69
[UNIFIED] Battery and heating feedback thread OnePlus 7t
  1. Roger.T
    Ice Cream Sandwich Jul 3, 2020
    Roger.T , via OnePlus Community App , Jul 3, 2020 :
    I don't notice any difference...
  2. Shinjan_Saha
    Cupcake Jul 5, 2020
    Shinjan_Saha , Jul 5, 2020 :
    Today I have got the best battery backup of all times.
    I have got 8hrs of SOT and ended up with 20% battery after 38 hrs of charging. This is too good to believe by even me.
    Its at 60hz display and RAM boost off with sleep standby optimization on. Never switched on battery saver in these 38 hrs.
    Attaching screenshots for reference.
  3. venuvchowdary
    Cupcake Jul 5, 2020
    venuvchowdary , via OnePlus 7T , Jul 5, 2020 :
    After an update i am facing battery drain problem in oneplus 7t...before that it was good...but from last 10 days i am facing issue in battery backup
  4. Cervantes
    Lollipop Moderator Jul 5, 2020
    Cervantes , Jul 5, 2020 :
    Hi
    Please, check and use the battery thread for questions and comments, read the first post
    Use the search engine before opening a new thread
    Thread merged
  5. manoj.sv
    Eclair Jul 5, 2020
  6. B1591261717504
    Cupcake Jul 5, 2020
  7. AmauryDeco
    Cupcake Jul 7, 2020
    AmauryDeco , via OnePlus 7T , Jul 7, 2020 :
    Hi all,
    this night I was on airplane mode but I see that I still lose battery life (12% using battery savior + closing all the app).
    And when I look at the App, I have a "-5" app. Am I the only one with this app?
    Oxygen OS 10.0.11
  8. manoj.sv
    Eclair Jul 7, 2020
    manoj.sv , via OnePlus 7T , Jul 7, 2020 :
    hi ,
    -5 is hotspot. Generally hotspot uses more battery .
  9. AmauryDeco
    Cupcake Jul 7, 2020
    thank you for the feedback. And yes, I have to share data connection to have a good wifi to work. So now I understand. But I still don't know why in 8 hours, I lose 12% using airplane mode. Usually it is between 3 to 5.
  10. Tony_1302
    Cupcake Jul 8, 2020
    Tony_1302 , Jul 8, 2020 :
    I requested a repair from oneplus. They replaced the battery. The issue still remains. The phone has been factory reset aswell, and there is still a HUGE battery drain when idle. Battery will drain in 7 hours from 100% to 0%, even when i am not using the phone at all.
  11. N1580388597241
    Eclair Jul 8, 2020
  12. E1592075720738
    Cupcake Jul 8, 2020
  13. C1579486966477
    Cupcake Jul 9, 2020
  14. Tony_1302
    Cupcake Jul 10, 2020
    Tony_1302 , Jul 10, 2020 :
    My Oneplus 7T's battery is draining very fast. In standby mode, about 15% in an hour. When my phone is turned off overnight, the battery can drain from 60% all the way to 0%.
    I have sent in my phone for repair by oneplus, where they replaced the battery and due to 'slow charging.' The issue still remains, and even after a factory reset, the phone still loses huge amounts of percentage (~ 60%) overnight even when the phone is turned off.
    Does anyone have any tips or know what the reason may be, or what next steps i should take? Is it a software bug or a hardware fault (even though the battery got replaced?)
  15. Sam1093
    Sam1093 , Jul 10, 2020 :
    I had the same problem. Updated my Oneplus 7T to Oxygen 10.0.11 and the battery got worse. Before it could last approximately 48 hours with 5/6 hours sot. After this update the battery can only last 24 hours with 2.5/3 hours sot. My phone was just a week old and I thought the problem was the phone, so I brought it back and got a new one. Now it's running on Oxygen 10.0.8 and it will last 48 hours again. So I think the problem is the new update.
  16. prajwal_.6
    Donut Jul 12, 2020
    prajwal_.6 , via OnePlus 7T , Jul 12, 2020 :
    Bro my phone is also heating in normal use age I don't know wt to do??? Any fix
  17. prajwal_.6
    Donut Jul 12, 2020
    Wt I do for my one plus 7t also gets heats up in normal useage ! Any fix or help please!!!!!!!
  18. prajwal_.6
    Donut Jul 12, 2020
    No bro after 10.3.3 my phone gets still heats up very quickly in normal useage bro am ****** ! I need a help
  19. prajwal_.6
    Donut Jul 12, 2020
    U luck bro ! My OnePlus 7t heats in 5 to 10 minutes ! I don't know wt to do ! I hate this phone right now because this is my new! Too!
