36
Battery/Charging [UNIFIED] Battery and heating feedback thread OnePlus 7t pro
  1. Piotr_M , via OnePlus Nord Blue Marble , Nov 26, 2020 :
    Hi,
    Same issue here.
    OnePlus Nord 8GB RAM, Oxygen OS 10.5.9.AC01BA, Gallery app v. 3.13.5.
    Attaching screenshots that show high battery drain by Gallery app.
    My friend with OnePlus Nord 12 GB RAM doesn't have this issue.
    Turned off Gallery app for good and I'm using Google Photos - huge difference with battery life.
    Cleared app cache, but it didn't help.
    We need to wait for app or OS update?
  2. Bittoo06
    Ice Cream Sandwich Nov 26, 2020
    Bittoo06 , via OnePlus Community App , Nov 26, 2020 :
    Hey! Thanks for choosing my answer as the best one! 🤩🙌🏼
  3. Piotr_M , via OnePlus Nord Blue Marble , Nov 26, 2020 :
    Hey,
    I can find where I can force stop Gallery app, but I don't know where I can find option to choose not to run in background.
  4. chandrahaas02
    Eclair Nov 26, 2020
    chandrahaas02 , via OnePlus 7T Pro , Nov 26, 2020 :
    But gallery doesn't have option to not run in bsckgroud
    Piotr_M likes this.
  5. Bittoo06
    Ice Cream Sandwich Nov 27, 2020
    Bittoo06 , via OnePlus Community App , Nov 27, 2020 :
    Oh ho! You need to clear in background and freeze the app so that it doesn't runs in the background. 🥴
  6. Piotr_M , via OnePlus Nord Blue Marble , Nov 27, 2020 :
    By freze you mean turn it off, right? That you can't use it at all?
    That's what I did and using Google Photos since then (way better battery lifespan).
    chandrahaas02 likes this.
  7. ZumodeVidrio
    Cupcake Dec 13, 2020
  8. Q1574791276623
    Cupcake Dec 15, 2020
  9. TrillyReign
    Cupcake Dec 23, 2020
    TrillyReign , Dec 23, 2020 :
    Hello everyone!
    First of, thank you too anyone who helps. I appreciate the support & community. It's one of my favorite things about OnePlus.
    That being said, the default launcher keeps draining my battery, even though I'm not using it. I'm using Nova Launcher, and I have data usage turned off for the default launcher. After a full days use, it'll show up at anywhere from 5% - 13% in the battery usage details. I know it's not a huge amount, but definitely more than it should be, and I'm very busy. I use my phone ALOT, so any battery that can be saved is very much appreciated. (I even keep my sensors off unless I need them)
    I've had my OnePlus 7T Pro for a while now, but for some reason I'm always having an issue with the default launcher. I couldn't find any other threads with this issue, so I hope it's okay I created a thread.
    And again, thank you to anyone who may have a fix.
    Oh, and yes, I've updated it, cleared the storage, force stopped it, etc. Sadly, nothing worked in that department.
    MRTLima likes this.
  10. andybirkett76
    Cupcake Dec 31, 2020
    andybirkett76 , Dec 31, 2020 :
    So is there no way to stop Gallery running in the background other than to disable it completely? I want to use it but I don't want my battery ruined. For some reason it's also missing from the list of 'all apps' for battery optimisation.
  11. manas paul
    Cupcake Jan 3, 2021
    manas paul , Jan 3, 2021 :
    I am using one plus from the beginning (OP3, OP5t, OP7) of one plus device. Currently, I'm using OP 7t Pro Mclaren edition but I'm not happy with the battery performance of this device. It's only 7 months old but the battery lasts only 14 hours of rarely used (only call and browsing).
  12. mobilography_ru likes this.
  13. ZGOD
    Cupcake Jan 21, 2021
  14. MRTLima
    Lollipop Jan 31, 2021
    MRTLima , via OnePlus 7T , Jan 31, 2021 :
    My OP 7T is going ok. I've nothing to claim about.
    E1611185682951 likes this.
  15. Louisbaecke510
    Honeycomb Feb 1, 2021
  16. Louisbaecke510
    Louisbaecke510 , Feb 1, 2021 :
    since 12/11/2020 i have me oneplus 7T Pro and he is not that old but he drain very quick on 90hz and fhd and its a bit strange look at me pictures so i ask oneplus fix it pls Screenshot_20210104-003345.jpg Screenshot_20210104-003347.jpg
    TrillyReign likes this.
  17. OALEXANDER likes this.
  18. OALEXANDER
    Assistant Head Moderator Assistant Head Moderator Feb 1, 2021
  19. timoantimo
    Donut Feb 6, 2021
    timoantimo , Feb 6, 2021 :
    Hello! So my battery performance is so bad... I don't know if a factory reset will help or no... But have a look at the below screenshots and tell me ur options. Thank you.
    Oxygen os : 10.0.7. HD01AA - Android 10
  20. the_o2
    OnePlus 9 Series Expert Community Expert Feb 7, 2021
    the_o2 , Feb 7, 2021 :
    You battery is healthy and almost perfect condition according to first screenshot,
    Why don't you update to latest version
    https://forums.oneplus.com/threads/oxygenos-10-0-14-and-10-3-8-india-for-the-oneplus-7t-pro.1385197/
    Bobbie63 and Dresa91 like this.
