126
[UNIFIED] Battery and heating feedback thread OnePlus 7t
  1. SRD.
    Lollipop Aug 23, 2020
    SRD. , Aug 23, 2020 :
    Can you just share the screenshot of battery usage ?
    Setting> battery> view detailed usage
    dhigvijay77 likes this.
  2. PRADEEP RAVULAPATI
    Cupcake Aug 23, 2020
  3. Venkat1110
    Froyo Aug 23, 2020
  4. K1541271353410
    Cupcake Aug 24, 2020
  5. dhigvijay77
    Donut Aug 24, 2020
    dhigvijay77 , via OnePlus 7T , Aug 24, 2020 :
    Swatiranjan
    Setting> battery> view detailed usage​
    Here you go
    so this morning at 830 am my phone was at 99% percent and now as you can see it's at 45. i don't think this is normal.
    SRD. likes this.
  6. SRD.
    Lollipop Aug 24, 2020
    SRD. , via OnePlus 7T , Aug 24, 2020 :
    Your usage says you are not using any intensive apps which drains battery fast.
    19 hours is what you are getting in a single charge. What more is required. Actually Display resolution is another factor which consumes battery ( auto resolution consumes more battery than manual optimised resolution) I don't mind to keep it auto resolution though
    Still I would suggest you to use dark mode to increase battery mileage further.
    Setting> customisation > tone> dark mode
  7. SRD.
    Doesn't matter whether it's T mobile or something else, but it matters a lot if the network coverage is not good. ( The area through which you spend your day)
    Finding a stable network itself consumes huge battery.
  8. dhigvijay77
    Donut Aug 24, 2020
    Swatiranjan
    Setting> customisation > tone> dark mode​
    But my friend's and colleague's phones last an entire day even with heavy usage..I am not using heavy apps...so it doesnt make sense...and it won't last till 12 AM today ... and this is brand new phone...
  9. E1594476924572
    Eclair Aug 24, 2020
    E1594476924572 , Aug 24, 2020 :
    here is mine
    I played an half an hour call of duty, and it's ok for me
    dhigvijay77 and SRD. like this.
  10. dhigvijay77
    Donut Aug 24, 2020
    dhigvijay77
    Swatiranjan
    Here you go
    By the time this thread has progressed my battery had dropped by 4% it's at 42 now....
  11. dhigvijay77
    Donut Aug 24, 2020
    It's at 41 now..
    I would say one hour of continuous usage depleted 15 % battery at the very least.. no games as you can see..not many third party apps either. 1598264726990.jpg
  12. E1594476924572
    Eclair Aug 24, 2020
    if you dont play games, and do normal browsing or chatting then your screen on time will be like 3.5 - 4 hours with time since last charge will be like 16 hrs - 1 day
  13. dhigvijay77
    Donut Aug 24, 2020
    I see..will it improve over time?..
    should I drain it Fully and recharge for a couple of cycles ?
  14. E1594476924572
    Eclair Aug 24, 2020
    so once the charging cycle goes on it will come back to normal, if your sot is 4 hrs with 18 - 19 hrs since last charge then you need not worry,
  15. evns
    Cupcake Aug 25, 2020
    evns , Aug 25, 2020 :
    Same here. Draining the battery really quickly. I've tried disabling the app today to see if it helps (I use Google photos anyway)
  16. sambitGooner
  17. E1594476924572
    Eclair Aug 25, 2020
    E1594476924572 , Aug 25, 2020 :
    wait a few battery cycles, it should correct itself, otherwise do a factory reset, if that does not work, go to the service centre and do a software update.
  18. A1592641134815
    Froyo Aug 26, 2020
    A1592641134815 , Aug 26, 2020 :
    please note truth that battery of one plus 7t is only 18 to 19 hours with approximately 4 to 5 hr screen on time !!!
    I have wasted my 35 k in so caled flagship
    I have checked with accubattery and all other software it continuously drain battery in standby mode
    you will never get solution of battery drain Even at service centre!!!!!
    accept truth that you will use or don't use your phone but fully charged battery at morning will run up to evening only !!!!
    there are thousands of complain but they are not doing anything
    I have complained everywhere and now tired with battery issues !!!!
    Venkat0309 likes this.
  19. E1594476924572
    Eclair Aug 26, 2020
    E1594476924572 , Aug 26, 2020 :
    A1592641134815
    I have complained everywhere and now tired with battery issues !!!!​
    sot of 4 to 5 hours with 18 to 19 hours is normal, with 1 hr call of duty I get 5 hrs approx, which is ok for a 3800mah battery, and I got just 3.5 hrs for 24 hrs since last charge for normal usage which is ok. so if your sot is 4.5 to 5 hrs with 1 hr of gaming you are perfectly fine. so bottom line sot with gaming will be 4 to 5 hrs and normal usage you can extend upto 24 hrs with sot 3.5 hrs.
  20. E1594476924572
    Eclair Aug 26, 2020
    you have not wasted your 35k, it's just that the 3800mah dies early, the latest OnePlus 8 lasts a little longer due the 4300 mah battery with a rating of 108hrs in gsmarena, whereas as 7t has a rating of 90hrs, for me which is not a big deal.
