90
[UNIFIED] Battery and heating feedback thread OnePlus 8
  1. SamTheGamer39 , via OnePlus 8 Glacial Green , Jun 7, 2020 :
    I agree, either you have some app running in the background that is consuming lots of battery power or you have a defective unit. Try a factory reset and install only your essential apps. If that doesn't fix the issue, I would contact OnePlus support and tell them that you have a defective battery.
    #61
  2. U1580007062575
    Gingerbread Jun 7, 2020
    U1580007062575 , via OnePlus 8 , Jun 7, 2020 :
    yes!! I did this , I will take your words guys and will do a factory reset and instead of recover from a backup I will start from scratch and just download the apps I use! I will backup everything later and let u guys know , just by looking at the screen 10 minutes you can see how the battery goes down
    #62
  3. D1588432254405 , via OnePlus 8 Pro , Jun 8, 2020 :
    the most I've got is around 4hrs and 40mins SOT and 36hrs since my last charge. it's hard for me to get lots of SOT to test because I work 6 nights a week so have limited time in work and when I'm home I am normally asleep. Not sure if that's good or bad.
    #63
  4. U1580007062575
    Gingerbread Jun 8, 2020
    U1580007062575 , via OnePlus 8 , Jun 8, 2020 :
    considering the 36hs I think that's a good SOT
    #64
  5. N1532457707342
    Cupcake Jun 8, 2020
    N1532457707342 , via OnePlus 8 , Jun 8, 2020 :
    my OnePlus 8 getting heat while in my pocket and gets hot only 10 minutes of usage and battery drains faster,plz fixed this issue,I just upgraded my phone 6 to 8 and I bought just one day ago.
    I don't want to be disappointed.
    #65
  6. Cervantes
    Moderator Moderator Jun 8, 2020
    Cervantes , Jun 8, 2020 :
    Hi
    You can contact support
    Please, check and use this thread for all battery questions
    what is the ambient temperature in your city
    for another user to suggest: upload a screenshot of:
    battery and other
    battery uses
    Install cpuz: thermal
    Use the search engine before opening a new thread
    Thread merged
    #66
  7. Amod raj
    Cupcake Jun 9, 2020
    Amod raj , Jun 9, 2020 :
    Yesterday I got delivery of my one plus 8 and i am already facing screen retention issue on it.. don't buy one plus 8!!! 😔
    #67
  8. Naung_Mon_Oo
    Cupcake Jun 9, 2020
    #68
    rean007 likes this.
  9. darshan_vaja
    Cupcake Jun 10, 2020
    darshan_vaja , via OnePlus 8 , Jun 10, 2020 :
    I am using OnePlus 8 since 2 days. I think i am not getting good SOT as the tech reviewer mentioned like 8 hrs. Today i got 5hr 18mins SOT while battery ran from 88% to 9%. system settings: black theme, haptics on, live wallpaper on, 90Hz.
    And also the app accubattery is telling only 93% battery health. Is there something wrong with device?
    #69
  10. darshan_vaja
    it is also on my phone, i think it is something related with indisplay fingerprint sensor.
    #70
  11. Amod raj
    Cupcake Jun 11, 2020
    Amod raj , via OnePlus Community App , Jun 11, 2020 :
    Can you please share me your images.. I don't think it's because of in display fingerprint sensor but rather burn in.
    #71
  12. darshan_vaja
    #72
  13. Amod raj
    #73
  14. darshan_vaja
    darshan_vaja , via OnePlus 8 , Jun 11, 2020 :
    don't forget to tell me what service centre guy says. How was your battery backup in terms of SOT?
    #74
  15. Amod raj
    TBH i didn't assess the battery backup as you did. I used it with all the default settings as you did and as far as i remember with 100 percent to 50% battery remained, SOT was around 4 - 4, 1/2 hours, taking in consideration i was watching series..
    Yeah, I'll let you know[e]1f44d[/e]
    #75
    P1591627028243 likes this.
  16. fubar3803
    Froyo Jun 13, 2020
    fubar3803 , Jun 13, 2020 :
    To add my battery life experience...
    Using AccuBattery, I can confirm that my OnePlus 8 using the 90hz display setting (instead of 60hz) will increase the battery consumption by approx. 8-10% per hour.
    Screen On Battery Discharge (No device usage, just screen on at 50% brightness)
    60hz
    Usage:4.7 %/h
    Consumption:213.7 mA
    Instant Consumption:175mA (Scrolling the screen increases this to 271mA)
    90hz
    Usage:13.6 %/h
    Consumption:256.4mA
    Instant Consumption:221mA (Scrolling the screen increases this to 337mA)
    Not sure if that’s to be expected or not, seems a bit high to me?
    #76
  17. S1591786950213
    Cupcake Jun 13, 2020
    S1591786950213 , Jun 13, 2020 :
    I got my OnePlus 8 some days ago. So here is a question of a "newcomer" to this phone: According to literature the lithium-accu should only charged to 80% and not discharged less than 30%. So is it according to your opinion useful to do so with the OnePlus 8?
    #77
  18. fubar3803
    Froyo Jun 13, 2020
    fubar3803 , via OnePlus 8 , Jun 13, 2020 :
    The OnePlus 8 (and pro) will trickle charge the battery to 100% based on your charging habits so that's no a problem.
    In terms of running the battery to empty, I would only suggest doing this once a month no more. This ensures the battery is cycled correctly.
    #78
  19. AdrianFischer
    Gingerbread Jun 14, 2020
    AdrianFischer , Jun 14, 2020 :
    I think there's more to it:
    - charging speed (faster is affecting the battery health over time)
    - capacity it's holding (above 80% and below 30% it's affecting battery health over time)
    charging speed is solved by trickle charging to 100%
    capacity problem is still there so you have to manually check for that
    Probably the best for your battery would be to not use Warp charge and instead go for the slower normal charging and stay between 30-80% but that's not realistic in real life. Who wants to miss out on the quick charging?
    #79
  20. manfred911
    Froyo Jun 14, 2020
    manfred911 , Jun 14, 2020 :
    degoogle it, you will be free from tracking and tracing spyware and the battery will last two full days
    #80
