65
[UNIFIED] oneplus 7 battery and heating feedback thread
  1. Q1569420069628
    Donut Sep 25, 2019
    Q1569420069628 , Sep 25, 2019 :
    When I'm using nightscape then it's capturing but in middle my screen does black and come back to home screen and also getting problem to get video call , it cut my call automatically. Could you please tell me something about this problem
  2. Gstone
    Cupcake Sep 28, 2019
    Gstone , Sep 28, 2019 :
    Well i thought i had battery issues after updating to oxygenos 10, but it seems i was wrong and i judged it too quickly.
    I consider myself a heavy user, always messaging on WhatsApp or I'm watching something on YouTube it's mostly those two.(this particular time i have high 9gag usage and gallery mostly because i watched a movie, but they generally are at 1-3%)
    there are others but not much, audible uses 1%
    so does my music.
    after these screenshots i imagine and expect my battery to last for about 8hs+
    settings:
    WiFi always on
    Bluetooth always on
    adaptive brightness
    location always on
    resolution on auto switch
    90hz display
    dark theme
    NFC always off
    battery saver at 15
  3. lijoans123
    Cupcake Sep 29, 2019
    lijoans123 , Sep 29, 2019 :
    My Mobile. one plus 7 Purchased on 9th September by Amazon. My Problem Heating issue for call and camera shoot time. what solution for this problem.
    Lijo Sebastian
    (edit moderator: You don't write private data)
  4. Cervantes
    Moderator Moderator Sep 29, 2019
    Cervantes , Sep 29, 2019 :
    Hi
    Please You read the first pos
    The battery thread is a thread of questions and/or commentary
    Thread merged
  5. arunabh22
    arunabh22 , Sep 29, 2019 :
    Today I got new phone from Amazon one plus 7. After 15-20 min continue using feeling heating at upper side.
  6. lekhrajsingh
    Cupcake Sep 30, 2019
    lekhrajsingh , Sep 30, 2019 :
    Same issue here
  7. Deactivated User
    Sep 30, 2019
    KathiravanJLR likes this.
  8. mlulic
    Ice Cream Sandwich Oct 1, 2019
    mlulic , Oct 1, 2019 :
    I see neither of you gave the effort to search the forums or google, right?
  9. Hrid151102
    Cupcake Oct 3, 2019
  10. ChanakyaNeelam
    Eclair Oct 3, 2019
  11. donPepitoGrillo
    Ice Cream Sandwich Oct 4, 2019
    mahekparmar likes this.
  12. donPepitoGrillo
  13. Deactivated User
    Oct 4, 2019
  14. mlulic
    mlulic , Oct 4, 2019 :
    So that means you also completely disabled background data usage for Google Play and related services and all google store related sync?
  15. Deactivated User
    Oct 5, 2019
  16. Swejuggalo
    OnePlus 9 Series Expert Community Expert Oct 5, 2019
    Swejuggalo , Oct 5, 2019 :
    Just to make some things clear... This issue pops up on ALL Androids sometimes and is not a Oneplus issue.
    Google "Fix Google play services battery drain" and you will find a ton of possible solutions.
  17. Deactivated User
    Oct 5, 2019
  18. Swejuggalo
    Well... I heard and read about Pixel phones having this issue too. Why would some other brand be immune when Googles own phones are not? That is why I said "all". It haven't spent enough time on other brands forums to know if it's equally as bad on other brands... But an unique problem on just Oneplus devices is certainly not the case.
    I have tried many versions of Oxygen OS, stable 9, developer previews and open beta on 7 Pro. It has has never been the reason for huge drain for me. Neither on any other brand. I don't know what triggers it. All I know is that it's not limited to just Oneplus devices and the reasons behind it seems to be many. Some users have even reverted to using betas to fix issues. Some just needed to disable some of the sync options
  19. Z1570319796393
    Cupcake Oct 6, 2019
    Z1570319796393 , Oct 6, 2019 :
    I have purchase op7 3 days ago working good but while playing pubg it is heating a lot sometimes. I play pubg for about 1 2 hrs and battery is also draining very fast normally is my product not upto mark did i i ne to replace it. Any suggestion
  20. S1564769214712
    Cupcake Oct 6, 2019
