64
[UNIFIED] Battery and heating feedback thread OnePlus 7t
  1. Slatter191
    Lollipop Nov 28, 2019
    Slatter191 , Nov 28, 2019 :
    7T gives on an average 6 hrs SOT, while my RNs infinix S5, a 150 $/ gives 10-11 hrs SOT on a 4,000 mah... With low grade hardware, CPU, GPU 4 gigs of RAM and a bloated stock ROM?
    Any ideas why 7T with top hardware gives half the SOT?
    Thanks!
  2. pablofg1978
    Nougat Head Moderator Nov 28, 2019
    pablofg1978 , Nov 28, 2019 :
    Which car do you think that will spend more gasoline? A Ferrari 812 Super fast or a fiat 500?
  3. Slatter191
    Ofcourse a Ferrari.
    But I assumed that a 855 CPU, Adrenal 640, Andriod Pure ROM, 8 gigs would consume lesser batt drain along with performance...
    Huawei series P30, Mate20/30 Pro/ 5G are far more batt efficient and have equivalent if not faster than 7Ts hardware...
    malidan likes this.
  4. pablofg1978
    Faster and more powerful soc will only consume more battery.
  5. Slatter191
    Lollipop Nov 29, 2019
    Slatter191 , Nov 29, 2019 :
    Agreed.
    But IYO, Huawei, Xiaomi, iPhone are fiats vs OP7T a Ferrari?
  6. saurav.v12
    Eclair Nov 29, 2019
    saurav.v12 , Nov 29, 2019 :
    Thanks for sharing your views! I still have the battery issues :( Lets see
  7. pablofg1978
    Nougat Head Moderator Nov 29, 2019
    pablofg1978 , Nov 29, 2019 :
    You are comparing brands to a particular model.
    malidan likes this.
  8. Topper_Gas
    Jelly Bean Nov 29, 2019
    Topper_Gas , Nov 29, 2019 :
    Nonsense the latest SoC's are supposed to be more efficient. OP seem to have issues with battery management on all their recent devices, they've never fixed the high battery drain on the OP3 before making it EOL. I sense they've now got to many devices and to few soft ware engineers to cope.
    G_Ayush_Bhatia_pIUB and malidan like this.
  9. pablofg1978
    You are totally wrong
  10. Slatter191
    I have similar ideas.
    Better batt management and lesser drain.
    But since your a mod, so must be correct...
    malidan likes this.
  11. malidan
    Nougat Nov 29, 2019
    malidan , Nov 29, 2019 :
    Not If you have a superior management and Kernel, which is the case with Samsung and Huawei
    They run way more and still have the speed and endurance.
    IPhones also prove that by doing great thing with smaller batteries and superior dev support.
  12. pablofg1978
    Nougat Head Moderator Nov 30, 2019
    pablofg1978 , Nov 30, 2019 :
    I'm not comparing different soc's, brands or phones, just comparing a mid range soc with a top line soc, same brand same generation. A more faster, powerfull soc will spend more energy (on full and same load).
  13. G_Ayush_Bhatia_pIUB , via OnePlus 7T , Nov 30, 2019 :
    when i switch off my phone and then on it the battery back up and screen on time increases very much almost2-3 hrs but when i use for days without switching it off the battery drains fast and screen on time decreases too
  14. malidan
    Nougat Nov 30, 2019
    malidan , Nov 30, 2019 :
    Oh so you're talking about on paper, really?
  15. pablofg1978
  16. malidan
    Nougat Dec 1, 2019
    malidan , Dec 1, 2019 :
    But SOC is not used on paper, there is no way of knowing what running the same program will produce without hardware attached.
    The junior SOC is produced to offer lower performance so if you pushed a 700 series using the same hardware as a 800 series and match the performance, it would lose as the 800 will be running well within itself.
    I always found on the motorway running a 2ltr and a 1-1.4 ltr at 80mph+ the 2.0L always produced more MPG, as you had gone well past the sweet spot of the inferior engine.
  17. drogueaf
    Cupcake Dec 1, 2019
    drogueaf , Dec 1, 2019 :
    Just for the records , I believe problem has been solved with WhatsApp version .341 . At least in OP5T.
    ssaisreenivas likes this.
  18. akshaygiridhar28
    Eclair Dec 1, 2019
    akshaygiridhar28 , via OnePlus 7T , Dec 1, 2019 :
    Hey there i ws having the same issue for 2/3 days and i think i might found the solution for it.
    * Go to setting > Battery > Battery Optimisation
    Here you could see all the apps are on Intelligent Control by default
    *Change it to Optimise one by one (Which ever you think you don't want it to be running on background).
    And change it your refresh rate to 60hz if you want to.
    By doing all this brought me back to 6+ hours SOT(Screen On Time).
    Hope this will help you as well!
    Thank you!
    Muhammad.Musa and ssaisreenivas like this.
  19. ssaisreenivas
    Eclair Dec 1, 2019
    ssaisreenivas , Dec 1, 2019 :
    Thanks Bro!, nice to see people comming up with solutions of the same issues i have in mine!
    akshaygiridhar28 likes this.
