104
[UNIFIED]OnePlus 9 Battery, heating and charging feedback thread
  1. Caomhin
    9 Series Expert, Participator of the Year Community Expert Apr 22, 2021
    Caomhin , Apr 22, 2021 :
    Please use this thread for any questions, SOT, tips, issues, and all things related to battery, heating, and charging of the OnePlus 9.
    Please note that the way you use the phone (daily usage scenarios and habits) will make a huge difference to the battery/heating performance. In a scenario where there is a heavy performance workload, such as photo shooting/video shooting/mobile gaming/video consumption, the power consumption and heating of the phone will increase accordingly, which is a normal phenomenon.
    There are also many other factors that can affect battery and heat, even ambient air temperatures above 25°c+ can slow down charging or cause heat issues, as the air temperature gets hotter the phone cannot dissipate heat as quickly so may even slow the charging down as a safety measure as well.
    You are more than welcome to share any battery and charging tips and tricks in the comment section and ask a forum moderator to pin your post on the first page of this thread.
    Also, please do check the links below for suggestions on alleviating any battery, heat, and charging issues. Along with more details on improving your experience with the OnePlus 9.
    Here are some tips to Optimise the use of your phone. This may help with many phone issues.
    Battery optimization never ends. To help OnePlus better resolve battery/heating-related issues, please submit a bug report via the Feedback Tool in the Community app or https://forums.oneplus.com/feedback
    Thank you for your participation in improving the OnePlus experience.
  2. #2
  3. Caomhin
    Caomhin , via OnePlus 6T , Apr 22, 2021 :
    Clear the OnePlus Camera App info Cache and App info Storage.
    Also clear the OnePlus Camera Service App info Cache and App info Storage as well.
    Restart the phone
    Check the links in the original post above for suggestions on improving heat issues.
  4. Rohit_vs_94 , via OnePlus 9 Pro Stellar Black , Apr 22, 2021 :
    I drained the battery to zero and charged it to 100% and kept over one hour after that and then used the phone also updated to the latest version [Had just got the update and updated before the battery drain to 0] and now it's actually much better. Now 5% drain overnight. Unlike 11% before. Then you for the answer it really helped😁😁
    MakB likes this.
  5. Hani90
    Eclair Apr 22, 2021
    Hani90 , Apr 22, 2021 :
    I got charging problems with my new Oneplus 9. First of all, when charging at home with wall charger that i got when buying the phone, i get 3860 mA. When charging with original car charger i get 1600 mA. It is SLOW AS f.... When i charged with my 7t on car, it charged the same speed at home.
  6. Caomhin
    What is the wattage rating for the car charger? And is it a USB C 2 type charger or USB C 3.1? This will also have an effect.
    Battery is bigger in the OnePlus 9. And the car charger will only charge at the wattage it is rated for.
  7. Hani90
    Eclair Apr 22, 2021
    I don't know about that. I just know it is the original from Oneplus that i bought. IMG_20210422_120659.jpg
  8. Caomhin
    If it is this one.
    https://www.oneplus.com/ie/product/oneplus-fast-charge-car-charger
    As it's fast charging between 3.4v-5.0v and 3.5Amp you just multiply the 2 figures to get the wattage.
    Fast charge will be between 12w and 18w through the charger.
    Standard charge would be 10w.
    If it is Fast charging in a wall socket at 65w and it takes 30 to 40 mins, then the fastest the car charger will charge the OnePlus 9 in the car will be less than a third of that at 18w. Take 40 mins multiply it by 3.3 and it could take up to 2 hours in the car to charge. That's just a limitation of the charger not the obone
  9. Caomhin
    L1621144382968 likes this.
  10. Hani90
    Eclair Apr 22, 2021
    But its funny when i had 7T it charged the same at home and in the car.
    Caoimhín likes this.
  11. Caomhin
    Not sure why that would be, as the output in the car charger is limited to a max of 18w. Anyway, check out the link to the charger Tests above. Lot of info there.
    SHIBUAKURIAN likes this.
  12. Hani90
    Eclair Apr 22, 2021
    I know. I checked that site with charging speeds. Normally i should have 6080 mA but i only get 3080 mA.
    And the other site you sent me doesn't work. But it links to Oneplus website
  13. Caomhin
    If the wall charger is charging slower than necessary, it can be down to a number of factors as mentioned in my original post at the top of the thread.
    But if these are not factors in your case. Please give Feedback on the issues back to the OnePlus OOS developers. So that they can investigate them. Thank you.
    Community App Feedback tool
    You can also contact [email protected]
    K1624927311539 likes this.
  14. Hani90
    Eclair Apr 22, 2021
    Thank you. I have written an email. If i still get this slow charging i will try to write to Support. Meanwhille i will wait for the next update to fix this problem.
  15. MakB
    Honeycomb Apr 22, 2021
    MakB , via OnePlus 9 , Apr 22, 2021 :
    Great.. Enjoy your phone dear. 👍
    Rohit_vs_94 likes this.
  16. SarthakGupta2912
    Eclair Apr 22, 2021
    SarthakGupta2912 , via OnePlus 9 , Apr 22, 2021 :
    I have purchased Oneplus 9, 3 days ago but the battery is draining rapidly.
    I am using Oneplus since past 3 years but this is the first time i am facing this issue. I even tried caliberating the battery but it didn't worked.
    Oneplus 9 has the latest snapdragon 888 which works on 5nm which means it should be more efficient in terms of power consumption but currently its draining battery like a flowing river !!
    Kindly send an update with a solution to it.
    pshverma847, Ab_Mateen and 2Retro like this.
  17. pablofg1978
    Head Moderator Head Moderator Apr 22, 2021
    pablofg1978 , Apr 22, 2021 :
    Thread merged
  18. Lucille
    Gingerbread Apr 22, 2021
    thomasmatheo59 likes this.
  19. #20
    Hasantha_94 likes this.
