64
[UNIFIED] Battery and heating feedback thread OnePlus 7t
  1. K1576848002565
    Cupcake May 22, 2020
  2. Ravindra Engle
    Cupcake May 27, 2020
    Ravindra Engle , May 27, 2020 :
    Purchased Oneplus 7T after a week of usage im still seeing 4hours of SOT. Worst battery. Oneplus you listening Battery draining Concerns mentioned here ?
  3. Vineet_Kumar_OP
    Froyo May 28, 2020
    Vineet_Kumar_OP , via OnePlus 7T , May 28, 2020 :
    Battery backup is poor, Heating issues are major. Help request from Team OnePlus. Software optimization is the only way to do so. Sometimes device heats upro 47 degrees. Screen on Time is only 3-4Hours.
    Ni3_chavan likes this.
  4. Ni3_chavan , via OnePlus 7 Mirror Gray , May 28, 2020 :
    Yess
    I am too expecting in software update
    Vineet_Kumar_OP likes this.
  5. C1570213607056
    Eclair May 30, 2020
    C1570213607056 , via OnePlus 7T , May 30, 2020 :
    i don't get 10.3.3 on my system update...and I don't have any kind of bug on my 7T so u should to download only system updater... don't download from op servers I think that's a right thing... server provide you beta updates only update from system update...
  6. N1580388597241
    Eclair May 31, 2020
  7. yashshrikant , via OnePlus 7T Glacier Blue , May 31, 2020 :
    I've tried accu battery ,better battery stats(XDA) and the inbuilt android battery stats.
    I faced these problems with these apps.
    accu battery doesn't work precisely. it doesn't account for some of the apps that cause heavy drain. I did a research and found out that the formula they use to calculate the battery estimates is pretty old too.
    as for better battery stats. it gets the job done ,but it doesn't give a detailed analysis of the apps which drain it.
    For the native android battery stats ,the main problem is it doesn't reset every time I charge the phone. it resets the stats only when I charge the phone to 100.
    is there any app which prevents all these issues and measures SOT accurately?
  8. NumberSix
    Honeycomb May 31, 2020
    NumberSix , May 31, 2020 :
    Not really any point in measuring the SOT if you aren't going to do it with a full battery.
  9. B_Wrath
    Nougat May 31, 2020
    B_Wrath , May 31, 2020 :
    If you want to check the screen usage time per app, why not use digital wellbeing? It does a pretty good job on accounting how much time you spend on an app. It is more or less the SOT in that app.
    Liehjan and tide1109 like this.
  10. HUZEFA07
    Cupcake May 31, 2020
    HUZEFA07 , May 31, 2020 :
    phone gets extremely heat up when i take videos in stable mode..did anyone get that issue?
  11. AbeyEJ
    AbeyEJ , May 31, 2020 :
    My 7T is heating when using Zoom or video streaming app on mobile data. Is that expected behaviour?
  12. Sumanth1771
    Donut Jun 2, 2020
    Sumanth1771 , via OnePlus 7T , Jun 2, 2020 :
    same here.. no need to go to service centre . they will say it is normal.. ONEPLUS should fix heating issue and battery issues
  13. B1591069105600
    Cupcake Jun 2, 2020
    B1591069105600 , Jun 2, 2020 :
    opened new 7t one hour ago.
    charged it and phone got heated up.
    using company provided case.
    charging for first time
  14. manoj.sv
    Eclair Jun 2, 2020
  15. jasmeet marwah
    Cupcake Jun 2, 2020
    jasmeet marwah , Jun 2, 2020 :
    update to the latest version, atleast 10.3.2
  16. Vineet_Kumar_OP
    Froyo Jun 3, 2020
    Vineet_Kumar_OP , via OnePlus 7T , Jun 3, 2020 :
    No. Its not as the battery has some cycles to get fully charged and discharged. So it's recommended to charge it form 15 to 90% to maintain a particular cycle. Lithium batteries in older days had a charging cycle of 500 times. Maybe this time they should have some improvements.
  17. manoj.sv
    Eclair Jun 3, 2020
  18. jasmeet marwah
    Cupcake Jun 3, 2020
    jasmeet marwah , Jun 3, 2020 :
    None
    Found worse video quality on 3rd party apps like snapchat in 10.3.3. I wish I could downgrade instead without data loss.
  19. Z1582086310886
    Froyo Jun 3, 2020
    Z1582086310886 , via OnePlus 7T , Jun 3, 2020 :
    Recently my OP7T Is Started Hanging by itself. any App gets open automatically and home screen gets hanged a little bit.
    One plus team kindly look into this matter and give me a proper solution.
  20. Cervantes
    Lollipop Moderator Jun 3, 2020
    Cervantes , Jun 3, 2020 :
    Hi
    what is the ambient temperature in your city
    for another user to suggest: upload a screenshot of:
    battery and other
    battery uses
    Install cpuz: thermal
    Use the search engine before opening a new thread
    Thread merged
