139
[UNIFIED] Battery and heating feedback thread OnePlus 7t
  1. SobinZz
    Jelly Bean Sep 28, 2020
    SobinZz , Sep 28, 2020 :
    Hey here's what I got from google support.
    This content is not created by me so all credit goes to the one who answer in google forums.
    Hi,Thanks for posting in Google help forums,Go to Settings > Security & Privacy> Device admin Apps > Select App ,
    “Deactivate this device admin App” Tap on and Deactivate > Deactivate all Apps temporarily,
    https://photos.app.goo.gl/GaJ332wTdJ5EbLjs7
    Go to Settings> Apps & notifications> App info > Google play store > Force stop> Storage> Clear cache> Clear data> Uninstall updates,
    https://photos.app.goo.gl/6FJQS1mDfXjU82Jx5
    Return to Settings > Apps and Notifications > Apps manager>
    Scroll down to>
    Google play services >3 Dot Menu at top right> Uninstall Updates > finish,
    https://photos.app.goo.gl/Th6y2Fsz288M3tBJ6
    Pull down the notification bar and select “ Update Google play services “ prompt,
    https://photos.app.goo.gl/mskhdCHsHo5akyrM6
    Or,
    Open the link and update Google play services,
    https://play.google.com/store/apps/details?id=com.google.android.gms
    Update Google play services >Go to Settings>>>> Find my device and other Apps activate.
    https://photos.app.goo.gl/qrHXfx27mNmEQSFx5
    Still problem persist,Reset the Device to Factory Settings.
    https://support.google.com/playedition/answer/6072865
    This will not degrade Android phone Version.
    Try following these steps. Many have eliminated battery draining problem by doing this.
    Deactivated User likes this.
  2. Dresa91
    User of the Year 2016; Most Active User 2020 Sep 28, 2020
    Dresa91 , Sep 28, 2020 :
    as I mentioned...
  3. rohit_burman
    Cupcake Sep 28, 2020
    rohit_burman , Sep 28, 2020 :
    Anyone had any luck with this? Not me. I tried everything except factory reset.
  4. A1592641134815
    Froyo Sep 28, 2020
    U1527917758122 likes this.
  5. OmarRolon
    Honeycomb Sep 29, 2020
  6. stajni13
    Gingerbread Sep 29, 2020
    stajni13 , via OnePlus 7T , Sep 29, 2020 :
    Exactly
  7. AaDi.aditya
    Eclair Sep 29, 2020
  8. satya2212
    Cupcake Sep 29, 2020
  9. kaz04
    Froyo Sep 29, 2020
  10. rohit_burman
  11. am10
    Honeycomb Sep 30, 2020
  12. prajvalshetty
    Eclair Oct 2, 2020
    Venkat0309 likes this.
  13. Venkat1110
    Froyo Oct 2, 2020
    Venkat1110 , Oct 2, 2020 :
    with 90hz refresh rate I too didn't got abv 5/5.5 hrs of SOT bro
  14. GaganPlus , via OnePlus 7T Frosted Silver , Oct 3, 2020 :
    Guys, I have been using OnePlus 7T but, recently my SOT has really dipped to 3-4 hours max. and I have noticed Whatsapp is draining too much of my battery. Can anyone help me with this? I have posted the ss of how much I have used Whatsapp and the my total battery drainage. Thanks in advance.
    Preetham28 likes this.
  15. P1594785761989
    Cupcake Oct 6, 2020
    P1594785761989 , Oct 6, 2020 :
    I have been facing battery drainage issue after two months of usage. At first when I purchased this phone. The battery back up was awesome. Screen on time for game like Call of Duty was 6 hours. Watching just movies on Amazon prime or Netflix lasted be above 9 hours. A mixed usage would give me a around 7 hours. Now the phone heats up and battery drains rapidly. Almost 2 hours drop in performance. I feel so frustrated because it's my first One plus phone, bought this with great expectation. If anyone facing an issue and knows how to fix it let me know.
  16. Manish_07
    Gingerbread Oct 8, 2020
  17. U1573540024081
    Eclair Oct 9, 2020
    U1573540024081 , Oct 9, 2020 :
    just minimal usage not even getting 5 hours of sot. first i used to get around 6 hours now not even getting 5 hours. kindly fix the battery issues on Oneplus devices
    mittalsaheb23 likes this.
  18. U1573540024081
    Eclair Oct 9, 2020
  19. Rana_S
    Gingerbread Oct 9, 2020
  20. navdeepsaxena7T
    Cupcake Oct 9, 2020
