82
Battery/Charging [UNIFIED] Battery and heating feedback thread OnePlus 8T
  1. Liehjan
    Marshmallow Oct 22, 2020
    Liehjan , Oct 22, 2020 :
    At least it charges faster ;):p
    EDIT: All oneplus phones have had bad battery at launch, wait for a few updates!
  2. Rohitr0p8t , via OnePlus 8T Aquamarine Green , Oct 22, 2020 :
    After first cycle completed i got 5h+ sot and then 2nd cycle onwards getting better played games in 120hz and social media ,watched a series got around 8h+(switched both 60& 120hz) with 20per left it needs some time to settle.
  3. #23
  4. Attached Files:
    GANESHPO75, VishnuRCU and gana_DaviD like this.
  5. F_Chethan_Veerabhadrappa , via OnePlus 8T , Oct 22, 2020 :
    Have u done any tweeks to get more SOT. Like reducing to 60hz always or inbetween are you changing the screen. How about location bluetooth and mobile data always on or on wifi
  6. chirag_varilani
    Donut Oct 22, 2020
    chirag_varilani , via OnePlus 8T , Oct 22, 2020 :
    I am not using AOD and i don't play games at all not a single game installed in my phone i only use social media application whatsapp Instagram and others thats it also not watching any of videos in normal usage i am getting 4 hrs SOT .
  7. D0ctorX
    Donut Oct 22, 2020
  8. Rohitr0p8t , via OnePlus 8T Aquamarine Green , Oct 22, 2020 :
    No tweaks done bro I will switch to 120hz during gaming and then 60hz always changing according to my useage.location will be turned off and akways using 4g+ using dual sims wifi not used till now got device in hand past 2dys and used with mobile data on all the time .try turning off bluetooth & wifi scanning,location off and check u will get better battery and remember one thing main thing try not to drain your battery below 15 percent and in between charge up to 90 ,95 and plugoff it will be good for your battery don't continuously chrge to 100
  9. F_Chethan_Veerabhadrappa , via OnePlus 8T , Oct 22, 2020 :
    Thanks bro and how about AOD I have disabled. Also how about notifications. Does your screen displays notifications with lights blinks in side of the screen when the device is locked
    Y1603743008207 likes this.
  10. TheMystic
    Lollipop Oct 22, 2020
    TheMystic , Oct 22, 2020 :
    Depends on what you use the phone for. It is funny people buy 120Hz phone and then set it to 60Hz. Why didn't you buy a lower spec phone instead?
    kvladan and Y1603743008207 like this.
  11. F_Chethan_Veerabhadrappa , via OnePlus 8T , Oct 22, 2020 :
    It's my wish to buy the phone
  12. TheMystic
    This is 2020. You can leave everything ON. They don't impact your battery life significantly, unlike in the past when the technology wasn't as developed as it is today. It is a smartphone and you should use it like one.
    kvladan, Y1603743008207 and Sriniroop like this.
  13. TheMystic
    Sure. Use it like as it is meant to be used. Else you are simply missing out on the experience that it is designed to give.
  14. TheMystic
    You don't have to configure all those things. The OS knows how to manage them. And your screen is not refreshing at 120Hz all the time. The OS keeps switching it based on what you are doing at any given point of time.
    As with battery, yes one should charge it before it drops below 15%.
  15. Rohitr0p8t , via OnePlus 8T Aquamarine Green , Oct 22, 2020 :
    Aod is enabled always as per lights I didn't notice it i think there is no lights as you said
  16. Rohitr0p8t , via OnePlus 8T Aquamarine Green , Oct 22, 2020 :
    I have a doubt regarding that if we put one refresh rate and does something that refresh rate will not want then it automatically switches back is that u saying then it's great
  17. TheMystic
    Look what is written on the settings page itself. You are only setting the 'maximum' refresh rate. Your display won't keep refreshing at that rate all the time. It will switch dynamically based on what is going on in the screen at any given point of time. So despite setting at 120Hz, if you are simply reading a news article, the OS will switch it to 60Hz until you do something that is graphically more intensive.
    Y1603743008207 and Rohitr0p8t like this.
  18. Dhaneshgavali
    Eclair Oct 22, 2020
    #38
  19. Rohitr0p8t , via OnePlus 8T Aquamarine Green , Oct 22, 2020 :
    Thanks bro that sounds great
    #39
  20. Chandra11121991
    Cupcake Oct 22, 2020
    #40
    Parivesh21 and Z1578150345819 like this.
