76
[UNIFIED]OnePlus 9 pro Battery, heating and charging feedback thread
  1. Mohammed shoaib 1001 , via OnePlus 9 Pro , Oct 16, 2021 :
    Recently I purchased OnePlus 9 pro and I am facing issue.....my phone heats everytime in my hand and everytime I charge my phone to 100 it discharge within 5 hours of normal usage it is not fair with new device and I don't have another device so pls help me
  2. prvn0491
    Cupcake Oct 16, 2021
  3. B9TM9N
    B9TM9N , via OnePlus 9 Pro , Oct 16, 2021 :
    Even mooooore bad battery stats. Literally fully charged it and had it in my pocket or on a table most of the time. Why won't they fix these problems?
  4. J1603771076529
    Cupcake Oct 17, 2021
    J1603771076529 , Oct 17, 2021 :
    [QUOTE = "Mohammed shoaib 1001, post: 23746229, member: 3178841"] Recentemente comprei OnePlus 9 pro e estou enfrentando problemas ... meu telefone aquece toda vez em minha mão e toda vez que carrego meu telefone até 100 ele descarrega dentro de 5 horas de uso normal, não é justo com o novo dispositivo e eu não tenho outro dispositivo, então, por favor, me ajude [/ QUOTE]
    O meu está acontecendo isso também. Está horrível a bateria. Não dura 5 horas.
  5. vsinha717
    Gingerbread Oct 17, 2021
    vsinha717 , via OnePlus 9 Pro , Oct 17, 2021 :
    R u on 11.2.9.9 update. This update has fixed the heating issue substantially. Pls update to this version. If on this version contact support and raise a ticket.
  6. Rebel Rouser
    Froyo Oct 17, 2021
    Rebel Rouser , Oct 17, 2021 :
    Yes on 11.2.9.9 update. still happens.
  7. Akil Raghu
    Cupcake Oct 18, 2021
  8. vsinha717
    Gingerbread Oct 19, 2021
    vsinha717 , via OnePlus 9 Pro , Oct 19, 2021 :
    In general this issue is inherent to 9pro because of the sd888 chip so heating will be there. The android 12 open beta 1 which I am using currently has also resolved the heating issue even more. But it is still buggy so wait for Android 12 stable release which I think will help immensely or if you are ok with beta release u can try it. However reverting back to 9.9 will erase data.
    B9TM9N and X1625510111536 like this.
  9. vsinha717
    Looking from the extended use perspective the open beta 1 is the best solution from OnePlus. The heating has been controlled well and battery efficiency has improved substantially from 9.9.
    B9TM9N likes this.
  10. X1625510111536
    Donut Oct 19, 2021
    X1625510111536 , via OnePlus 9 , Oct 19, 2021 :
    Thanks for sharing, I'll wait for stable Android 12
  11. Paonepav1997
    Eclair Oct 20, 2021
    Paonepav1997 , via OnePlus 9 Pro , Oct 20, 2021 :
    The battery drain issue has started again, earlier at 100% it stayed for atleast 20 mins then started decreasing now it falls within a minute after i plug out the phone
  12. Paonepav1997
    Eclair Oct 20, 2021
    Same problem here, no fix has been done till now. Completely charged phone keeps draining battery very fast. Within 15 mins 5% battery drained without usage.
    and please don't ask whether am using later version. yes i keep my phone up-to-date
    B9TM9N likes this.
  13. Artemus
    Junior Moderator, Community Hero 2020 Junior Moderator Oct 20, 2021
    Artemus , Oct 20, 2021 :
    Have you posted any battery graphs?
  14. pradev
    Donut Oct 20, 2021
    pradev , via OnePlus 9 Pro , Oct 20, 2021 :
    Battery life becoming worst in oneplus 9pro, even knowing about the issue OP supporters will respond as if there is no issue with OP 9PRO, PLEASE Provide a fix instead of advising us. We have used previous versions of oneplus but we din face any issues. Did a mistake by buying 9pro
    J1603771076529 likes this.
  15. Artemus
    There is no one from OP that will answer, this is a user forum not official tech support. The only thing you'll receive are suggestions from other users to alleviate your problems.
    Battery problems will plague every other device if you don't know how to optimize your phone and be cognizant of what apps you use. Battery graphs help too.
  16. pradev
    Donut Oct 20, 2021
    Thanks for your advice on optimization, I was using 7T earlier i din do any optimization course for battery drain. In 9pro even with basic app I am facing battery drain issue.. the reason to buy higher end mobile is for good performance and battery life. There is a big question❓ mark on basic need it self.
  17. pablofg1978
    Head Moderator Head Moderator Oct 20, 2021
    pablofg1978 , Oct 20, 2021 :
    Thread merged
  18. Paonepav1997
    Eclair Oct 21, 2021
  19. B9TM9N
    Cupcake Oct 21, 2021
    B9TM9N , via OnePlus 9 Pro , Oct 21, 2021 :
    So I know this phone just has battery problems but what I don't understand is how my screen uses so much even though I'm hardly on it? I turn off auto brightness if I'm not using it and I also just turned of po let cuz maybe that uses the screen? Idk. I have tried everything and just no lick with this phone.
  20. arjunchemical
