29
[UNIFIED] oneplus 7 battery and heating feedback thread
  1. himani_verma
    Cupcake Aug 7, 2019
    himani_verma , Aug 7, 2019 :
    I bought one plus 7 last week and observed that it's draining alot of battery with simple apps.
    I don't even play games on my phone.
    I have to charge my phone 2-3 times a day.
    Disappointed :(
  2. dosherpa
    Gingerbread Aug 9, 2019
    dosherpa , Aug 9, 2019 :
    My battery draining very fast even in ideal mode can any one help me in this issue?
  3. Mohamed Rashid S
    Eclair Aug 9, 2019
    Mohamed Rashid S , Aug 9, 2019 :
    my OnePlus 7 after upgrading to 9.5.8 have noticable battery drain ....
    There is no change in my usage pattern and with which I could clearly see huge drain in battery and heating issue..
    it's definitely after this upgrade.
    Please provide a easy rollback option or just fix it.
    MrDivyanshu likes this.
  4. parag008
    Ice Cream Sandwich Aug 9, 2019
    parag008 , Aug 9, 2019 :
    well at that time it was 9.5.6 or something i think.
    currently i have 9.5.8 and i dont see any drain issues here.
    please refer the battery saving tips provided by other users on forum.
  5. Mohamed Rashid S
    Eclair Aug 9, 2019
    But I use all battery saving tips like dark mode etc.
    And I was using the same previously and with the same settings enabled, I can feel the difference.
    Which means it should be something to do with OS upgrade I did (9.5.8).
    But I have no idea how u and some people experiencing the upside down of mine.
  6. Dhruvj
    Donut Aug 10, 2019
    Dhruvj , Aug 10, 2019 :
    I don't use Facebook and Instagram
  7. Swejuggalo
    Lollipop Aug 10, 2019
    Swejuggalo , Aug 10, 2019 :
    There can be various reasons for drain. Mine is usually between 0.3-0.4 with some battery hogging monsters installed (7 Pro)... Built-in battery stats does not always give enough helpful info.
    I've done a few tweaks and analysed the drain with BetterBatteryStats. My little battery guide (a work in progress)
    http://bit.ly/2ZzdsP8
  8. S1561098784907
    Cupcake Aug 10, 2019
  9. parag008
    Ice Cream Sandwich Aug 11, 2019
    parag008 , Aug 11, 2019 :
    sometimes some things behave specifically for specific devices differently.
    i have been there and i know its hard to see that while some guys are having great battery backup and my device is running low on half day passed.
    if u still think you are having problems.
    ill say try resetting everything.
    sometimes that did solved the problem for me.
    i hope same will happen for you.
  10. T1560840681374
    Donut Aug 11, 2019
    T1560840681374 , Aug 11, 2019 :
    T1560840681374
    results after turning GPS off, I have even used flashlight for few minutes due to power outage. Anyways, pretty pleased with the result. Got Screen on time of more than 8 hours.....
    But still stand by time is where battery drain is the most, I think it might be because of my dual sim combination (maybe) that is Jio and Idea.
    I will be moving to Canada in about 15 days and will post results with single sim.​
    hello everyone,
    An update, after moving to Canada (Toronto) I have been getting a decent battery, my phone ate just 3 percentage during last night(on standby for at least 5 hours) with GPS turned on. In India, with similar conditions, my OP7 used atleast 10 percentage. Now I think that Indian communication networks has to do something with it. Ive used Jio, Idea and Vodafone. Im using Rogers here.
    So,
    current battery level 30
    screen usage 4,34 (including usage of navigation for at least an hour which eats a lot of battery in almost every phone)
    last full charge 18 hours ago.
    mahekparmar likes this.
  11. vikadi28
    Cupcake Aug 13, 2019
    vikadi28 , Aug 13, 2019 :
    After the last update my battery has significantly improved.
    Used to give me 5 hrs screen usage, and now it is around 7 almost.
    Battery used to drain in idle mode prior to the update, not it remains stable.
    Good improvement!
  12. G1563068446994
    Cupcake Aug 17, 2019
  13. Muhammed Afeef M
    Froyo Aug 17, 2019
  14. Muhammed Afeef M
    Froyo Aug 17, 2019
  15. O1566115576455
    Cupcake Aug 18, 2019
    O1566115576455 , Aug 18, 2019 :
    one plus 7 camera makes the photo warm and makes the skin tone yellowish in both front and back camera in auto mode.the image quality is also not up to the mark.skin tones are not nautral and it also softens the skin tone.
    moreover it makes the skin tones too dam yellow.
    both in indoor lightining and outdoor lightning it makes the skin tones yellow.
  16. R1563983725214
    R1563983725214 , Aug 18, 2019 :
    oneplus 7 battery backup is too bad . After updating the lastest version 9.5.8 And also call drops are more.Please fix those issue. Battery backup is coming less than 20 hours
  17. K1566131205613
    K1566131205613 , Aug 18, 2019 :
    My OP7 drains upto 8-9% at night even after turning on the airplane mode. What could be the problem ?
    J1560080028751 likes this.
  18. SanjaykSoni
    Donut Aug 19, 2019
    SanjaykSoni , Aug 19, 2019 :
    same problem battery draining very fast in a normal use. not even played high graphics games or watched videos than also it draining in 10-11 hours.
    cruzAD and Rounak95 like this.
  19. Saurabh Verma...
    Cupcake Aug 19, 2019
    Saurabh Verma... , Aug 19, 2019 :
    oneplus 7 lock screen has yellow tint but after unlocking the phone screen becomes normal. how to disable this feature. night mode and read mode is off but still the display at lock screen has some yellow tint. plz help . when I take the screenshot of this yellow tint screen at lock screen the screenshot doesn't have that yellow tint the screenshot is normal. plz anybody help me in this.
  20. cruzAD
    Gingerbread Aug 20, 2019
    cruzAD , Aug 20, 2019 :
    HOLY SHHIT, It sounds terrible. I already ordered my OP 7.
    For the 6T it needed half a year bug fixes and updates to become acceptable. The latest update solved the app freezings, but the private DNS it is still buggy, practically unusable.
    So be damn patient, LoLz... But cry loud, it helps, and allow all Telemetry and bug report, at least for a while ;)
    Srinadh_Palavalasa likes this.
