59
[UNIFIED] oneplus 7 battery and heating feedback thread
  1. runforfun
    Gingerbread Jul 3, 2020
    runforfun , via OnePlus 7 Mirror Gray , Jul 3, 2020 :
    Please give me a Solution...[e]1f61e[/e]
  2. Artemus.
    Community Hero 2020 Jul 3, 2020
    Artemus. , Jul 3, 2020 :
    There is no solution, it's just how batteries work. If it's at ~70% down from ~80% this is completely normal.
    runforfun likes this.
  3. runforfun
    I'm changing the battery 20% to 80% , is it good or bad to the Battery life..?
  4. Artemus.
    Good. The longer you keep it on the charger the better.
  5. runforfun
    Artemus. likes this.
  6. SwastikaSom
    Cupcake Jul 5, 2020
    SwastikaSom , Jul 5, 2020 :
    I updated my op7 to oxygen os 10.3.3 and then to op 15 beta. and also did a factory reset but the battery is draining like crazy. I used to charge it once in two days but now i have to charge it every 8 hours. the battery drains even when the phone is left unused. this is so not worth the money. i also emailed the company with the same but never got a response.
    Detrab1 likes this.
  7. Muhammed Afeef M
    Gingerbread Jul 6, 2020
  8. GreyWolfUA
    Cupcake Jul 7, 2020
    GreyWolfUA , Jul 7, 2020 :
    so after 3times a day charging experience for last 2 weeks after system update i did a hard reset. it's really painful thing as a lot of credentials for apps was lost, but now, the power consumption dropped tremendously! I can use the phone from the morning till night without a charging. The only Hard reset is the savior in this problem.
  9. jayantsingh0680@
    Cupcake Jul 7, 2020
    jayantsingh0680@ , Jul 7, 2020 :
    As in past fews days I have observed that my phone i.e OnePlus7 battery backup has been reduced battery is draining very fast so plz fix this problem asap..
    Muhammed Afeef M likes this.
  10. SP207
    Cupcake Jul 8, 2020
    SP207 , via OnePlus 7 , Jul 8, 2020 :
    While charging, my OnePlus 7 got heat up quickly....while browsing, playing games it's usually happens but for after continuous use..but since 1 months or above..I have noticed that it's get heat up easily in 5 to 10mins while charging..
    please resolve this..
  11. R.Peter
    Ice Cream Sandwich Jul 8, 2020
    R.Peter , Jul 8, 2020 :
    What happened a month ago that could cause the problem you described? Just to narrow down the issue a bit.
    xnutzii and Artemus. like this.
  12. M1584302034478
    Cupcake Jul 12, 2020
    M1584302034478 , Jul 12, 2020 :
    Try AccuBattery or Aida64 to check the specs and health of your battery
    Using AccuBattery i found out that my battery lost ~10% in 9 months.
  13. starboy1910
    Froyo Jul 16, 2020
    starboy1910 , via OnePlus 7 , Jul 16, 2020 :
    Same here bud
  14. starboy1910
    Froyo Jul 16, 2020
    Ok guys here what all I have noted about the latest 10.3.3 update about the improvement, suggestions and bugs about it regarding the battery life after 10.3.3.
    1) Improvement of RAM management has been made in the latest update which sounds good but it is the quite opposite of good. RAM management improvements here keep your apps stored in your RAM for much longer than usual or needed. Like for eg. If you open a set of apps before sleeping and leave it open you'll find that all those apps will stay open even after you wake up, they're still open; hence more drop in your % overnight and very bad standby battery drain (seriously everybody's got this problem) This keep your apps running in the background all the time. Yes the RAM management has improved but I don't remember seeing any post about asking for improvements for RAM management before. It was already good for what we had but now this improvements has only made things worse so I request the devs to please look into this.
    2) lot's of bugs have been reported by me and also there are many posts pointing out the bugs in the r/Oneplus sub in reddit. I was shifting to stable 10.3.3 from beta 14 and after resetting my phone after installing the 10.3.3 I found that all the default wallpapers from the launcher were gone. Tried everything. Clearing cache, storage... Everything... But then I had to reset again only to be finding this again. Again I had no default wallpapers. By the time beta 15 had arrived so I migrated there.
    3) just when are you planning to fix the bug of this SMS backup in the automatic back-up section? The SMS won't even backup automatically. We need to manually press the backup for even the SMS to backup. Like wow guys I'm surprised that you guys didn't fix it even now and I've seeing this since the 10 release. Why OnePlus!!!
    4) sometimes after turning the dark mode on the keyboard won't abide by the system rules and not turn dark but stay white and sometimes it does. Like why is this happening?
    5) In every beta release I have seen that even system apps and default apps can be set to optimise like chrome, YouTube, Netflix, gallery etc... So why not give this feature to stable too. It was already present in your android pie version. Then why not add this feature in your next release also?
    6) double tap to wake up doesn't work half of the time and when in pocket many accidental touches also one touch to wake Ambient display works only when it wants to not everytime. Please fix that too
    7) taking just 5 photos with flash on heats up the phone as much as when playing COD or PUBG for 2 hours straight. Why!!!
    8) just give us smooth scrolling guys looks so dope in beta release.
    There can be more but this is what I've noticed so far.
    Thank you.
  15. G_pranav_malik_PLtW
    Cupcake Jul 17, 2020
  16. sagar_nk
    Cupcake Jul 22, 2020
    sagar_nk , Jul 22, 2020 :
    Really very bad impression : i bought one plus 7 last year in November and getting issue in its power within 8 month of usage.I do not know whether its port issue or software issue.This is the first time i try to use one plus leaving apple like brand .Now i am repenting over my decision.I had a huge expectation over this brand 😞 .and there is no response from customer care as well.please contact me 9937049470
  17. Alimohammad005
    Cupcake Jul 25, 2020
    Alimohammad005 , Jul 25, 2020 :
    one plus 7 Purchasing in Oct 2019 which have some battery draining issue I don't know whether it is a battery problem or Some bugging issue. kindly give us an update to improve battery capacity.
  18. Cervantes
    Moderator Moderator Jul 25, 2020
    Cervantes , Jul 25, 2020 :
    Hi
    Please, check and use this thread for battery questions and comments, read the first post
    Use the search engine before opening a new thread
    Thread merged
  19. Aman351
    Donut Jul 25, 2020
    Aman351 , via OnePlus 7 , Jul 25, 2020 :
    What's app is now draining a lot of battery. There seems to be issue with One plus 7 beta updates. After every few days, any app starts consuming battery like hell. Pls see.
  20. F_Rishank_Gupta_QzKW
    Froyo Jul 26, 2020
