67
[UNIFIED] Battery and heating feedback thread OnePlus 7t
  1. sathishblue
    Donut Apr 13, 2020
    sathishblue , via OnePlus 7T , Apr 13, 2020 :
    After the recent update, battery draining very fast, my SoT is 4hrs only. Previously it was 5 and half hours. Am using 7T. Heating is also there.
    Nilesh bajaj26 likes this.
  2. mikep7
    Eclair Apr 13, 2020
    mikep7 , Apr 13, 2020 :
    Hey, WiFi and Bluetooth scanning were already disabled, but I also disabled location accuracy right now. This is making me sick no idea what might cause this issue.
  3. Sheppards
    Ice Cream Sandwich Apr 13, 2020
    Sheppards , via OnePlus 7T , Apr 13, 2020 :
    Sure, I'd be pissed too.
    Did you try battery saver?, if I remember correctly, it will stop background apps. This should help you to find that rouge app that kills your battery.
    It will 99% be an app that eats your battery.
  4. mikep7
    Eclair Apr 13, 2020
    Do You mean OnePlus battery save mode to be enabled manually? No I didn't try it. I'll set this enabled for next night.
    Sheppards likes this.
  5. mikep7
    Eclair Apr 14, 2020
    mikep7 , Apr 14, 2020 :
    Hello I'm surprised but with manually enabled battery saver result is the same over 1.1% / h and over 11 % in almost 10 hours.
  6. H1574995089589
    Donut Apr 14, 2020
  7. Sheppards
    Ice Cream Sandwich Apr 14, 2020
    Sheppards , via OnePlus 7T , Apr 14, 2020 :
    That's interesting. Does the phone do the same with a fresh install? Either you kill all background apps with the app info screen for every app, or do a factory reset and check that way.
    I would rule out the rouge app eating the battery...
  8. yashwanthshetty
    Cupcake Apr 14, 2020
  9. Cervantes
    Lollipop Moderator Apr 14, 2020
    Cervantes , Apr 14, 2020 :
    Hi
    Please, check and use this thread for all battery questions
    Use the search engine before opening a new thread
    Thread merged
  10. Cervantes
    for another user to suggest: upload a screenshot of:
    battery and other
    battery uses
  11. G_Haddin_Sisodia_CCzl
    CHANDAN018 likes this.
  12. mikep7
    Eclair Apr 14, 2020
    Hard to say I think it was better before something around 3% per night.
    Tell me why BetterBatterStats does not show what is causing issue? This is crazy.
    Look at sensors how it's possible 19 hours and what is that process ( 9:49 time since disconnected )? Also why Netflix and Google Play use sensors?
    Sheppards is there any way to force stop all apps - not one by one? I did it manually but it's lot of work...
    UPDATE: I've attached second screenshot with details of that Sensors with interesting pickup / pocket name. I've also disabled AOD ( lift ) now and lift up for answer the phone or turn screen down to reject call.
  13. Madnezz4Ever
    Jelly Bean Apr 14, 2020
    Madnezz4Ever , via OnePlus Community App , Apr 14, 2020 :
    It's normal for a cell phone to become hot as like any other electronic device it's internals will heat up and there's not much to cool them off.
    There fans on a computer for a reason, but unfortunately a phone can't have them.
    You can try adjusting your phone settings, game settings and not use it for such a long period big time.
    Also make sure no apps are over using the CPU.
  14. shalin12
    shalin12 , Apr 14, 2020 :
    to changing my phone into lower settings... for what iam owning oneplus7t ?
  15. Madnezz4Ever
    shalin12
    To reduce heat?? It doesn't matter what phone you own, they all produce some heat and the more powerful your phone is the more the heat that needs to be transfered.
    If your phone is using a lot of the CPU/GPUfor whatever reason, expect a lot of heat.
  16. mikep7
    Eclair Apr 15, 2020
    mikep7 , Apr 15, 2020 :
    Success! I got tonight 2% per 10 hours so it's around 0.2%/h. Earlier battery usage has to be related to AOD/pickup sensor. Now I wonder if this is normal ( ~1.1%/h ) or this is issue with my phone, because AOD was enabled all time and I had good battery drops earlier. Total drop is 8% ( from 93% ) in 17 hours but phone was used before night, when I was going sleep it was 87%.
  17. Sheppards
    Ice Cream Sandwich Apr 15, 2020
    Sheppards , via OnePlus 7T , Apr 15, 2020 :
    mikep7
    Success! I got tonight 2% per 10 hours so it's around 0.2%/h. Earlier battery usage has to be related to AOD/pickup sensor. Now I wonder if this is normal ( ~1.1%/h ) or this is issue with my phone, because AOD was enabled all time and I had good battery drops earlier. Total drop is 8% ( from 93% ) in 17 hours but phone was used before night.​
    AOD? IS this a 3rd party app? The 7 doesn't have it by default
  18. Sumanth1771 likes this.
  19. R1520450246492
    Cupcake Apr 16, 2020
    R1520450246492 , via OnePlus 7T , Apr 16, 2020 :
    Battery drains quite early even after very less use or sometimes when phone is just on rest... The moment I open any app and start browsing there's a drop in battery like very immediately...
    SOT at 60hz- 1hr 12 mins
  20. mikep7
    Eclair Apr 16, 2020
    mikep7 , Apr 16, 2020 :
    7T and sorry of course I wrote wrong name i meant Ambient Display - this is that notification screen with time when You lift up device. So far is great 2 days on battery ( currently 70% ) - 6 days ETA and average power consumption 0.5% per hour, at night 0.2% per hour.
