22
[UNIFIED] oneplus 7 battery and heating feedback thread
  1. K1N6
    Cupcake Feb 22, 2020
    K1N6 , Feb 22, 2020 :
    When I connect my Samsung Galaxy Watch (46mm) Silver (Bluetooth) to one plus 7 It drains battery very fast (100% to 50% in 3 hr without using) please help in this regards. I have other phones too in that it is not draining the battery at this speed (normal).
  2. Shocky
    Honeycomb Feb 25, 2020
    Shocky , Feb 25, 2020 :
    I'm getting around 5 hours SoT between charges, using FHD+ and 90hz, not had any issues with heating at all.
    It's not bad but not great either, haven't tested QHD+ much and probably won't.
  3. Tsever
    Cupcake Feb 25, 2020
    Tsever , Feb 25, 2020 :
    after the 10.3.1 update, I am facing with heating and battery drain issues. I am using the same way I used to, but my battery performance seems like dropped to %50. I am generally charging the phone overnight and then unplug it at 6.30 am. Before the update, I could use the phone all day and there are %20 battery remaining. But now, I am reaching %20 at 2.30 - 3.00 PM
  4. tobes
    Ice Cream Sandwich Feb 26, 2020
    tobes , Feb 26, 2020 :
    Oneplus 7 user. I had the Whatsapp battery drain issue in Nov 2019. The issue seemed to have been resolved through a Whatsapp update at the time. Recently (Whatsapp updated 18 Feb 2020) the issue seems to have come back. Whatsapp continuously tops the list of battery consumption by app, despite moderate usage at best. Have tried both settings - Optimize and Intelligent Control.
    Do you face the same issue?
    Whatsapp version: 2.20.47
    Oxygen version: 10.0.1.GM57BA
    Device: Oneplus 7 GM1903 (8GB ram)
  5. ankushg92
    Cupcake Feb 26, 2020
    ankushg92 , Feb 26, 2020 :
    i have tried ccleaner to clean cache and force stop all the apps..after that cleaned the wipe cache and partition..thats solved my battery issues completely..back to normal battery usage..
  6. T1518500705859
    Donut Feb 26, 2020
    T1518500705859 , Feb 26, 2020 :
    ankushg92
    i have tried ccleaner to clean cache and force stop all the apps..after that cleaned the wipe cache and partition..thats solved my battery issues completely..back to normal battery usage..​
    how to clean the wipe cache and partition?... after doing,how are the battery stats?
  7. Abhijeetp33
    Cupcake Feb 27, 2020
  8. Praty_28
    Jelly Bean Feb 27, 2020
    Praty_28 , Feb 27, 2020 :
    Post a screenshot of battery statistics from settings>>battery. Also, before taking screenshot turn on show full device usage from the 3 dot menu on the top right of battery usage section.
  9. Liehjan
    Lollipop Feb 27, 2020
    Liehjan , Feb 27, 2020 :
    The phone drains battery even in stand by, can you post screenshots of battery usage?
  10. Cervantes
    Lollipop Moderator Feb 27, 2020
    Cervantes , Feb 27, 2020 :
    Hi
    Please use this thread for questions and comments on the battery topic
    Use the search engine before opening a new thread
    Thread merged
    mahekparmar likes this.
  11. JayeshRaghani
    Donut Feb 29, 2020
    JayeshRaghani , Feb 29, 2020 :
    after updating to latest version on my op7 battery life is not good as it was further and in notification panel notes is running notification is coming again and again if anyone knows how to solve this problem please tell me
  12. G_pranav_malik_PLtW
    Cupcake Mar 2, 2020
  13. T1518500705859
    Donut Mar 3, 2020
    T1518500705859 , Mar 3, 2020 :
    OP7 Indian users, Please post your battery stats, which could gauge the battery issue better .
  14. ankushg92
    Cupcake Mar 3, 2020
  15. sureetc
    Donut Mar 11, 2020
    rafab21 and mahekparmar like this.
  16. ankushg92
    Cupcake Mar 12, 2020
    ankushg92 , Mar 12, 2020 :
  17. ak441983bhel
    Cupcake Mar 14, 2020
  18. T1518500705859
    Donut Mar 14, 2020
  19. G_Anwar_Khalife_oTli
    Eclair Mar 20, 2020
  20. rafab21
    Cupcake Mar 23, 2020
    rafab21 , Mar 23, 2020 :
    Battery is draining so much while not in use. Draining so fast in standby mode. I've tried airplane mode, nothing is changed. I tried resetting and cleared cache. But nothing happened. I am really annoyed with this new update 10.3.1[Oneplus7 12/256]
