67
[UNIFIED] Battery and heating feedback thread OnePlus 7t
  1. umang___
    Eclair May 17, 2020
  2. swathikrishnavemula
    Gingerbread May 19, 2020
  3. vishnu@7444
    Cupcake May 20, 2020
    vishnu@7444 , May 20, 2020 :
    I have bought one plus 7t a week before .As everyone saying that battery of 7t is poor but in my case it's awesome. With sot of above 6 hrs and idle 10 hrs my phones battery lasts for 16 hra approximately. i am using dual sim with mobile data . Tips to save battery and give more backup
    Tip 1: Turn off Adaptive brightness
    Tip 2 : Turn off shelf in home screen
    Tip 3 : Turn off wifi and Bluetooth scanning in background
    Tip 4 : uninstall unnecessary Apps
    Tip 5 : use facebook lite app
    Tip 6: Use Dark wallpapers
    Tip 7 : use location services only when u need
    It will give u more backup even for heavy usage
  4. p.pavljasevic
    Froyo May 21, 2020
    p.pavljasevic , May 21, 2020 :
    i leave everything enabled, as this is a smrtphone, but you are right the batterylife is amazing
    U1586845268107 likes this.
  5. TheMechanic14794
    Cupcake May 21, 2020
  6. jasmeet marwah
    Cupcake May 22, 2020
    jasmeet marwah , May 22, 2020 :
    Awesome battery life on 7T
    Not even using dark mode, did a lot of calls(on duo and voice) that too on bluetooth. Used the most battery draining app snapchat for an hour still couldn't finish it's battery.
    On 90hz with wifi all day.
  7. K1576848002565
  8. JABIR5469
    Donut May 24, 2020
    JABIR5469 , May 24, 2020 :
    This is my 2nd flagship of OnePlus , I'm having heating issue with my oneplus 7t the phone starts to heat up while using whatsapp, Instagram,tiktok and tho the internet connection is strong but still while surfing it takes time my OnePlus 6 never heated up like this before and which leads to battery drain rapidly and sometimes apps doesn't load or after starting them they get stucked then I've to turn my phone off and restart it again and sometimes the lock screen doesn't work properly 😕
    please help to resolve this issue.
    shubham2670 likes this.
  9. Batman360
    Lollipop May 24, 2020
    harshil1903 likes this.
  10. Ravindra Engle
    Cupcake May 27, 2020
    Ravindra Engle , May 27, 2020 :
    Purchased Oneplus 7T after a week of usage im still seeing 4hours of SOT. Worst battery. Oneplus you listening Battery draining Concerns mentioned here ?
  11. Vineet_Kumar_OP
    Froyo May 28, 2020
    Vineet_Kumar_OP , via OnePlus 7T , May 28, 2020 :
    Battery backup is poor, Heating issues are major. Help request from Team OnePlus. Software optimization is the only way to do so. Sometimes device heats upro 47 degrees. Screen on Time is only 3-4Hours.
    Ni3_chavan likes this.
  12. Ni3_chavan , via OnePlus 7 Mirror Gray , May 28, 2020 :
    Yess
    I am too expecting in software update
    Vineet_Kumar_OP likes this.
  13. C1570213607056
    Eclair May 30, 2020
    C1570213607056 , via OnePlus 7T , May 30, 2020 :
    i don't get 10.3.3 on my system update...and I don't have any kind of bug on my 7T so u should to download only system updater... don't download from op servers I think that's a right thing... server provide you beta updates only update from system update...
  14. N1580388597241
    Eclair May 31, 2020
  15. yashshrikant , via OnePlus 7T Glacier Blue , May 31, 2020 :
    I've tried accu battery ,better battery stats(XDA) and the inbuilt android battery stats.
    I faced these problems with these apps.
    accu battery doesn't work precisely. it doesn't account for some of the apps that cause heavy drain. I did a research and found out that the formula they use to calculate the battery estimates is pretty old too.
    as for better battery stats. it gets the job done ,but it doesn't give a detailed analysis of the apps which drain it.
    For the native android battery stats ,the main problem is it doesn't reset every time I charge the phone. it resets the stats only when I charge the phone to 100.
    is there any app which prevents all these issues and measures SOT accurately?
  16. NumberSix
    Honeycomb May 31, 2020
    NumberSix , May 31, 2020 :
    Not really any point in measuring the SOT if you aren't going to do it with a full battery.
  17. B_Wrath
    Nougat May 31, 2020
    B_Wrath , May 31, 2020 :
    If you want to check the screen usage time per app, why not use digital wellbeing? It does a pretty good job on accounting how much time you spend on an app. It is more or less the SOT in that app.
    Liehjan and tide1109 like this.
  18. HUZEFA07
    Cupcake May 31, 2020
    HUZEFA07 , May 31, 2020 :
    phone gets extremely heat up when i take videos in stable mode..did anyone get that issue?
  19. AbeyEJ
    AbeyEJ , May 31, 2020 :
    My 7T is heating when using Zoom or video streaming app on mobile data. Is that expected behaviour?
  20. Sumanth1771
    Donut Jun 2, 2020
    Sumanth1771 , via OnePlus 7T , Jun 2, 2020 :
    same here.. no need to go to service centre . they will say it is normal.. ONEPLUS should fix heating issue and battery issues
