Blue , Feb 16, 2020 :
    i have talked to other guy his device also reaches to 65 degrees while playing pubg and has same issues as mine and some others as well.
  12. Y.Singh
    Froyo Feb 16, 2020
    well mine is fine, the people you talk to have issues try speaking with other people who own it and ask comments on videos that are not about heating issues as you will meet people who have these issues.
  13. AlizainAkber , via OnePlus 7T Pro Haze Blue , Feb 16, 2020 :
    ok. so will it be replaced with new phone or be repaired? any idea?
  14. Y.Singh
    Froyo Feb 16, 2020
    you might have to pay for repair as it's not from your country
  15. Y.Singh
    Froyo Feb 16, 2020
    yes it should be repaired if you go to the place of purchase, as long as the warranty is not voided
  16. Y.Singh
    Froyo Feb 16, 2020
    it depends on the problem. if it's a easy fix then they'll probably repair it and if it's hard to find the problems and is time consuming then they might just give you a new handset. depends on the problem though.
  17. AlizainAkber , via OnePlus 7T Pro Haze Blue , Feb 16, 2020 :
    ok so are you sure that my device is faulty right?
  18. Y.Singh
    Froyo Feb 16, 2020
    I cannot be sure as I don't personally have it but when comparing it to mine which is in good shape it does seem that there is a fault.
