21
[UNIFIED] Battery and heating feedback thread OnePlus 7t
  1. Y1570643667340
    Donut Nov 19, 2019
    Y1570643667340 , Nov 19, 2019 :
    should I Stop using my phone noww?? so annoying..even after updates no improvement in the battery life. its so difficult to work like this
  2. Z1574263595582
    Cupcake Nov 20, 2019
  3. D1572406744864
    Eclair Nov 20, 2019
    D1572406744864 , via OnePlus 7T , Nov 20, 2019 :
    i am using one plus 7t from last 20 days i was not happy with battery backup of this phone i got recent update 10.6 i thought there will be some improvement in battery life but no total screen usage i am getting in full charged only 5 hours my friend who have one plus 6 they are getting more tha. 10 hours of screen usage in single charge did i spent 38k for this device ...i am very very disappointed. see this 2 hours 42 minute since it was fully charged and 50 percentage of battery gone total i will run 5 hours only.
    Kinuta likes this.
  4. O1573856371230
    Cupcake Nov 21, 2019
    O1573856371230 , Nov 21, 2019 :
    My battery is really bad...can barely get 5 hours of screen time. It's updated to the latest Android. What to do?
  5. Ketan_jn
  6. kirahvi27
    Froyo Nov 21, 2019
    kirahvi27 , Nov 21, 2019 :
    I get constantly over 6-7 hours even with 1 hour of playing PokemonGo. Mostly reddit and youtube videos with a bit of surfing with chrome. I have data and bluetooth constantly on with 90hz and automatic brightness. Check what apps are draining your battery and uninstall them. If you chose to use FB or similar apps then thats on you.
    J1573983549232 likes this.
  7. qualin
    Eclair Nov 21, 2019
    qualin , Nov 21, 2019 :
    battery life depends what u do on phone, what apps are installed z what games u play, how strong signal u have, how many sims u use etc etc
    i have always minimum 24h battery life and 6-8h od sot. my record battery life is 44h with standard usage, and max sot i had was 9h.
    Kethrildur likes this.
  8. rahulkr13
    Eclair Nov 22, 2019
    rahulkr13 , via OnePlus 7T , Nov 22, 2019 :
    The battery on 7T is very disappointing. I already regret making the purchase. Suggestions like using the 60hz defy the whole purpose of going with 7T. Less than 4 hours SOT is well below expectations. Moreover, OnePlus is not addressing this issue at all.
  9. D1572406744864
    Eclair Nov 22, 2019
    D1572406744864 , via OnePlus 7T , Nov 22, 2019 :
    i only use one sim card i dont play game....then aslo it's maximum 5:30 minutes sot i got till date
  10. mohammed2501
    Cupcake Nov 22, 2019
    mohammed2501 , via OnePlus 7T , Nov 22, 2019 :
    These are the best battery life i get with 90Hz with 15% left. 7 hours with gaming and battery consuming apps like Duo. 60Hz i get more than 8 hours SOT. 1574441863643.jpg
  11. D1572406744864
    Eclair Nov 22, 2019
  12. D1572406744864
    Eclair Nov 22, 2019
    Yes only getting 4 hours of scren usage at 69 hz display rate no hame play..
  13. D1572406744864
    Eclair Nov 22, 2019
    same here
  14. Z1573828598844
    Donut Nov 22, 2019
  15. Boya_Vinod_Kumar
    Cupcake Nov 23, 2019
    D1572406744864 likes this.
  16. Mambobuzzz
  17. D1572406744864
    Eclair Nov 23, 2019
  18. Z1573828598844
    Donut Nov 23, 2019
  19. D1572406744864
    Eclair Nov 23, 2019
  20. Sheppards
    Donut Nov 23, 2019
    Sheppards , Nov 23, 2019 :
    Some hints
    - disable wi-fi scanning
    - disable bluetooth scanning
    - disable "scanning always available"
    - disable NFC (I personally don't use it)
    - only enable bluetooth when really using it
    I'm getting at least ~30 hours of standby and at least ~ 6 hours of screen on time at all times.
