22
[UNIFIED] oneplus 7 battery and heating feedback thread
  1. Saisisindri
    Donut Jan 26, 2020
    Saisisindri , Jan 26, 2020 :
    In my one plus 7 Last 7 days mobile heating was very high,Iam not able to use mobile that time very hot like a stove heat pls solve this issue.
  2. Gowtham_G48
    Cupcake Jan 27, 2020
    Gowtham_G48 , via OnePlus 7 , Jan 27, 2020 :
    I bought my OnePlus 7 on June 17th 2019, and i am a power user. I used to have a OnePlus 5, and i used to charge it in the end of the day always.
    My OnePlus 7 was giving me similar battery stats until i got the stupid Android 10 update.
    I used to get 7 hours of SoT (I'm a power user) on WiFi and a single sim (adaptive brightness off and i almost never cross 50% brightness) but i started getting 3 hours all of a sudden.
    Same amount of apps and the usage🙄
    Now don't give me shit like my battery depends on the usage statistics. I have been using the same apps since day 1. I have actually uninstalled a few games and apps since my battery backup is sucking so badly.
    I visited the service centre on September 28th 2019, and last month and reported my issue both the times. They activated LOGKIT and checked my usage for a few hours and did some service but no use. I'm still getting only 3-4 hours of SoT.
    Worst part is i sold my beautiful Samsung Galaxy S10e because it's battery life was very bad(and that was the ONLY problem i had with that phone compared to my OnePlus 5).
    Now i am charging this device twice or thrice a day. I always recommend Oneplus phones to everyone but now I'm having second thoughts.
    PS - By the time i typed the above rant, my phone dropped 3% and last night my battery was 23% when i slept, and it was at 14% when i woke up (slept for 7 hours with data and wifi off and zero brightness)
    mahekparmar likes this.
  3. gian_nyc
    Eclair Jan 28, 2020
    gian_nyc , via OnePlus 7 Pro , Jan 28, 2020 :
    I agree with the comments above regarding battery life. My Oneplus 7 Pro on Open Beta 8 is seemingly on constant wake lock.. I'm attaching a couple of screen shots from BBS. Anyone has any idea which process could be causing this behavior?
    P. S. My night time battery drain is also very high with screen, obviously, always off.
  4. C1563091050218
    Eclair Jan 29, 2020
  5. P1567582282474
    Cupcake Jan 30, 2020
    P1567582282474 , via OnePlus 7 , Jan 30, 2020 :
    Hi All,
    While I am on the phone and new calls come through, they go straight to voicemail. I don't get any incoming call alert etc etc.
    I have gone through the settings but can't find the answer anywhere! thanks for you help!
  6. leovolpe
    Cupcake Jan 31, 2020
    leovolpe , via OnePlus 7 , Jan 31, 2020 :
    Hello, my OP7s battery is draining over night (35-40%). The strange thing is that I always turn off my device when I go to sleep, how is this possible? Have any of you have this issue?
    https://ibb.co/QdjQMRr
    Here is the link to my battery usage. As you can tell it went from 60% to 20% over night
  7. Z1574070786771
    Cupcake Feb 1, 2020
    Z1574070786771 , Feb 1, 2020 :
    Hello, I just received my OnePlus 7 yesterday but I have a huge problem. I can't charge the phone, or turn it on. When I plug in the charger, I can read "Battery is too low" then nothing. I tried Hard reboot without success.
    Do you have any idea ?
  8. X1580032949899
    Cupcake Feb 1, 2020
    X1580032949899 , Feb 1, 2020 :
    Just bought op7 a week ago and I first charged it 6% to fully charged but my op7 still drain battery fast. Do I really need to charge my phone overnight or just 3-4 hours?
  9. mahekparmar
    Eclair Feb 10, 2020
    mahekparmar , via OnePlus 7 , Feb 10, 2020 :
    Totally agree with you mate.
    Gowtham_G48 likes this.
  10. mahekparmar
    Eclair Feb 10, 2020
    Better Downgrade your Phone to Pie to get superbeb battery backup.
  11. Gowtham_G48
    Cupcake Feb 10, 2020
  12. mahekparmar
    Eclair Feb 10, 2020
  13. T1518500705859
    Donut Feb 12, 2020
    T1518500705859 , Feb 12, 2020 :
    Drain is much rapid than the RapidCharge deployed by OnePlus. Does OnePlus intends to fix this in next upgrade? 7 series have gone seriously bad after 10 update.
  14. Seetharammn
    Cupcake Feb 17, 2020
  15. Gav_W86
    Starting Point Expert Feb 17, 2020
    Gav_W86 , Feb 17, 2020 :
    -5 is the Tethering (wifi hotspot) service.
    akshat120197, keithnyc and gikkka like this.
  16. gikkka
    Froyo Feb 17, 2020
  17. akshat120197
    akshat120197 , Feb 17, 2020 :
    Ya,got to know few days back. Still,thanks for the info.
  18. ankushg92
    Cupcake Feb 18, 2020
    ankushg92 , Feb 18, 2020 :
    battery drains faster in OP7 after 10.3.1 update
    suggest some ways to improve it
  19. K1N6
    Cupcake Feb 22, 2020
    K1N6 , Feb 22, 2020 :
    When I connect my Samsung Galaxy Watch (46mm) Silver (Bluetooth) to one plus 7 It drains battery very fast (100% to 50% in 3 hr without using) please help in this regards. I have other phones too in that it is not draining the battery at this speed (normal).
  20. Shocky
    Honeycomb Feb 25, 2020
    Shocky , Feb 25, 2020 :
    I'm getting around 5 hours SoT between charges, using FHD+ and 90hz, not had any issues with heating at all.
    It's not bad but not great either, haven't tested QHD+ much and probably won't.
