89
[UNIFIED] Battery and heating feedback thread OnePlus 7t
  1. OmarRolon
    Gingerbread Nov 15, 2020
    OmarRolon , via OnePlus 7T Pro , Nov 15, 2020 :
    This is a cycle at 60Hz, the truth is that it gives me one more hour of battery life, but I dislike the experience of spending all the time at 90Hz at 60hz, the smoothness is very remarkable. I decided to leave at 90hz
  2. Ritik@Singh
    Eclair Nov 15, 2020
  3. rmstrasel
    Donut Nov 15, 2020
  4. OmarRolon
    Gingerbread Nov 16, 2020
  5. xXAstroXx
    xXAstroXx , via OnePlus 7T , Nov 16, 2020 :
    Gaming can drain your battery quickly, especially something like PUBG. Are you running at 60Hz or 90Hz? How warm does your device get during gameplay? On the second screenshot we need you to tap on the 3 vertical dots in the top right to show system values for more info. There are too many unknowns here to help you my friend. I would suggest restarting your device into recovery and clearing cache to start with.
  6. abenbjohn10
    Donut Nov 17, 2020
  7. abenbjohn10
    Donut Nov 17, 2020
  8. Janefernandes
    Cupcake Nov 18, 2020
    MRTLima likes this.
  9. Ritik@Singh
    Eclair Nov 18, 2020
    Ritik@Singh , via OnePlus 7T , Nov 18, 2020 :
    How i do recovery re-start
  10. xXAstroXx
    Gingerbread Nov 18, 2020
    xXAstroXx , via OnePlus 7T , Nov 18, 2020 :
    Go into Settings>About Phone>tap on Build Number several times to enable developer>go to System>Developer options>Advanced Reboot. When you go to power off your device you will see an option for recovery. If you have a lock screen pin it will have you enter it in recovery mode. Chose clear data option when in recovery and you will see an option to clear cache and then reboot. I would recommend doing it while plugged in at 100%. After you finish unplug and use normally without charging until ~1% and then plug back in and charge to 100% without unplugging. Use normally for a few days and see if there's any improvement.
  11. Ritik@Singh
    Eclair Nov 18, 2020
  12. OmarRolon
  13. JAINSHUBHAM.97
    Donut Nov 19, 2020
  14. Ritik@Singh
    Eclair Nov 19, 2020
    Ritik@Singh , via OnePlus 7T , Nov 19, 2020 :
    Just in 2 hour's 60 % I can't believe
  15. MRTLima
    Gingerbread Nov 19, 2020
  16. MRTLima
    MRTLima , via OnePlus 7T , Nov 19, 2020 :
    I have optimised mine too. Since then it's been great!!!!
  17. Preetham28
    Eclair Nov 19, 2020
    D.SANTHOSHKUMAR1 likes this.
