149
[Unified]Battery and heating Thread for OnePlus Nord
  1. K1627494394296
    Cupcake Jul 28, 2021
    K1627494394296 , via OnePlus Nord , Jul 28, 2021 :
    The same for me. I have the phone from 2 weeks, last software and while i using the phone on the car with the app for driving (waze or maps) it goes overheating. If the temp go above of 45°C, the phone is enter in safe mode. Very dissapointed about the phone, maybe in the future with only a update of the software, they will fix it.
  2. Yash0107
    Yash0107 , via OnePlus Nord , Jul 28, 2021 :
    I am also facing exactly same problem with OnePlus Nord.
    My old OnePlus 3T is working perfectly fine with this condition.
    Did you find any solution??
  3. arvindsoni2001.asj , via OnePlus Nord , Jul 30, 2021 :
    Battery Saver is a very big reason of notifications delay too.
    (For me, atleast)😖
  4. N1627711355896
    Cupcake Jul 31, 2021
    N1627711355896 , Jul 31, 2021 :
    Nord2 in battery optimization it is reported when you optmize it that th 5g connection has been turned off ...how to turn it on again?
  5. 3matija likes this.
  6. M1627743500229
    M1627743500229 , Jul 31, 2021 :
    i have oneplus nord 5g and it is noticed since last 2 weeks the battery is draining fast. while checking detail it is noticed that around 65% usage is for messages only. I have deleted cache still result is same. what is the issue and how to resolve?
  7. N1608534068846
    3matija likes this.
  8. Pinku Reddy
    Gingerbread Aug 2, 2021
    Pinku Reddy , Aug 2, 2021 :
    Before you about to charge please clear all apps from recent. There are some apps which will run in background and required more powers. Those apps will effect charging time and leads to slow charging..
    Apps :- FB , Picsart , MCA Security , etc..
  9. I1589703477404 , via OnePlus Community App , Aug 4, 2021 :
    My battery drains fast even without using the mobile and it gets heated up with normal usage..Need this to be fixed immediately.. earlier i was using oneplus 6 it was a seamless experience on that.. Battery drain and heating up is major issue and it should be considered with fix asap.. @Oneplusnord2 #nord2
  10. Suryasao999
    Cupcake Aug 8, 2021
    Suryasao999 , via OnePlus Nord , Aug 8, 2021 :
    52% 30w fast charging less than 1 hr, 6 min remaining 🤣🤣🤣🤣😡😡😡🤬🤬🤬🤬🤬
    what a joke
    This problem even after being in dark mode
    what to do now😡😡😡😡
  11. Lucas X.
    OnePlus Engineer Staff Member Aug 9, 2021
    Lucas X. , Aug 9, 2021 :
    If you have any power consumption problems, you can email me or send me a private message.
  12. Lucas X.
    OnePlus Engineer Staff Member Aug 10, 2021
    Lucas X. , Aug 10, 2021 :
    The latest V8.8 version of Google Info has solved this problem, please update the latest version in the app store.
  13. pablofg1978
    Head Moderator Head Moderator Aug 10, 2021
    pablofg1978 , Aug 10, 2021 :
    Thread merged
  14. debrouwer.kristof
    Cupcake Aug 10, 2021
    debrouwer.kristof , Aug 10, 2021 :
    HW: Oneplus Nord, AC2003
    SW: OxygenOS 11.14.4.AC01BA
    Problem Description
    I'm facing Battery drain issues during standby, from ADB batterystats I seem to loose 1% per 20 minutes, essentially during the night i loose 25 to 30% battery life in standby, when I put the device in flight mode i only loose 4% battery life during the night.
    Details:
    #1: +21m14s482ms to 69 (screen-off, power-save-off, device-idle-on, network-off)
    #2: +20m15s602ms to 70 (screen-off, power-save-off, device-idle-on, network-off)
    #3: +22m23s795ms to 71 (screen-off, power-save-off, device-idle-on, network-off)
    #4: +21m19s914ms to 72 (screen-off, power-save-off, device-idle-on, network-off)
    #5: +25m29s207ms to 73 (screen-off, power-save-off, device-idle-on, network-off)
    #6: +23m39s491ms to 74 (screen-off, power-save-off, device-idle-on, network-off)
    #7: +21m31s357ms to 75 (screen-off, power-save-off, device-idle-on, network-off)
    #8: +19m49s211ms to 76 (screen-off, power-save-off, device-idle-on, network-off)
    Since my last discharge i lost 1003 mAh from which 50% happened during deep doze:
    Screen off discharge: 895 mAh
    Screen doze discharge: 0 mAh
    Screen on discharge: 107 mAh
    Device light doze discharge: 179 mAh
    Device deep doze discharge: 537 mAh
    Looking at power use per PID, 762mAh is unaccounted:
    Estimated power use (mAh):
    Capacity: 4115, Computed drain: 267, actual drain: 1029-1070
    Unaccounted: 762 ( ) Including smearing: 0 ( ) Excluded from smearing
    Screen: 98.4 Excluded from smearing
    Uid 1000: 41.3 ( cpu=37.7 wake=0.471 wifi=2.65 gps=0.00254 sensor=0.477 ) Excluded from smearing
    Uid 0: 26.2 ( cpu=23.1 wake=3.03 radio=0.000286 wifi=0.0323 ) Excluded from smearing
    I need further assistance on how do identify the root-cause of this standby battery drain, feel free to reach out for a full bugreport
    Kristof
  15. jdkzzz
    Froyo Aug 12, 2021
    jdkzzz , via OnePlus Nord , Aug 12, 2021 :
    USE ONLY WI-FI - POSSIBLE SOLUTION TO INCREASING BATTERY LIFE
    Initially my Nord was getting 7-8hrs of SOT. Then after Android 11 update, it reduced to 4-5hrs. The latest update addresses battery drain issue but it didn't work for me.
    Suddenly on this Tuesday I got close to 8hrs of SOT and decent standby time after I changed my wallpaper to a static image and only used the internet via WiFi. Today, I switched to just using mobile data and I only got 4hrs of SOT and standby time seems to have gotten worse. See screenshots below for reference.
    So my guess is that using the phone on mobile data gives worse battery life which is not ideal for most Indian users LoL.
  16. Zankenobi
    Eclair Aug 13, 2021
