21
[UNIFIED] Battery and heating feedback thread OnePlus 7t
  1. pablofg1978
    Spanish POC Assistant Head Moderator Nov 29, 2019
    pablofg1978 , Nov 29, 2019 :
    You are comparing brands to a particular model.
    malidan likes this.
  2. Topper_Gas
    Jelly Bean Nov 29, 2019
    Topper_Gas , Nov 29, 2019 :
    Nonsense the latest SoC's are supposed to be more efficient. OP seem to have issues with battery management on all their recent devices, they've never fixed the high battery drain on the OP3 before making it EOL. I sense they've now got to many devices and to few soft ware engineers to cope.
    G_Ayush_Bhatia_pIUB and malidan like this.
  3. pablofg1978
    You are totally wrong
  4. Slatter191
    Lollipop Nov 29, 2019
    Slatter191 , Nov 29, 2019 :
    I have similar ideas.
    Better batt management and lesser drain.
    But since your a mod, so must be correct...
    malidan likes this.
  5. malidan
    Marshmallow Nov 29, 2019
    malidan , Nov 29, 2019 :
    Not If you have a superior management and Kernel, which is the case with Samsung and Huawei
    They run way more and still have the speed and endurance.
    IPhones also prove that by doing great thing with smaller batteries and superior dev support.
  6. pablofg1978
    Spanish POC Assistant Head Moderator Nov 30, 2019
    pablofg1978 , Nov 30, 2019 :
    I'm not comparing different soc's, brands or phones, just comparing a mid range soc with a top line soc, same brand same generation. A more faster, powerfull soc will spend more energy (on full and same load).
  7. G_Ayush_Bhatia_pIUB , via OnePlus 7T , Nov 30, 2019 :
    when i switch off my phone and then on it the battery back up and screen on time increases very much almost2-3 hrs but when i use for days without switching it off the battery drains fast and screen on time decreases too
  8. malidan
    Marshmallow Nov 30, 2019
    malidan , Nov 30, 2019 :
    Oh so you're talking about on paper, really?
  9. pablofg1978
  10. malidan
    Marshmallow Dec 1, 2019
    malidan , Dec 1, 2019 :
    But SOC is not used on paper, there is no way of knowing what running the same program will produce without hardware attached.
    The junior SOC is produced to offer lower performance so if you pushed a 700 series using the same hardware as a 800 series and match the performance, it would lose as the 800 will be running well within itself.
    I always found on the motorway running a 2ltr and a 1-1.4 ltr at 80mph+ the 2.0L always produced more MPG, as you had gone well past the sweet spot of the inferior engine.
  11. J1575146937520
    Cupcake Dec 1, 2019
  12. rahulkr13
    Eclair Dec 2, 2019
    rahulkr13 , via OnePlus 7T , Dec 2, 2019 :
    I visited the service center because my 7T was dropping wifi connectivity when connected on 5 ghz channel. Their solution was to reset the phone to the factory settings i.e. to install the os with which the device came. I think that was 10.0.4. The funny thing, ever since that reset and updating to the latest 10.0.6 my battery lasts for almost 7 hours SOT
  13. Nikhil_Kashid
    Froyo Dec 3, 2019
    Nikhil_Kashid , Dec 3, 2019 :
    what was your SOT before resetting and then updating?? because i think if your method works then everyone needs to hear this, because our SOT is below average. it lasts only upto 4.5 hrs which i way to less.
  14. rahulkr13
    Eclair Dec 3, 2019
    rahulkr13 , via OnePlus 7T , Dec 3, 2019 :
    This was before the people at the service center reinstalled the OS completely.
  15. V Rajender
    Cupcake Dec 4, 2019
    V Rajender , Dec 4, 2019 :
    Wait for update
  16. V Rajender
    Cupcake Dec 4, 2019
  17. P1575130125627
    Cupcake Dec 5, 2019
    P1575130125627 , Dec 5, 2019 :
    Hi Team,
    I purchased this phone on 30th Nov from amazon. but I found battery drianing at very fast rate.
    earlier I installed number of application.but I tested it by even after factory reset and using only YouTube..I am not comfortable with the battery performance.
    even i haven't use any sim.so battery performance is far below the expectation.
    please refer the screenshot of battery using YouTube over WiFi (post factory reset).
    also I am requesting you to please suggest how can in replacement this with good phone (as I purchased it under 10 day replacement from amazon.in)
    please help.
  18. arunsagarsk
    Cupcake Dec 8, 2019 at 9:04 AM
  19. G_Van_Hauwermeiren_Steve
    Cupcake Dec 9, 2019 at 10:03 AM
    G_Van_Hauwermeiren_Steve , Dec 9, 2019 at 10:03 AM :
    Hi,
    Can you tell how you managed to get such a high "screen of usage"?
    Thx
