75
[UNIFIED] Oneplus 6T battery and heating thread
  1. FakeMelon Cupcake Jan 7, 2019
    FakeMelon, Jan 7, 2019 :
    Hey,
    Just got a new device. Battery was insane for about 2 days. Then last night I charged the phone up to a 100%. When I went to sleep I disabled mobile data and wifi as usual. Woke up this morning and battery got to about 80%! 20% drain over night. And it seems to keep draining pretty fast now as well.
    Is this related to the system update released yesterday? I'm very worried about my new device. Any help?
  2. F_Marko_Bogdanovic_nCvp Donut Jan 7, 2019
    F_Marko_Bogdanovic_nCvp, Jan 7, 2019 :
    Had more or less same problem after updating phone on last release. Two times restart and everything was back to normal. Every day had more than 7 SOT, and decided to test it yesterday. See it for yourself, my SOT from last day. 10+ h !!! :) 9.0.11 update is applied. Just to prove it. :) Maybe it is new world record :D
  3. malidan Marshmallow Jan 7, 2019
    adi1001 likes this.
  4. FakeMelon Cupcake Jan 7, 2019
    So should I restart the device a couple of times? Getting about 3 SOT after the update!
  5. F_Marko_Bogdanovic_nCvp Donut Jan 7, 2019
    It works for me. Also, remove unnecessary apps, turn on black theme, adaptive brightness, smart battery. If you do not have any other problem, like bugs or virus it should be OK. In worst case, do backup and master reset...
  6. F_Marko_Bogdanovic_nCvp Donut Jan 7, 2019
    In my case. Not saving it from "burning" at all, YouTube, Instagram, Facebook, talking...
  7. adi1001 Honeycomb Jan 7, 2019
    adi1001, Jan 7, 2019 :
    yes ...it is very worst....I m just irritated of this battery life.....when I was on 9.0.6 it was way better than now i.e. 9hrs of screen on time with 29hrs of total standby......
    they just messed up with battery
    I did factory reset several times but no change or fix ....
  8. malidan Marshmallow Jan 7, 2019
    malidan, Jan 7, 2019 :
    To install an update is not compulsary and OP's updates have always been this way.
    There are also seems to be quite a few root and modded YouTube app stats in this threads inflating SOT times .
  9. malidan Marshmallow Jan 7, 2019
  10. naramamoorthi Eclair Jan 8, 2019
    naramamoorthi, Jan 8, 2019 :
    Agreed. I just used it for a couple of days and the batt life is back to normal. Yay!
  11. FakeMelon Cupcake Jan 8, 2019
    FakeMelon, Jan 8, 2019 :
    Seems like it's back to normal for me as well. lost only 3% over night instead of 20%. looks promising.
  12. G12c4 Donut Jan 8, 2019
    G12c4, Jan 8, 2019 :
    Battery life seems better on 9.0.11 but nowhere close as on 9.0.6, also getting some random reboots
  13. JackBoss Cupcake Jan 8, 2019
  14. Lucas_Martins_Doretto Cupcake Jan 11, 2019
    S1548597146932 likes this.
  15. adi1001 Honeycomb Jan 11, 2019
  16. Pe4enie Cupcake Jan 12, 2019
    Pe4enie, Jan 12, 2019 :
    Literally just bought this phone yesterday. Updated to the latest 9.0.11 build, used OnePlus switch to copy data from my old phone. Fully charged the phone before going to sleep and woke up to this picture:
    This needs a fix asap.
    adi1001 likes this.
  17. Shrijal Shrestha Cupcake Jan 12, 2019
  18. C1545523358680 Donut Jan 12, 2019
    C1545523358680, Jan 12, 2019 :
    once I got an outstanding battery life after using it normally with less data usage n an hour of pubg but now I don't get this, rare to find 9hrs of SOT and my camera drains my battery quick like it drops a percentage for a min usage is this an issue? if some one facing the camera app draining battery issues let me know?
  19. adi1001 Honeycomb Jan 12, 2019
    adi1001, Jan 12, 2019 :
    i m facing this too and battery drain faster in idle mode...........
    hope so @OnePlus will fix it
  20. C1545523358680 Donut Jan 12, 2019
    are you facing the camera app battery draining issues? that's predominantly pissing me off.
