73
[UNIFIED] oneplus 7 battery and heating feedback thread
  1. Daniele_Tosco
    Cupcake Jun 4, 2021
  2. Daniele_Tosco
    Cupcake Jun 4, 2021
  3. Iamhasannaqvi
    Ice Cream Sandwich Jun 4, 2021
    Iamhasannaqvi , via OnePlus 7 , Jun 4, 2021 :
    Is it due to Media Storage?? Have you checked which app is causing the battery drain. If it is the Media Storage ensure there is nothing happening in background i.e. downloading, app running in background etc. This would drain the battery and heat up the device.
    If this does not resolve the issue. I would suggest doing a hard reset. Ensure to backup your data. This would surely fix the issue. If not than only option is to submit a feedback via forum so that someone from OnePlus can help resolve the issue.
    Daniele_Tosco likes this.
  4. Tmjd
    Cupcake Jun 6, 2021
  5. Ravan06
    Cupcake Jun 8, 2021
    Ravan06 , via OnePlus 7 , Jun 8, 2021 :
    I have OnePlus 7 and I am facing heating issue. At normal use its temperature is above 40°c and at the time of gaming and using heavy apps it temperature is reaches around 46-47°C.
    Please help to resolve this problem.
    Anks Lee likes this.
  6. bikashpu89
    Froyo Jun 8, 2021
  7. J1587241867456
    Cupcake Jun 8, 2021
    Anks Lee and bikashpu89 like this.
  8. bikashpu89
    Froyo Jun 8, 2021
  9. I1586358716926
    Cupcake Jun 11, 2021
    I1586358716926 , via OnePlus 7 , Jun 11, 2021 :
    A new phone needs to rebuild cache for system and all apps. This is taking time and power.
    A new battery will need 3-4 full charge/discharge circles to get its full capacity.
  10. imdeiv
    Eclair Jun 12, 2021
    imdeiv , via OnePlus 7 , Jun 12, 2021 :
    After Android 11 update i am facing this issue. i have updated latest update.
    i have tried all fixes
    - Reset
    - Factory reset
    bikashpu89 likes this.
  11. karim.Fadel
    Gingerbread Jun 12, 2021
    karim.Fadel , via OnePlus 7 Pro , Jun 12, 2021 :
    Do you have India or EU
    That happened with me when I was using India software so I reflash my OnePlus 7 pro with the European software and that's fixed my problem with the heating it's heating now but not like with the Indian software it's a big difference so try to flash the European version off the software
    imdeiv likes this.
  12. Artemus
    Junior Moderator, Community Hero 2020 Junior Moderator Jun 12, 2021
    Artemus , Jun 12, 2021 :
    Turn down the graphics.
    imdeiv likes this.
  13. imdeiv
    Eclair Jun 12, 2021
  14. Artemus
    Actually, it is. If you're playing on extreme graphics, it's gonna use the GPU more, resulting in more heat. Why not give it a try?
  15. imdeiv
    Eclair Jun 12, 2021
    one plus 7 capable for extreme FPS... IM NOT PLAYING WITH HDR MODE.. EVEN IN BALANCE MODE IT ALSO HEATING
  16. Artemus
    It might be capable but you're gonna have to deal with the consequences of it. Graphically-intensive games will cause the SoC to start heating up on all devices. It's why gaming-centric phones come with an external fan attachment.
    imdeiv likes this.
  17. imdeiv
    Eclair Jun 12, 2021
    Yup You are right. But What If I Install Eu Version??
  18. Artemus
    Doubt that'd have much of a difference but worth a try, I suppose.
    imdeiv likes this.
  19. imdeiv
    Eclair Jun 12, 2021
    Thank You Buddy😐😐😐 im confused now
  20. Deepak2610
    Cupcake Jun 13, 2021
