67
[UNIFIED] Battery and heating feedback thread OnePlus 7t
  1. Ni3_chavan likes this.
  2. skv_sajal
    Cupcake Apr 18, 2020
  3. souvikdutta0728
    Cupcake Apr 19, 2020
    souvikdutta0728 , via OnePlus 7T , Apr 19, 2020 :
    dear concern
    I'm using OnePlus 7th 8gb and 256gb variant since 1st Jan,2020.
    in initial days I was quite happy about this device regarding looks camera and mostly for battery back-up
    it's almost 4moths after I'm facing huge issue in battery backup.
    in a day where as I had to charge only once but now days I have charge it twice .
    I was in touch with OnePlus whatsapp assistance and they have guided me very well but the problem is remain same.
    kindly advise.
    -Souvik Dutta
  4. lifelight
    Cupcake Apr 20, 2020
    lifelight , Apr 20, 2020 :
    Good morning community!
    I have a simmilar problem to report. Since the last 4 battery charges (charging in the late evenings to 100%) the device looses about 15% battery while beeing in aeroplane mode overnight without any usage after unplugging from the charger. The amount of lost energy is not displayed in the battery consumption at all.
    Does anyone around experienced the same issue? Is this probably a software topic? As the device is in use since ~6month (and I am clearly not a power user - I usually go like 6 days) this should not be a battery hardware problem itself I guess.
    Really thankful for any feedback!
    Device: 7T
  5. R1520450246492
    Cupcake Apr 21, 2020
    R1520450246492 , via OnePlus 7T , Apr 21, 2020 :
    Even I'm facing the same problem... Will you please help in getting touch with OnePlus WhatsApp assistance
    souvikdutta0728 likes this.
  6. souvikdutta0728
  7. R1520450246492
  8. fawasac
    Cupcake Apr 22, 2020
    fawasac , Apr 22, 2020 :
    After 10.3.2 update phone is heating up while charging. Is it a common issue?
  9. I1521367172935
    I1521367172935 , Apr 22, 2020 :
    I have just used screen for 3hr 16min but my battery used is 70%. that is nearly 5hr for full charge. idk the reasons for its reduce in efficiency
  10. I1521367172935
    even I'm facing the same issue
  11. skv_sajal
    Cupcake Apr 23, 2020
  12. I1521367172935
    I1521367172935 , Apr 23, 2020 :
    I just turned out on not like I use it all the time
  13. skv_sajal
    I1521367172935 likes this.
  14. pscsuganth , via OnePlus 7T Glacier Blue , Apr 25, 2020 :
    my oneplus 7t is getting heated too much daily..
    when i use to pick my mobile the temperature is above 43°c
    while using any application the temperature is increasing more than 44°c
    I can't handle my mobile now a days
    pls help me to decrease the temperature...
  15. Cervantes
    Lollipop Moderator Apr 25, 2020
    Cervantes , Apr 25, 2020 :
    Hi
    Please, check and use this thread for all battery questions
    for another user to suggest: upload a screenshot of:
    battery and other
    battery uses
    Install cpuz
    Use the search engine before opening a new thread
    Thread merged
  16. GAMERSHIV
    Cupcake Apr 27, 2020
    GAMERSHIV , Apr 27, 2020 :
    Phone's Heating too much,I can't even hold the phone
    Just by playing Pubg.
    I play Pubg on HD graphics and Extreme Frame Rate
    Refresh Rate:60Hz
  17. GAMERSHIV
    Can you explain this please..
    Within 3hrs my One Plus 7T battery goes down from 100 to 2.
    Refresh Rate:60Hz
  18. nishtha kapoor
    Cupcake May 1, 2020
    nishtha kapoor , May 1, 2020 :
    hi, in the past week, i experienced it twice that while using my phone which is oneplus 7T, it suddenly switched off and got restarted on it's own. i hope someone can help me out with this.
    thanks
  19. JorgeBoscan
    Eclair May 1, 2020
    JorgeBoscan , May 1, 2020 :
    Hi all.
    Wipe cache of the Google Play Services and also wipe cache of the System via Power button + volume down. It worked for me!
  20. Ni3_chavan , via OnePlus 7 Mirror Gray , May 1, 2020 :
    plz tell me Which Phone are you using ?
    and does heating while charging issue solved?
