58
[UNIFIED]OnePlus 9 pro Battery, heating and charging feedback thread
  1. the_o2
    OnePlus 9 Series Expert Community Expert Apr 8, 2021
    the_o2 , Apr 8, 2021 :
    Phone usually heats in both the scenario, but does it overheats?
    What is your Oxygen OS version?
  2. Caoimhín likes this.
  3. MarkoBatrac
    Ice Cream Sandwich Apr 8, 2021
  4. dishant25
    Cupcake Apr 8, 2021
  5. MarkoBatrac
    F1617297910704 likes this.
  6. Gary C.
    OxygenOS Product Lead Staff Member Apr 8, 2021
    Gary C. , Apr 8, 2021 :
    Hey everyone, thank you for your feedback.
    We've identified the underlying reasons behind the reported increase in temperature and already begun pushing out OTA updates to optimize the overall device temperature and improve battery performance. So far, the initial feedback has been positive.
    The first OTA (build number 11.2.3.3) was pushed out to our India users this week, and will be rolled out to North American and European devices by the end of this week. We’ll be following up with a second OTA to further improve the device temperature and battery in the coming weeks as well.
    Thanks so much for sharing your feedback here on the forums. We’ll keep working hard to make even more improvements so you can have a reliable and enjoyable OnePlus experience.
  7. A1541153458073
    Cupcake Apr 8, 2021
  8. camohan
    Moderator Moderator Apr 8, 2021
    camohan , Apr 8, 2021 :
    Hi there, I guess the diagnosis app is not giving right results.
  9. Swejuggalo
    Swejuggalo , via OnePlus 9 Pro Stellar Black , Apr 8, 2021 :
    Known flaw. All apps can get incorrect reported data. Possible solution is to toggle on/off reverse charging (just for the sake of the bug). But it does not remove the fact that is was never overheated just because apps said so. It even said overheat at a moment when my battery was 12°C. Look at the actual temperature.
  10. N1602406107837 , via OnePlus 9 Pro , Apr 8, 2021 :
    I purchased on the day of launch.Battery improved little bit after update but still it's not performing like what you will expect from a new 4500mah battery. Even moderate usage is draining battery very fast. I am having just 4 or 5 apps. nothing heavy. Also , it heats up Little bit on very light usage.
  11. Caomhin
  12. Swejuggalo
    Some says yes. Some say no. What that means however... (many issues not even related to the update itself is often blamed on the update) 😉
  13. eddiedimitris
    Cupcake Apr 8, 2021
    eddiedimitris , Apr 8, 2021 :
    Good evening. Today 2 times when they called me and I made the upward move to answer the google dialer got stuck and did not answer the call except it had a white screen. Has it happened to you? Also one more question ...
    There is a way the notifications that were added to android 11 and have all the notification history in it to have it as a shortcut or some kind of widget because it does not make sense to enter the settings every time. Thank you.
  14. Caomhin
    Caomhin , via OnePlus 6T , Apr 8, 2021 :
    Please check the Unified Battery and Heat thread for more info. Thanks
    https://forums.oneplus.com/threads/...feedback-thread.1412143/page-11#post-23045612
    N1602406107837 likes this.
  15. Caomhin
    MarkoBatrac likes this.
  16. Swejuggalo
    Guess you can read here if haven't done so yet and see what the overall idea of how the new update behaves.
    https://forums.oneplus.com/threads/oxygenos-11-2-3-3-for-the-oneplus-9-and-oneplus-9-pro.1414383/
    I have reported an issue myself that could generate both unnecessary drain and heat. But other than that I'm not really affected by any abnormal heat nor drain myself.
  17. Nipu_1998
    The Lab Reviewer - OnePlus Nord 2 Apr 8, 2021
    Caoimhín and MarkoBatrac like this.
  18. MarkoBatrac
    MarkoBatrac , via OnePlus 9 Pro , Apr 8, 2021 :
    Hi all,
    I just noticed this kinda wierd battery jumps. When I zoomed it, it looks like battery charges for 1-2 %.
    But in that time , my phone is not on the charger.
    What can it be ?
