10
[UNIFIED] oneplus 7 battery and heating feedback thread
  1. onslow Eclair Jul 16, 2019
    onslow, Jul 16, 2019 :
    Hi guys. i am the thread starter !
    The battery unfolded its full potential after aprox. 10 chargings
    Awesome batterylife now !
    Thank you all
    AkhilCherukuri likes this.
  2. AV82 Cupcake Jul 16, 2019
    AV82, Jul 16, 2019 :
    Hi, on a completely different topic is there a way to change the date and time format. Mine is on the US format and want it to change to UK format. For example i have the message conversations saved as 07/15/19 instead of 15/07/19
  3. S_Govardhan_Reddy Gingerbread Jul 16, 2019
    S_Govardhan_Reddy, Jul 16, 2019 :
    today I got op7 in my hands , I'm so happy
  4. T1560840681374 Donut Jul 17, 2019
    T1560840681374, Jul 17, 2019 :
    results after turning GPS off, I have even used flashlight for few minutes due to power outage. Anyways, pretty pleased with the result. Got Screen on time of more than 8 hours.....
    But still stand by time is where battery drain is the most, I think it might be because of my dual sim combination (maybe) that is Jio and Idea.
    I will be moving to Canada in about 15 days and will post results with single sim.
  5. Jaideep27 Cupcake Jul 17, 2019
    Jaideep27, Jul 17, 2019 :
    I am not satisfied with the op7 interms of battery and battery drain per night is 10%
    J1560080028751 likes this.
  6. Camica Donut Jul 17, 2019
    Camica, Jul 17, 2019 :
    Guys look at my Ghost Touch Issues with my OnePlus 7:
    I tried to contact OnePlus or make a new thread but nothing helps. They need to make an update.
  7. _udayraj_ Froyo Jul 18, 2019
    _udayraj_, Jul 18, 2019 :
    You need to replace your phone. Contact OnePlus customer service.
  8. donPepitoGrillo Gingerbread Jul 18, 2019
    donPepitoGrillo, Jul 18, 2019 :
    Hi guys,
    Last day I think I had a good battery life since I bought my OnePlus 7. But now it's again with a poor battery life. I have noted that last day Google Play Services was not active (in stats), but now it's increasing in section "while in active use" even though I put my phone in flight mode. What's up with Google Play Services? I have factory reset my phone but it's with same issue.
    Could you tell me if you have same issue with Google Play Services?
  9. Camica Donut Jul 18, 2019
    Camica, Jul 18, 2019 :
    I already ordered a new one on Amazon but it has the exact same Problems. So I thought every device has these kind of problems and they just need to update the software.
  10. _udayraj_ Froyo Jul 18, 2019
    I do also use OnePlus 7 but I don't have any issue. Mine's perfect.
  11. Camica Donut Jul 18, 2019
    Okay, thank you. I will contact the Costumer Service :)
  12. zaheentj Cupcake Jul 19, 2019
    zaheentj, Jul 19, 2019 :
    I'm facing severe Battery Drain by Google Play Services on OnePlus 7 for the past week or so. It started a couple of days ago, and I see its getting worse over time. I hardly get 2-4hrs screen time, and I don't play any games.
    Device OnePlus 7
    running oxygen OS 9.5.6
  13. chandra_vsl143 Cupcake Jul 19, 2019
    chandra_vsl143, Jul 19, 2019 :
    Even i am facing same issue when i contact customer care there is no proper responce and suggested to go to service center
  14. Poussin16 Froyo Jul 20, 2019
    Poussin16, Jul 20, 2019 :
    hi bro,
    I received my phone yesterday. from Hong Kong. . I'm a French user.
    I 'm facing on security issue. I have op7 9.5.6. I have code pin and fingerprint Turned on. but I can unlock my phone by slide.
    I have padlock logo (opened)
    did you let this issue? can you please help me.
    Thanks.
  15. ShibeShibe Donut Jul 20, 2019
    ShibeShibe, Jul 20, 2019 :
    This isn't the right thread to post your question on, but is your Smart Lock on your phone on?
  16. Poussin16 Froyo Jul 20, 2019
    Hi,
    sorry I'm starting on the forum. I received my phone yesterday.i didn't find the correct post.
    but yes, I turned it on.
    but I remarked,even if I adjusted lock screen immediately, screen is locked after several seconds (20s,maybe more).
    thanks for your help.
  17. ShibeShibe Donut Jul 20, 2019
  18. L1560002248541 Cupcake Jul 23, 2019
    L1560002248541, Jul 23, 2019 :
    Its been almost 2 months Im using OP7 .Im experiencing pathetic battery performance . Refer the screenshot : It is showing as if it were fully charged even though I charged it till 88% only . Any suggestions or help how can I improve my battery performance ?
  19. ShibeShibe Donut Jul 23, 2019
    ShibeShibe, Jul 23, 2019 :
    It shows 88% charged? I'm not exactly getting what you're trying to say. Have you turned on battery saver?
  20. L1560002248541 Cupcake Jul 23, 2019
    ShibeShibe
    It shows 88% charged? I'm not exactly getting what you're trying to say. Have you turned on battery saver?​
    It was charged till 88% only . But last full charge is showing as 0 mins ago which means it is considering 88% as a full charge .
