35
[UNIFIED] Oneplus 6T battery and heating thread
  1. tommyscy Eclair Nov 3, 2018
    tommyscy, Nov 3, 2018 :
    Moderator edit:
    To help us better resolve battery/heating-related issues, please submit a bug report [HERE]. Thank you in advance.
    1. Please use this thread for any issues, questions, tips and all things related to battery and heating.
    2. You can ask a moderator to pin a post with battery tips to be shown on the first page of this thread.
    Hey community,
    I would like to ask those who have the new OP6T how much does the battery lasts when working hard or medium on phone. You can upload a screenshot of the analytics on the end of your day
  2. SiliconAddiction Froyo Nov 9, 2018
    Stickied Post
    SiliconAddiction, Nov 9, 2018 :
    There are a lot of people complaining about battery life. While many folks most likely know this already as its pretty common knowledge it should still be reiterated for folks who aren't aware.
    While this isn't a silver bullet solution, enabling the dark theme and enabling it for any apps that support such as YouTube, Messages, Google News, and Phone can help.
    Google did some tests. The results pretty much back up what we already know with real numbers
    Note that this is with max brightness. Drop that to 50% and...well do the math.
    Google details just how good dark mode is for your battery
    https://www.androidauthority.com/google-dark-mode-battery-923359/
    Standard behavior of an OLED is that blacks onscreen are locations where the pixel is off. The more off pixels.....obviously.... the less power being drawn from the screen.
    The setting is easy to find under SETTINGS > DISPLAY >Customization > Theme
    Ultimately there will not be a single solution for battery life. But this can be one part of the overall puzzle.
  3. souby Cupcake Nov 3, 2018
  4. tommyscy Eclair Nov 3, 2018
    6 hours non stop active?
  5. souby Cupcake Nov 3, 2018
    JelleZon, mariogold42 and Jeyr2012 like this.
  6. Aks41179 Jelly Bean Nov 3, 2018
    Aks41179, Nov 3, 2018 :
    You should wait for few days and then see how your battery performance is, don't expect great results in just couple days
  7. kksirur Eclair Nov 3, 2018
    kksirur, Nov 3, 2018 :
    6 and have hours with 29% remaining [e]1f60a[/e]. I am sure it will last me a day and also with dash charging it takes little more than an hour to fully charge the device so this is fine for me [e]1f60a[/e]
  8. Sandip_Patil Gingerbread Nov 4, 2018
    Sandip_Patil, Nov 4, 2018 :
    I have One plus 6 and OnePlus 6t also but I see that One plus 6T has a heating issues. Normal videos and game heats the 6T a lot when compared to One plus 6.
  9. lolu2394 Cupcake Nov 4, 2018
    lolu2394, Nov 4, 2018 :
    does any one feel that their one plus 6t's battery is draining? I feel that battery is draining even if the phone is idle. any optimization tips would also be helpful.
  10. cyber_warrior Eclair Nov 4, 2018
    cyber_warrior, Nov 4, 2018 :
    no brother there is nothing like that there must be some issue with your mobile
    pls give a visit to service center
  11. HarishGunjalli Cupcake Nov 4, 2018
    HarishGunjalli, Nov 4, 2018 :
    Even I feel that. I think it's because of amoled display as it keeps on showing with a minimal shake on the phone.
  12. ankitbhagat.ankit Donut Nov 4, 2018
  13. cyber_warrior Eclair Nov 4, 2018
    jamesvmoore likes this.
  14. A1541317464620 Eclair Nov 4, 2018
  15. A1541317464620 Eclair Nov 4, 2018
    A1541317464620, Nov 4, 2018 :
    reduce the screen activity time to 30 sec
    KiKlP and cyber_warrior like this.
  16. F1541306225320 Cupcake Nov 4, 2018
  17. G_HIMANSHU_CHOUHAN_PwIT Cupcake Nov 4, 2018
  18. F1541306225320 Cupcake Nov 4, 2018
    F1541306225320, Nov 4, 2018 :
    pubg doesn't cause heating issue with this phone. try asphalt 9.
    truepreet likes this.
  19. S1541341699659 Cupcake Nov 4, 2018
    F1541137857767 likes this.
  20. rs1 Honeycomb Nov 4, 2018
    rs1, Nov 4, 2018 :
    A number of videos on Youtube show this not to be the case. In nearly every instance, the OPO 6T seems to be relatively stable from a temperature perspective only increasing 2-3 degrees in most use cases.
    If your phone is getting hot you may have other apps/services running in the background attributing to the heat. The more CPU intensive a task, the more heat that gets generated.
    IotaLion, cenon415 and Abhi Dahiya like this.
  21. S1541341699659 Cupcake Nov 4, 2018
    S1541341699659, Nov 4, 2018 :
    sure I try and revert
