52
[UNIFIED] oneplus 7 battery and heating feedback thread
  1. ankushg92
    Eclair Mar 3, 2020
  2. sureetc
    Donut Mar 11, 2020
    rafab21 and mahekparmar like this.
  3. ankushg92
    Eclair Mar 12, 2020
    ankushg92 , Mar 12, 2020 :
    i have tried ccleaner to clean cache and force stop all the apps..after that cleaned the wipe cache and partition..thats solved my battery issues completely..back to normal battery usage..
  4. ak441983bhel
    Cupcake Mar 14, 2020
    mahekparmar likes this.
  5. T1518500705859
    Eclair Mar 14, 2020
  6. BunnyStranger
    Cupcake Mar 17, 2020
  7. G_Anwar_Khalife_oTli
    Eclair Mar 20, 2020
  8. G_Mukund_Badhe_tEXf , via OnePlus 7 , Mar 23, 2020 :
    hey guys my OnePlus 7 is randomly heating and gets very lagy
    I tried everything even factory reset
    I think this is the software problem I am on oxygen os 10.3.0
    please help me how can I downgrade to 10.1.0 of any other version of oxygen this version is very unstable with also random apps crashes
    please help!
  9. rafab21
    Donut Mar 23, 2020
    rafab21 , Mar 23, 2020 :
    Battery is draining so much while not in use. Draining so fast in standby mode. I've tried airplane mode, nothing is changed. I tried resetting and cleared cache. But nothing happened. I am really annoyed with this new update 10.3.1[Oneplus7 12/256]
  10. I1585385723702
    Cupcake Mar 28, 2020
    Ni3_chavan likes this.
  11. R1545921808385
    Cupcake Apr 1, 2020
  12. G_Pegasus_on_Road_MYgS
    Cupcake Apr 1, 2020
  13. Mitesh_kareliya
    Cupcake Apr 4, 2020
    Mitesh_kareliya , Apr 4, 2020 :
    my oneplus 7 getting hot while playing games like pubg or during charge. sometimes fast charge stopped working while playing. i have tried playing without case but its seems very hot back panel and sides though its difficult to hold in hands after 15 mins of gameplay.
  14. J1577693231083
    Cupcake Apr 5, 2020
    J1577693231083 , via OnePlus 7 , Apr 5, 2020 :
    dear OnePlus authority I purchased this phone on last auguest ,the problm I seen that the battery drains very quickly I getting 7 hrs after my full charge ,I lost my hope about OnePlus this is very costly one I'didnt get enough power back
  15. Manojprathap
    Cupcake Apr 5, 2020
  16. S1561822102449
    Donut Apr 7, 2020
    S1561822102449 , Apr 7, 2020 :
    I don't know what happened with my phone but now heating issue is more coming in oneolus 7 after 10 month use
  17. raj3104__
    Cupcake Apr 7, 2020
  18. Cervantes
    Moderator Moderator Apr 7, 2020
    Cervantes , Apr 7, 2020 :
    Hi
    man, how can I fix your phone, you don't say anything
    Please, use this thread for battery problems
    for another user to give you a suggestion, upload a screenshot of:
    battery and another of battery uses
    Use the search engine before opening a new thread
    Thread merged
  19. G_dinesh_subbiah_lSls
    Donut Apr 11, 2020
    G_dinesh_subbiah_lSls , Apr 11, 2020 :
    hi, I am observing heating issue when charging, when using some vdo apps like you tube, MX player etc, also heating issue some time using any other app continuously even in wifi. when using Google maps in mobile data it get heats alot.
  20. Philipp30
    Cupcake Apr 13, 2020
    Philipp30 , via OnePlus 7 , Apr 13, 2020 :
    parag008
    just yesterday night.
    it will get in rhythm soon.
    keep using your device as usual and use some battery saving measures.
    Like disabling background apps, disabling background sync for unnecessary apps etc etc.
    using dark themes and all that.​
    Hey,
    I was wondering what settings you're running on to achieve that insane battery life. I too have an OP7, all the apps but the ones i use frequently are optimized (my most used apps are on intelligent control), the display is on 60% brightness and I only have wifi and bluetooth turned on. Still, I only get around 5 hours of display on screen time with the phone lying around quite some time throughout the day. When I'm outside and running data it's even worse...
    (note: I'm using the phone for half a year now)
    Maybe you have some tips & tricks for me
    Thanks a lot
