34
[UNIFIED] Oneplus 6T battery and heating thread
  1. Nikhilesh750 Froyo Nov 8, 2018
    Nikhilesh750, Nov 8, 2018 :
    Was using internet for nearly 2 and half hour on mobile data then watched a movie as well as other videos and then normal checking whatsapp, social media with mobile data being on and off, gallery, community, shopping, some chrome browsing, some camera testing with the pixel mod nightsight, downloaded a video of 400 mb on 4g and basically what i can say is my 6T is just wow. Brightness bar is set at 75%.
    I get 4hrs of gaming on PUBG from 98% to 4% on mobile data with HD Ultra antialisation on with gaming mode on too.(if i had a wifi i guess i might never run out of battery[e]1f602[/e])
    Seagal_aikikai likes this.
  2. Sunny84singh Eclair Nov 8, 2018
    Sunny84singh, Nov 8, 2018 :
    If one thing I was always worried about in last 7yrs of iPhone usage was carrying a charging case,power bank and a charger with me.I had a charger at work ,home and my car .So after 7 long years I said bye to Apple and bought OnePlus 6t and m speechless with battery performance.I am a heavy user and still this guy is getting through the day easily.I only have one charger that too in my home that's it.In love with battery performance,feels independent toe.....
    Seagal_aikikai and Nikhilesh750 like this.
  3. badjack Eclair Nov 8, 2018
    prowler8811 likes this.
  4. badjack Eclair Nov 8, 2018
    badjack, Nov 8, 2018 :
    agreed
  5. imattv4 Ice Cream Sandwich Nov 8, 2018
    imattv4, Nov 8, 2018 :
    My average screen time since Nov 1 has been roughly 9hrs over a 25hr period. Id consider myself light usage though, with heavy gaming resulting in 5hrs over the same 25hr period. Either way, I am extremely pleased so far.
    For the first time ever, I have battery completely disabled in the notification bar and statusbar. I simply dont need to worry anymore, no matter what I do, im always fine for the full day
    Currently sitting at 80% with 3hrs screen time over 9hrs off charger
    Using Nacho Notch to hide the notch and black out the nav bar.
  6. I1541611427380 Cupcake Nov 8, 2018
  7. F_Ankush_kumar Cupcake Nov 8, 2018
    I1541611427380 likes this.
  8. F_Ankush_kumar Cupcake Nov 8, 2018
  9. badjack Eclair Nov 8, 2018
    Received feedback from OnePlus
    Hello badjack,
    Greetings. This is Jeff from OnePlus Bug Hunters Team, thanks for your feedback.
    We’re very concerned about the issues you mentioned on post: https://forums.oneplus.com/threads/oneplus-6t-battery-drain.935946/page-9 #164
    Sorry for this happened. please try to wipe cache to check if it helps:
    1. Power off your phone.
    2. Press Power switch while pressing Volume Down button for four seconds.
    3. Choose language and tap "Wipe data and cache".
    4. Tap "Wipe cache" and reboot.
    In order to resolve the issue reported ASAP, we may need to get more information and your data is under protected, please provide the below information for analysis, thanks.
    1, Can you tell me how many hours you can use the phone from 100% to 0 now?
    2, Is your phone heating when draining?
    3, Is it draining when in normal using or idle?
    4, Can you please capture some logs for investigation?
    1. Input *#800# from dialing interface, enter "oneplus logkit", enable "Move log path to build-in SD card", tap" delete history log".
    2. Tap "advanced" > "save log type" > enable all options, then click OK.
    3. Go back, click "save log", when it informs you whether to reboot, click “cancel”.
    4. Keep the logkit running in background for more than 1 hour when the phone is in idle, then go to settings>battery, and take a screenshot of the battery consuming situation.
    5. Enter oneplus Logkit, choose “other log info”, click “get top info”, “battery history” several times (with a time gap) and “get bugreport info” just before you finish the log process(it takes several minutes, wait till it’s done).
    6. After that, enter “oneplus Logkit”, tap “save log” again to stop it.
    7. Enter file manager, choose storage, then send the whole oem_log folder to jefferson.he@oneplus.cn along with the screenshots and your forum username. If the logs are too large, you can transfer the logs to google and share us a link.
    If battery drains most under normal use, please capture the log when you use normally. If it drains under long time standby, please start it before you go to sleep and finish when you wake up. It’s better to do it when battery is below 50%.
    Thanks and awaiting your reply.
    High regards,
    OnePlus Bug Hunters
    C1541230117599 likes this.
  10. mandeepsingh10 Froyo Nov 8, 2018
    mandeepsingh10, Nov 8, 2018 :
    1. Restrict background processing for social media apps like Instagram, Facebook, snapchat.
    2. Disable Google now if you don't use it.
    3. Go to recovery and clear cache.
    4. Restart your device daily when you wake up in the morning (it sounds silly but makes a lot of difference)
    Try these and let me know if there's an improvement.
    Cheers [e]270c[/e]
    itsmerenu likes this.
  11. MSB98 Donut Nov 8, 2018
    MSB98, Nov 8, 2018 :
    I got 5hrs of screen on time with 47mins of pubg at high graphics settings, took pics for a few mins and occasional browsing...It was 95% at around 7 in the morning. came down to 15 at 7 in the evening..Used to get more from my OnePlus 3T...But I guess that's just pubg takin it's toll
  12. sathishg72 Cupcake Nov 8, 2018
    sathishg72, Nov 8, 2018 :
    Again posting my battery life is approx. 1.5 days with medium usage with leftover of 20%. Very good battery life.
  13. I1541252925868 Cupcake Nov 8, 2018
  14. Goggeboy Honeycomb Nov 8, 2018
  15. M1541535601492 Donut Nov 8, 2018
  16. badjack Eclair Nov 8, 2018
    light use of WhatsApp and Facebook only. not happy with battery performance.
  17. Forgetfull Cupcake Nov 8, 2018
    Forgetfull, Nov 8, 2018 :
    You're really not happy with 6+ hours of screen on time while using some of the bigger battery sucking apps?
  18. badjack Eclair Nov 8, 2018
    Forgetfull
    You're really not happy with 6+ hours of screen on time while using some of the bigger battery sucking apps?​
    you think 6hrs of use without YouTube, games and calls is good ??
    C1541223514971 likes this.
  19. Marco313 Cupcake Nov 8, 2018
    Marco313, Nov 8, 2018 :
    I've gotten great battery life also on my 6t. The highest I've gotten was a little over 10hrs. I usually average around 8 though
  20. Marco313 Cupcake Nov 8, 2018
    That's great! You're on Pace for 15hrs SOT [e]1f601[/e]
