10
[UNIFIED] oneplus 7 battery and heating feedback thread
  1. nasirh009 Cupcake Jul 5, 2019
    nasirh009, Jul 5, 2019 :
    I face the same problem. Phone heats up when playing pubg more than 30mins. Battery also drains faster even when using light apps like whatsapp.
    #81
  2. TarveshChauhan Eclair Jul 5, 2019
    TarveshChauhan, Jul 5, 2019 :
    exactly same i m facing ×.
    heating problem is also there
    #82
  3. Zshah007 Cupcake Jul 6, 2019
    Zshah007, Jul 6, 2019 :
    Hi, can anyone help here. So when I keep my phone as idle before sleeping and whenever I get up in the morning, the battery level falls upto 6 percent even though I keep it on flight mode. I did clear the cache files but no luck. It is normal or if not then can someone help me with this one ?
    Thank you in advance.
    #83
  4. Axay123 Cupcake Jul 7, 2019
    Axay123, Jul 7, 2019 :
    Yeah so basically I got the latest update and..
    1. Phone heats up when playing pubg
    2. Seemingly lesser SOT.
    I played pubg on 60fps,HDR. The phone can handle it but it overheats.
    *oh, phone will heat up when it's under performance*
    Then what's the point of packing in an 855 when it can't be utilized to the max? S10 doesn't overheat. Poco, running an older, higher power consuming processor doesn't heat up much.
    I'm inclined to believe some updates can fix this and it ain't a hardware bottleneck.
    #84
  5. Swejuggalo Ice Cream Sandwich Jul 7, 2019
    Swejuggalo, Jul 7, 2019 :
    I've tried this on my phone and 2 previously owned phones. It gives you a pretty good idea of how good the heat dissipation works.
    If it starts to lower the frequency very early it could be a hardware issue.
    Should look something like this if it preforms good. 15 minutes is the recommended run time.
    #85
  6. Amit7678 Eclair Jul 7, 2019
    Amit7678, Jul 7, 2019 :
    inspite of charging the one plus 7 full the battery is getting drained quickly
    #86
  7. Maverick2.0 Jelly Bean Jul 7, 2019
    #87
  8. T1560840681374 Donut Jul 8, 2019
    #88
  9. Maverick2.0 Jelly Bean Jul 8, 2019
    Maverick2.0, Jul 8, 2019 :
    Facebook, Instagram, Snapchat, Hike, WhatsApp - wow! Look, social media apps are massive battery hogs. I would say you are getting excellent battery life.
    #89
  10. T1560840681374 Donut Jul 8, 2019
    T1560840681374, Jul 8, 2019 :
    I agree, but hike and WhatsApp mostly goes in a hibernate type of condition, because they don't show any notification or message, not until I use one of them.
    still if I calculate the percentage of all the apps that have used battery it is about 50% while the rest half is eaten by standby itself which is quite weird as my friend's OP6t uses only about 2 to 3 percent while in standby whereas mine one eats about or more than 10 in the same time
    #90
    J1560080028751 likes this.
  11. G_Srimanth_Yarlagadda_Oj Eclair Jul 8, 2019
    #91
  12. miss4chewN8 Froyo Jul 8, 2019
    #92
  13. T1560840681374 Donut Jul 8, 2019
    #93
  14. Amitp1998 Honeycomb Jul 8, 2019
    Amitp1998, Jul 8, 2019 :
    no he didn't because he is just fooling around
    #94
  15. miss4chewN8 Froyo Jul 8, 2019
    miss4chewN8, Jul 8, 2019 :
    sorry should have done it in the first place.
    moreover the upward spike you see is actually when I connected my phone to pc
    #95
  16. Amitp1998 Honeycomb Jul 8, 2019
    how do u let yourself to not charge your phone for 3 day ..?
    #96
    karanvijaysingh likes this.
  17. miss4chewN8 Froyo Jul 8, 2019
    this is a new phone, so as to calibrate the battery I use it from 100 to 0
    #97
  18. miss4chewN8 Froyo Jul 8, 2019
    also, I have been doing this for only 2 times, I'll do it once more to completely calibrate the battery
    #98
  19. Sanyam0108 Donut Jul 9, 2019
    Sanyam0108, Jul 9, 2019 :
    I am also having battery drain. 7-9% battery drain overnight. every 2-4 minute, 1% battery drain when I am using the phone even for the normal usage. Brought my phone recently.
    Oxygen OS Version: 9.5.6.GM57AA
    #99
  20. Jenish_1309 Cupcake Jul 9, 2019
