101
Battery/Charging [UNIFIED] Battery and heating feedback thread OnePlus 8T
  1. Tokolozi
    Most Original Avatar Feb 24, 2021
    Tokolozi , Feb 24, 2021 :
    In MMO terms.... it would mean it lasted much longer tho.
    Tobikage and Bobbie63 like this.
  2. Bobbie63
    Marshmallow Feb 24, 2021
    Tokolozi, Auristic and KluGe like this.
  3. camohan
    Moderator Moderator Feb 24, 2021
    camohan , Feb 24, 2021 :
    Hi there, I think that's an estimate based on your usage. It doesn't necessarily mean that it will switch off in 4 hours.
    If this is not you are expecting as accurate . You should provide by going to community app, profile page, my feedback, click on +, system charging.
    Also i dont understand why there is extra ss in mins and hrs.
    fulton1 and Bobbie63 like this.
  4. Auristic
    Lollipop Feb 24, 2021
    Bobbie63 likes this.
  5. Bobbie63
    Bobbie63 , Feb 24, 2021 :
    It's the new translation, Bugs Bunny edition
    Tokolozi, Auristic and McJader like this.
  6. McJader
    McJader , Feb 24, 2021 :
    It's a spelling error
    Auristic and Bobbie63 like this.
  7. McJader
    Bobbie63 and Auristic like this.
  8. fulton1
    Donut Feb 24, 2021
    fulton1 , via OnePlus 8T , Feb 24, 2021 :
    Ah so it's my fault that my battery drains more quickly and I need to do things post-update to limit the impact. Gotcha!
    Auristic likes this.
  9. Bobbie63
    It some does and sometimes don't. Just use and charge your device as you normally would do for a few days and see if the battery consumption is normal after that. Don't try to do all kinds of tweaking, just leave it as it is.
    Should the battery consumption still be high, better come back and post aal stats. Like battery (SOT) detailled battery and overall usage (3dot menu)
    Until then I wouldn't worry too much
    Auristic, Tokolozi and fulton1 like this.
  10. fulton1
    Donut Feb 24, 2021
    I'll do this.
    Had this problem before and had to send my 5T to Sweden to have its battery replaced.
    Hopefully as you say it'll take a few days to even itself out.
  11. Bobbie63
    No it's nobodies fault, just the way things work and as said, it's an estimation. Just do what I mentioned in my previous post.
  12. Bobbie63
    It will and when it doesn't, post again the screenshots as I mentioned.
    Just don't worry too much about battery consumption just after an update and don't focus too much on it, that'll drive you crazy
  13. pablofg1978
    Head Moderator Head Moderator Feb 24, 2021
  14. Y1608324070406
    Cupcake Feb 24, 2021
    Y1608324070406 , via OnePlus 8T , Feb 24, 2021 :
    Battery consumption is inconsistent. The one day I could get 7 hours of screen on time while the other day I could get 5 screen on time (with the same usage). I have to say that I don't use always on display but I use high refresh rate (120hz
  15. advridam
    Eclair Feb 24, 2021
  16. Liehjan
    Liehjan , Feb 24, 2021 :
    SoC or battery temp?
    McJader, Bobbie63 and Tobikage like this.
  17. AlwaysOneplus
    Gingerbread Feb 24, 2021
  18. Junjun Baccay
    Gingerbread Feb 25, 2021
  19. Sheppards
    Jelly Bean Feb 25, 2021
    the_o2, McJader, Liehjan and 5 others like this.
  20. advridam
    Eclair Feb 25, 2021
    advridam , via OnePlus 8T , Feb 25, 2021 :
    A flagship phone shouldn't get hot while playing games l for like 10 to 20 minutes regularly, as far as i expect. The main problem is that it gets hot over the screen area and it is constant in nature...
