55
[UNIFIED] Oneplus 6T battery and heating thread
  1. C1521575030765 Cupcake Jan 4, 2019
    C1521575030765, Jan 4, 2019 :
    itsmesmack
    I'm using that OS version dude. If your using Mobile Data over the WIFI you usually notice the significant draining of battery.
    thanks, yes i noticed that, but i don't use mobile data. currently having this on screen back up from 100-20 . main problem is idle battery draining.
  2. itsmesmack Donut Jan 4, 2019
    itsmesmack, Jan 4, 2019 :
    C1521575030765
    itsmesmack
    I see..just make your phone in the Dark theme. It will also reduce the battery draining on screen, actually it's only 2-5% from 100% full charge if the phone is running on the idle background. And just off or Wifi or Data if your not using.
    C1521575030765 likes this.
  3. C1521575030765 Cupcake Jan 4, 2019
    thanks bud [e]1f44a[/e]
    itsmesmack likes this.
  4. itsmesmack Donut Jan 4, 2019
    Your welcome dude. [e]1f44d[/e]
  5. Gary Uppiah Eclair Jan 4, 2019
    Gary Uppiah, Jan 4, 2019 :
    I have had the most amazing battery life ever. went to be and woke up to this much battery still in the phone with almost 7 and a half hours of screen on time. brightness was on auto. and I was using it normally such as texting, watching YouTube, browsing social media and more.
  6. C1521575030765 Cupcake Jan 4, 2019
    OS version?
  7. Gary Uppiah Eclair Jan 4, 2019
  8. Sasikumar15 Cupcake Jan 5, 2019
    Sasikumar15, Jan 5, 2019 :
    How much applications have you installed in your mobile...
  9. Q1511230454445 Cupcake Jan 5, 2019
    Q1511230454445, Jan 5, 2019 :
    bro what is your current version of os
  10. Z1541314361003 Cupcake Jan 5, 2019
    Z1541314361003, Jan 5, 2019 :
    I believe I am facing the issue related to phone getting heated up and battery getting drain within 5 hrs. this was not the same when I had purchased the phone. I have an average usage and don't think it should dràin the battery so frequently
  11. Z1541314361003 Cupcake Jan 5, 2019
    how do I check which app is drainng the battery?
  12. itsmesmack Donut Jan 5, 2019
    itsmesmack, Jan 5, 2019 :
    Bro, just go to Settings and Battery you will see there View usage Battery.
  13. W1546713228405 Cupcake Jan 5, 2019
    W1546713228405, Jan 5, 2019 :
    I got my op6t a couple of days ago after sending back a Huawei p20 pro. I can honestly say that the battery life is better than the Huawei, even though it'it has a 4000 mah battery. So far I am well impressed. It may be because I have decided to not use Nova launcher as I am quite happy with oneplus oxygene using swipe gestures which I am slowly getting used to. I have heard that Nova launcher does drain the battery quicker.
  14. vipindas Donut Jan 5, 2019
    vipindas, Jan 5, 2019 :
    Hello ,
    I am from Asia Pacific region (India) and i have recently updated my 6T to 9.0.11 . The strange issue i noticed was that post the update my battery is draining faster while using Dual sims. I have tested this under different scenarios
    1. With Dual sim (preferred network type :LTE) -battery drain noticed
    2. With Single sim (preferred network type :LTE) -normal battery performance
    3. With Dual sim and VoLTE enabled (preferred network type :LTE) -battery drains noticed
    4. With Single sim and VoLTE disabled (preferred network type :LTE) -normal battery performance
    Note: I am not playing any games or graphics intense apps. I am a medium/average user.
    If anyone else has noticed please let me know.
  15. Gary Uppiah Eclair Jan 6, 2019
    Gary Uppiah, Jan 6, 2019 :
    I have mostly social media and a single game. but I do have a smart watch constantly connected via Bluetooth.
  16. naramamoorthi Eclair Jan 6, 2019
    naramamoorthi, Jan 6, 2019 :
    I've noticed higher battery drain since getting 9.0.11
    Apps usage looks normal. I lost about 6% overnight while sleeping. Used to be 2%. The phone feels like it's running a bit warmer too. Let me know if there's anything i can do to help troubleshoot these issues.
  17. Gary Uppiah Eclair Jan 6, 2019
    I'll test this out tonight. going to bed at 95% battery. my smartwatch is still connected via Bluetooth. I'll update you on the percentage tomorrow morning.
    naramamoorthi likes this.
  18. Gary Uppiah Eclair Jan 6, 2019
    alright so woke up with 91%. I don't think it's draining too quickly. I do have a Bluetooth device connected.
  19. Wiruz Donut Jan 6, 2019
    Wiruz, Jan 6, 2019 :
    I have A6003 OS 9.0.2
  20. Hardmonk07 Cupcake Jan 6, 2019
    adi1001 likes this.
