21
[UNIFIED] oneplus 7 battery and heating feedback thread
  1. Swejuggalo
    KitKat Sep 9, 2019
    Swejuggalo , Sep 9, 2019 :
    Google "Fix Google play services battery drain" and you should find a few tips on what to look for. This seem to happen for many and is not a Oneplus limited issue.
    Pay attention to what apps you have installed for example. If some constantly polls for location... If something fails to sync or failes to backup and so on.
    naresh63 likes this.
  2. naresh63
    Cupcake Sep 10, 2019
  3. naresh63
    naresh63 , Sep 10, 2019 :
    Now issue resolved , i have unchecked google fit and calender in sync options. now battery is good and play store is not consuming battery.
    thanks for the help
    Jai Google
    Swejuggalo likes this.
  4. shashi sunny
    Cupcake Sep 11, 2019
    shashi sunny , Sep 11, 2019 :
    even I'm facing the same problem
  5. DA7801
    Honeycomb Sep 15, 2019
    DA7801 , Sep 15, 2019 :
    Hey guys I'm facing battery issues with the 7
    Earlier i used to get 12-16hrs of battery life now I'm getting 6-9hrs of battery life
    Please drop your suggestions on fixing it
    Thanks
  6. Abinash469
    Donut Sep 16, 2019
    Abinash469 , Sep 16, 2019 :
    can somebody help. Google pay services is using battery like hell though I am not using it.
  7. KathiravanJLR
    Gingerbread Sep 21, 2019
    soulsurfer4life likes this.
  8. N1539239009257
    Cupcake Sep 22, 2019
    N1539239009257 , Sep 22, 2019 :
    Is this normal? I checked the Ampere app. When I plugged the charger it will reach around 3700 ma but will go down and stay at around 1800 ma.
  9. Abinash469
    Donut Sep 25, 2019
    Abinash469 , Sep 25, 2019 :
    Thanks everyone for your help. Problem solved after clearing phone cache.
  10. donPepitoGrillo
    Honeycomb Sep 25, 2019
    donPepitoGrillo , Sep 25, 2019 :
    I don't see Google Pay in your screenshot. Related to Google Play Services, yes, you are using it. Barely all apps use Google Play Services.
  11. Q1569420069628
    Donut Sep 25, 2019
    Q1569420069628 , Sep 25, 2019 :
    When I'm using nightscape then it's capturing but in middle my screen does black and come back to home screen and also getting problem to get video call , it cut my call automatically. Could you please tell me something about this problem
  12. Gstone
    Cupcake Sep 28, 2019
    Gstone , Sep 28, 2019 :
    Well i thought i had battery issues after updating to oxygenos 10, but it seems i was wrong and i judged it too quickly.
    I consider myself a heavy user, always messaging on WhatsApp or I'm watching something on YouTube it's mostly those two.(this particular time i have high 9gag usage and gallery mostly because i watched a movie, but they generally are at 1-3%)
    there are others but not much, audible uses 1%
    so does my music.
    after these screenshots i imagine and expect my battery to last for about 8hs+
    settings:
    WiFi always on
    Bluetooth always on
    adaptive brightness
    location always on
    resolution on auto switch
    90hz display
    dark theme
    NFC always off
    battery saver at 15
  13. lijoans123
    Cupcake Sep 29, 2019
    lijoans123 , Sep 29, 2019 :
    My Mobile. one plus 7 Purchased on 9th September by Amazon. My Problem Heating issue for call and camera shoot time. what solution for this problem.
    Lijo Sebastian
    (edit moderator: You don't write private data)
  14. Cervantes
    Lollipop Moderator Sep 29, 2019
    Cervantes , Sep 29, 2019 :
    Hi
    Please You read the first pos
    The battery thread is a thread of questions and/or commentary
    Thread merged
  15. arunabh22
    arunabh22 , Sep 29, 2019 :
    Today I got new phone from Amazon one plus 7. After 15-20 min continue using feeling heating at upper side.
  16. lekhrajsingh
    Cupcake Sep 30, 2019
    lekhrajsingh , Sep 30, 2019 :
    Same issue here
  17. soulsurfer4life
    Donut Sep 30, 2019
    soulsurfer4life , Sep 30, 2019 :
    Google play services is eating my battery as well. On a regular basis, by the end of the day or when my battery gets down to about 40%, Google play services will have consumed over 50% of my battery.
    I have a OnePlus 6T. The device is only a year old. And, along with other issues, this is becoming one of the worst smartphones I have ever used.
    I don't see myself buying another OnePlus device. I won't be recommending these devices to my friends anymore as well. On my recommendation, there are 6 of us with OnePlus devices. And we are all having issues.
    KathiravanJLR likes this.
  18. mlulic
    Honeycomb Oct 1, 2019
    mlulic , Oct 1, 2019 :
    I see neither of you gave the effort to search the forums or google, right?
  19. Hrid151102
    Cupcake Oct 3, 2019
  20. ChanakyaNeelam
    Eclair Oct 3, 2019
