73
[UNIFIED] oneplus 7 battery and heating feedback thread
  1. M1572000549100
    Cupcake Jun 13, 2021
    M1572000549100 , via OnePlus 7 , Jun 13, 2021 :
    After the latest update of OS11, I have noticed that my phone battery is draining very quickly. Now I need to charge my phone twice a day despite the same usage as before. Look into this matter. It's a serious issue and need to be addressed immediately
  2. Arvi08
    Cupcake Jun 15, 2021
    Arvi08 , via OnePlus 7 , Jun 15, 2021 :
    Never Expected The Poor Experience From OnePlus.
    Ram management is not upto the mark
    Battery Drains In jet speed
    Full Of bugs
    Lag
    No AOD till now
  3. gdsingh94
    Jelly Bean Jun 15, 2021
    Artemus likes this.
  4. KluGe
    Lollipop Jun 15, 2021
    KluGe , Jun 15, 2021 :
    When was the last time you used Search ?
    Did you ever use it?
    Did you read our forum rules?
    All you wrote is known and already discussed.
    Please respect our forum rules and do not create redundant and therefore useless new threads!
    Artemus likes this.
  5. V1560165685313
    Honeycomb Jun 15, 2021
    V1560165685313 , via OnePlus 7 , Jun 15, 2021 :
    My OnePlus device is still under 2 years of warrenty and I found that my battery is not working so good like before.
    I used OnePlus diagnosis app and battery health is only 79% with Mark as Serious loss. Please refer attached screenshot.
    Will service center replace the battery or not???
    Service center is 60km away from my location and that is not good to go if they just give excuses
  6. Mr. BG
    Welcoming Expert, Community Hero 2020 Community Expert Jun 15, 2021
    Artemus and Tobikage like this.
  7. KarthikChikki
    Gingerbread Jun 15, 2021
    shoera likes this.
  8. Mr. BG
    Mr. BG , Jun 15, 2021 :
    Lithium Ion battery degradation is normal, 80% capacity after 500 load cycles is normal. To have longevity keep the charge between 20-80%. Do not overcharge or deep discharge as that significantly reduces battery life. This is considered normal wear and tear is generally NOT covered by warranty.
    Also, the community is for and by members, we are NOT staff, Customer Support or Devs..
  9. Tobikage
    Nougat Jun 15, 2021
    Tobikage , Jun 15, 2021 :
    Refer the same answer above your reply.
    Artemus and Mr. BG like this.
  10. McJader
    Marshmallow Jun 15, 2021
    McJader , Jun 15, 2021 :
    Did you check it again at a different battery percentage?
    Because at that time the battery percentage was also 79%:rolleyes:
    Artemus likes this.
  11. V1560165685313
    Yes yes . It was I would say coincidence.. battery is already 80% since last 2 weeks ans it is getting degraded
    McJader likes this.
  12. McJader
    Artemus likes this.
  13. V1560165685313
    I discussed with customers care and they toll that you can go and replace as your device is under warranty.
    Anything below 80% is not heathy and you have complete 2 years of warrenty for device which is not expired yet..
    Any comments will be welcomed
  14. Tobikage
    Nougat Jun 15, 2021
    Go get it replaced then ? o_O
    Artemus, McJader and V1560165685313 like this.
  15. Mehsan23
    Mehsan23 , Jun 15, 2021 :
    Any solution yet? I didn't have this problem when my phone was empty. But now that I have a few pictures and videos in my phone, it drains 30-40% of my battery. Please patch this quick OnePlus. Either add an option to downgrade to android 10 or delete this app. ASAP.
  16. Harsha_prabhakar_udupi , via OnePlus 7 Pro , Jun 16, 2021 :
    Hi, can you share apk link of the OnePlus diagnosis app?
  17. V1560165685313
    Honeycomb Jun 16, 2021
  18. V1623766838612
    Cupcake Jun 16, 2021
  19. KarthikChikki
    Gingerbread Jun 16, 2021
  20. Sooraj1803
