129
Battery/Charging [UNIFIED] Battery and heating feedback thread OnePlus 8T
  1. TSD4
    Donut Oct 29, 2020
    TSD4 , via OnePlus 8T , Oct 29, 2020 :
    Dude how are you getting so much SOT?? I am hardly getting around 4-5hrs of SOT
  2. F_Chethan_Veerabhadrappa
    Froyo Oct 29, 2020
    F_Chethan_Veerabhadrappa , Oct 29, 2020 :
    yes how is that possible to get 6hrs SOT. i am getting 4 to 5 hours max. now also updated to 11.0.2.3. Within 2 hours from 100% to 90% just for using. 1 min youtube, 10 mins whats app & 1% for 10mins call thats it. 10% battery drain for 2 hours is bad. 1603980561215.jpg
  3. TSD4
    Donut Oct 29, 2020
    I get 4-5hrs if i use continuous for 1 to 1.5 hrs and then remaining is of casual usage if i just leave it idle then it keeps on draining the battery, should i consider for replacement but there are no much heating issues( but it gets warmer at times or hotter on continuous gaming which is normal i guess) only problem is battery drainage!!! Or should i wait for 10 more cycles of charge and discharge until now I completed only 4 cycles of battery charge and discharge before the second charge and discharge itself i got the update which made it more worse i guess!
    Please suggest me!
  4. ConnectMrMJ
    Honeycomb Oct 29, 2020
    ConnectMrMJ , via OnePlus 8T , Oct 29, 2020 :
    Haven't came through an issues. The device is pretty cool enough even after 90min of gaming & 7hrs of screentime. I only charge my device once a day n its pretty enough.
  5. Rohitr0p8t , via OnePlus 8T Aquamarine Green , Oct 29, 2020 :
    Don't know the magic iam still getting good sot I tested with 120hz full gaming and got in between 6-7 sot (cod,dead trigger,asphlt)and with 60hz norml I got 8-9 sot and both switched at times still get good backup I usually didn't drain bttry too much when it comes around 20 I put in charge and u should not continuously chrge till 100 chrge till 90,85 like that it will improve battery usually it will takes couple of charges to set battery life
    120hz full useage gaming ,YouTube social media
    ConnectMrMJ likes this.
  6. nolandc
    Eclair Oct 29, 2020
    nolandc , Oct 29, 2020 :
    Went to bed last night and woke up with about 40% battery loss. Seems like battery drain started happening after I un pluged from cars Android Auto. I don't think this is related but my app icons are suddenly missing in apps and notification section of settings. I've only been getting a maximum of 4hours SoT. I'm using 60hz.
  7. F_Chethan_Veerabhadrappa
    Froyo Oct 29, 2020
    Please provide the screenshot where system apps are consuming battery. Like screen
  8. ConnectMrMJ
    Same for me.. i m getting 7Hour+ on screen time.
  9. ConnectMrMJ likes this.
  10. ConnectMrMJ
    Yeah i have received an update yesterday, the latest version is "11.0.2.3.KB05DA"
  11. ConnectMrMJ
    I noticed even lesser heat while gaming.. temps use to be around 36°C, now it's 31-33°C most of the time. Updates r worth any day :)
    Rohitr0p8t likes this.
  12. anmokpuranik
    Eclair Oct 29, 2020
  13. anmokpuranik
    Eclair Oct 29, 2020
    anmokpuranik , via OnePlus 8T , Oct 29, 2020 :
    There's a comparison of batter backup between phones on YouTube and it seems One plus 8T can manage 5+ hours of screen on time including Full HD YouTube Playback and extreme gaming at full brightness. I am planning to go with replacement as not everyone seems to be facing the issue.
  14. panda211
    Donut Oct 29, 2020
  15. hojsimpson952
    Ice Cream Sandwich Oct 30, 2020
    panda211 likes this.
  16. Akhilbuddha
    Eclair Oct 30, 2020
  17. U1593342158886 , via OnePlus 8T Lunar Silver , Oct 30, 2020 :
    People are saying( the reviewers )that by 65watt charging it will damage the battery in upcoming 2 years that your battery will drain faster because you charge with 65 watt charging ?
    And why did OnePlus not come with 865+ ?
  18. panda211
    Donut Oct 30, 2020
    hojsimpson952 likes this.
