126
[UNIFIED] Battery and heating feedback thread OnePlus 7t
  1. E1594476924572
    Eclair Aug 26, 2020
    E1594476924572 , Aug 26, 2020 :
    my sot
  2. A1592641134815
    Froyo Aug 26, 2020
    A1592641134815 , Aug 26, 2020 :
    you can see the battery used by one plus 7t and other phone of 15k rs
    from images it can be seen that one plus continuously drain battery in sleep mode battery use by screen and in deep sleep is same 12 percentage
    while other phone of 15000 rs has 0 percentage battery use in deep sleep mode
    but moderator of one plus will not reply on all this problems
    now some one says the battery uses data is wrong but one data is of my wife's 15k phone and other is one plus 7 t 35 k phone
    one plus requested to solve severe battery drain issues of oneplus 7 t
    Venkat0309 likes this.
  3. A1592641134815
    Froyo Aug 26, 2020
    one phone of 15000 gives 3 hour sot in 27 percent battery use with 18 hour stand by and 0 percentage battery use in deep sleep !!!
    one plus 7 t will give 4 hour sot in 19 hour use consuming 80 percentage battery !!!
    hope one plus will solve these battery issues
  4. rashimkavel7
    Cupcake Aug 26, 2020
    rashimkavel7 , Aug 26, 2020 :
    sahi kaha
  5. K1574146284610
    Cupcake Aug 28, 2020
    K1574146284610 , Aug 28, 2020 :
    Same problem. Gallery consumed more than 80% of the battery.
    It's Strange as I rarely open a gallery in a day. It must be a system bug from the last update (10.3.4.HD65AA)
  6. Caomhin
    OnePlus 9 Series Expert Community Expert Aug 28, 2020
    Caomhin , via OnePlus 6T , Aug 28, 2020 :
    Clear the Gallery App info Cache and App info Storage as well
    See if that helps.
  7. Psychosis69
    Gingerbread Aug 28, 2020
  8. A1574888083062
    Cupcake Aug 29, 2020
    A1574888083062 , Aug 29, 2020 :
    didn't help me. I had to disable the app and use another gallery app.
  9. pramodpaluri
    Eclair Aug 30, 2020
    pramodpaluri , Aug 30, 2020 :
    yes I have battery issues as well. it drains fast on a little above average use. battery drains in no time.
    I guess message to android and OEMs is - we dont care about new and complex features in a smartphone , we just need good battery life , and simple features which consume less battery.
  10. sambitGooner
    Cupcake Aug 30, 2020
    sambitGooner , Aug 30, 2020 :
    this is the 10th day of using my new OP 7t. I have already done 5 battery cycles still the screen on time is not giving me more than 5 hrs. If playing pubg for an hour the battery drains completely within 3.5hrs screen on time.
  11. A1592641134815
    Froyo Aug 31, 2020
    A1592641134815 , Aug 31, 2020 :
    sir you will get only 5 hour screen on time
    please accept truth I believe I have wasted my money in this phone with very poor battery life
    I have complained everywhere but no one gives you response
    even 15 k rs phone has far better battery life than one plus 7 t
    more money less battery life !!!!
    pramodpaluri likes this.
  12. pramodpaluri
    Eclair Aug 31, 2020
    pramodpaluri , Aug 31, 2020 :
    I agree , I feel the same. battery life is not as expected.
    A1592641134815 likes this.
  13. D1528169082053
    Cupcake Sep 2, 2020
  14. Caomhin
    OnePlus 9 Series Expert Community Expert Sep 2, 2020
    Caomhin , via OnePlus 6T , Sep 2, 2020 :
    Try to Optimize the phone, clear your recent apps, also set 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    Guide to lower Batter Drain.
  15. D1528169082053
    Cupcake Sep 2, 2020
    D1528169082053 , Sep 2, 2020 :
    can we fix in the update
  16. Caomhin
    Maybe, maybe not, that be up to OnePlus, check your Battery stats and see if there is an app or apps using up more resources, heating is usually battery, CPU or GPU related.
    Is it while playing games, has it only started recently, and if so, did it coincide with a Game update or App update or new installation?
  17. shlyify
    Cupcake Sep 2, 2020
    shlyify , Sep 2, 2020 :
    Guys have you tried turn off RAM Boost
    Settings -> System -> RAM Boost
  18. ravanip2020
    Cupcake Sep 2, 2020
    ravanip2020 , Sep 2, 2020 :
    Just changed.
    kãräñ_90564 likes this.
  19. shlyify
    Cupcake Sep 2, 2020
    Good let us know, if drain stopped and how is battery life now :)
  20. RISHI_C
    Cupcake Sep 4, 2020
