79
[UNIFIED] Battery and heating feedback thread OnePlus 8
  1. Cool_jaisss
    Donut Nov 6, 2020
  2. naidubhimesh
    Eclair Nov 8, 2020
    naidubhimesh , via OnePlus 8 , Nov 8, 2020 :
    I think your current location it too hot their is only religion of heating the mobile and you can give some rest also because even a human being can also Tide to heavy work ...so plase do it
  3. naidubhimesh
    Eclair Nov 8, 2020
    After updating your phone new os 11 , actually it's happens you need to wait for the up coming bugf fix update
    Cool_jaisss likes this.
  4. naidubhimesh
    Eclair Nov 10, 2020
  5. Rio19052
    Froyo Nov 10, 2020
    Rio19052 , via OnePlus 8 , Nov 10, 2020 :
    Guys turn off the intelligent switch wifi from the wifi preferences, I think that is the issue seems to have solved the problem for me. That feature is super glitched anyway.
  6. naidubhimesh
    Eclair Nov 10, 2020
  7. CRK1918
    Cupcake Nov 11, 2020
    CRK1918 , via OnePlus 8 Pro , Nov 11, 2020 :
    I recommend to get the Greenify Pro version so you can kill all the background applications in the system and or some you don't use as much(Or you don't need to run on the background.)...and increase the battery performance.
  8. Zero000o
    Cupcake Nov 12, 2020
  9. Sheik_Nawaz
    Gingerbread Nov 13, 2020
  10. Mehulagarwal_1
  11. pandu4400
    Donut Nov 13, 2020
  12. nedjmouchaieb
    Donut Nov 13, 2020
  13. iTarifP6
  14. Swejuggalo
    OnePlus 9 Series Expert Community Expert Nov 13, 2020
    Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Nov 13, 2020 :
    You might find it by looking for idle drain. Heat usually comes from some activity.
    You can force manual background optimizing and view the actual CPU usage via ADB.
    Background optimizing (adb shell) : cmd package bg-dexopt-job
    CPU usage (adb shell) : top -m 10 (or a other number of your choosing).
    https://forums.oneplus.com/threads/...-and-battery-calibration-myths-busted.993896/
    Alternate battery stats app.
    https://play.google.com/store/apps/details?id=com.gsamlabs.bbm
    ( https://play.google.com/store/apps/details?id=com.gsamlabs.bbm.pro )
    Adb installation.
    https://www.xda-developers.com/install-adb-windows-macos-linux/
  15. Mehulagarwal_1
    Gingerbread Nov 14, 2020
  16. AliOgun
    Cupcake Nov 14, 2020
  17. SoumenduK
    Cupcake Nov 15, 2020
    SoumenduK , via OnePlus 8 , Nov 15, 2020 :
    Same.
    I used to get around 8 hours on a full charge which has reduced by an hour atleast even with very light usage.
    I have already done a factory reset but the battery is nowhere close to what it was on OOS 10.
  18. Swejuggalo
    OnePlus 9 Series Expert Community Expert Nov 15, 2020
