36
Battery/Charging [UNIFIED] Battery and heating feedback thread OnePlus 7t pro
  1. erinjacob87 likes this.
  2. SMRasel
    Froyo Apr 9, 2021
  3. rolleroo
    Gingerbread Apr 28, 2021
    rolleroo , via OnePlus 7T Pro , Apr 28, 2021 :
    Lol, this could be the most useless sinkhole thread I have ever read, 740+ posts. Is there anything useful in here? Or should I just bin the 7t pro and go get another phone?
  4. flither
    Gingerbread Apr 29, 2021
    rupankardey13 likes this.
  5. rupankardey13
    rupankardey13 , via OnePlus 7T Pro , Apr 29, 2021 :
    Already roll backed to os 10 , battery was worst on Os 11 which need further optimization
    flither likes this.
  6. Q1590654522545
    Cupcake May 9, 2021
    Q1590654522545 , May 9, 2021 :
    try enabling developer mode : settings > about phone > click on android version 7 times.
    then go to settings > system > developer option > apps select these options from there, these may help "Don't keep activities" (checked), Background process limit (1 or 2 may be), my assumption is the background process runs and drains the battery.
    also in settings > system > developer option > Networking > enable "Wifi scan throttling" disable "Tethering hardware acceleration" and disable "Mobile data always active"
    maybe these two will help the issue, but still Oneplus needs to pay some attention to their battery.
  7. B1581241913448
    Cupcake May 12, 2021
    S1583694483935 and nassir05 like this.
  8. nassir05
    Donut May 16, 2021
  9. kamtapr
    Cupcake May 18, 2021
  10. KluGe
    Lollipop May 18, 2021
    KluGe , May 18, 2021 :
    Use Search!
    Read the forum rules!
    Do not create redundant and therefore useless new threads!
    Thank you for your forum pollution!
  11. george.shady , via OnePlus 7T Pro Haze Blue , May 24, 2021 :
    I recently updated mt 7t pro to OxygenOs 11 and had 0 problems. Until 3 days ago when the battery of my phone has been dropping drastically in comparison to before. My phone went from 6-7 SOT to 3-3,5 SOT, with my same usual consumption. It's really getting on my nerves. Can't even get to the evening without having to fill it up again for the last 4 days.
    I've checked my apps, updated them all, made sure I'm on thr latest OS update and even restarted the phone a couple of times. Nothing seems to solve the problem.
    Please let me know how to get rid of the problem.
    I need your feedback so bad 🙏🙏
  12. varunpilankar
    Froyo May 24, 2021
  13. george.shady , via OnePlus 7T Pro Haze Blue , May 24, 2021 :
    Yeah I know. But the thing is I upgraded to 11 like over a month ago and everything was fine and I had no problems. They appeared only 3 days ago
  14. varunpilankar
    Froyo May 24, 2021
    varunpilankar , via OnePlus 7 , May 24, 2021 :
    I can understand.. Some users are facing problems immediately and some are facing it later.. But it's only happening on Android 11.
    Even i faced the issue after couple of weeks on my new device.. Fixed by getting back to 10
    george.shady likes this.
  15. ghostofcain
    Marshmallow May 24, 2021
    ghostofcain , May 24, 2021 :
    No we aren't.
    Sounds like it's an app gone rogue, I'd visit the pinned battery threads for some pointers on identifying the app and dealing with it.
  16. varunpilankar
    Froyo May 25, 2021
    varunpilankar , via OnePlus 7 , May 25, 2021 :
    He can try running BBS to determine the app's going rouge.. This can be done by full charge your device and let BBS running until your battery drops below 15%
  17. A1577286855911
    Cupcake May 25, 2021
    A1577286855911 , via OnePlus 7T , May 25, 2021 :
    Can you please explain how we can uninstall the update 11 and back to 10 ???
  18. varunpilankar
    Froyo May 25, 2021
    1. Download the Oxygen OS build OTA for your phone either from Oneplus support page or xda - 10 latest is recommended but if you prefer any other.. No problem. Just make sure it is a full build.
    2. Place the OTA into your root folder of your device.
    3. Charge your phone, at least keep the battery above 70%
    4. Go to settings --> System --> System updates --> Gear setting --> local updates, select the OTA file to manually update.
    4. Press start and wait to finish! And reboot
    Caution - Downgrading formats your phone, so make sure you take a backup of your data before downgrading.
    A1577286855911 likes this.
  19. george.shady , via OnePlus 7T Pro Haze Blue , May 25, 2021 :
    Thank you for your help, but what's BBS?😁
